Glare.....Should I replace my screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-19-2013, 12:32 PM - Thread Starter
sjdis's Avatar
I have a bad glare on very bright screen shots such as snow or white/light backgrounds. Is this caused by my cheap screen? If so, any suggestions on what type I should look for? I'm using an Epson 8700ub if that helps. As you can tell, I'm new at this Home Theater stuff but really enjoy it.
sjdis is offline
post #2 of 4 Old 12-20-2013, 05:24 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1774 Post(s)
Liked: 808
Is your screen a Fixed or Retractable? Brand? Surface type? How large? PJ Throw distance?
Often, adjusting the Gamma can reduce overt glare, as well as using the PJ in Economy Lamp Mode.
MississippiMan is offline
post #3 of 4 Old 12-20-2013, 07:11 AM - Thread Starter
sjdis's Avatar
Thanks for the info and advice! I'll check when I get home on the distance but I think it's around 12 feet. It's a fixed screen and about 109" diagonally. I don't know what brand the screen is because it was given to me as a gift from and AV guy who had it folded up in his basement for years. I think it was originally designed to be an outdoor screen because there was a black border around it. I cut it out and managed to stretch it out to remove the wrinkles.
Thanks again!
sjdis is offline
post #4 of 4 Old 12-20-2013, 07:35 AM
bepperb's Avatar
Trying the ECO mode on your projector is good advice. Painting a cloth screen more or less requires a sprayer, and outside of spraying paint I don't know of a good way to change the sheen of a screen evenly across a large surface.
bepperb is offline
Reply DIY Screen Section
