Which tint for Glidden GLN-9000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2014, 08:14 PM - Thread Starter
qwerty11's Avatar
I'm going to be painting MDF with Glidden GLN-9000. Could you please tell me what tint I should get the paint in?
The projector is an Optoma HD 20. Walls are a light tan, floor is cream, sealing is white. Windows have BOC on them. Room will have no lights on when using PJ.
Also, I was going to use Kiltz 2 to prime it. Is this ok?
What type of roller should I use for the Kiltz and Glidden?
Anything else I should be aware of?
qwerty11 is offline
post #2 of 3 Old 02-24-2014, 09:21 AM - Thread Starter
qwerty11's Avatar
Anyone? Already got two coats of Kiltz on the screen and ready to put the Glidden down. Just need to know what coat to get and any of info I may need.
qwerty11 is offline
post #3 of 3 Old 03-03-2014, 11:09 PM
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
You've probably already gotten it, but you don't want a tint. Just get the plain base.
Kilz 2 is fine as primer.
Use a 3/8" nap roller. I never really got a clear answer as to what material. Wool holds more paint and is better suited to being re-used, but I didn't find one under 1/2".
curttard is offline
Reply DIY Screen Section
