Encycolorpedia - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-31-2014, 08:24 AM - Thread Starter
PerryH's Avatar
Quoted: 47 Post(s)
Encycolorpedia
It has been a very long time since I posted here, but in an effort to find a wall paint that would not color cast photos if I bounce flashed off of it and/or that I could click on in a RAW file to use to set white balance, I came across this site...
http://encycolorpedia.com/cacaca
Those last 4 characters are hexadecimal values for RGB. If you give it a color in RGB it will return a set of the closest commercially named paint colors. It might come in handy for settling those screen shade debates that I remember from days long past. Behr Silver Screen is indeed the most neutral I have found so far among the widely available consumer brands (assuming their data is accurate). It might be a bit too dark for today's projectors (with better black levels), but it is pretty close to neutral... just slightly yellow.
PerryH is offline
post #2 of 3 Old 07-31-2014, 08:50 AM - Thread Starter
PerryH's Avatar
Quoted: 47 Post(s)
PerryH is offline
post #3 of 3 Old 07-31-2014, 09:06 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2053 Post(s)
Liked: 909
It's all about what can be considered practical ad-judgement of just how close to "perfect" something needs to be.
In your case, when bounce flashing off a surface when using a reference level Flash, the raw umber in SS would have to react, albeit very slightly. Enough to really matter? Only you can judge.
For all extent and purposes, when "projecting" onto SS, the extremely small amount of adjustment via calibration required to get to neutral makes SS among the best of choices. Of course that flew in the faces of those who condemned SS on the basis of it not being absolutely perfect. That....and the fact that "as is" it delivers a sub unity gain surface. SS is what it is, that's all that it is, and all it purports to be. Which BTW happens to be more than adaquate for many people,.
That Auto Table is pretty cool. Thanks for introducing it.
MississippiMan is online now
Reply DIY Screen Section
