Need help- milliskin spandex 70 inch width - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-22-2014, 06:29 PM - Thread Starter
BCWookie's Avatar
I'm trying to build a milliskin spandex screen. I can't seem to find a 70 inch width that I will need as my screen height will be 74 inches.
Anyone have any experience finding such a product?..
Marantz AV 8802
Goldenear 7.2.4
Oppo 105D
HTPC
BCWookie is offline
post #2 of 3 Old 08-22-2014, 08:29 PM
Debonaire's Avatar
Quoted: 149 Post(s)
Liked: 24
There's this stuff that's the same weight as milliskin per square foot. Available in white and a titanium (silver ).
122" wide.
https://www.dazian.com/product-detai...catalog=Dazian
Debonaire is offline
post #3 of 3 Old 08-23-2014, 05:38 AM
MississippiMan's Avatar
Quoted: 1490 Post(s)
Liked: 677
Might be worth considering, however although it is used as a Rear projection material, it has not been acclaimed suitable for AT use, at least in any critical listening sense I can recall.
Weight does not always equate to Weave, and time being an issue, direct comparisons are not likely possible.
The main hope being that Diazan is just a re-naming of 3-way Stretch 90/10 Spandex, (...so it is not as high a Blend as 80/20 - 4 way Stretch Milliskin...) and done so to segregate it from mere "Cloth" status and justify a higher price. However because it is used in Commercial Stage applications, it is more fire resistant than Spandex.
As stated above, it might be worth considering, but it will constitute a bit of a unknown factor. One thing is certain, it would constitute a big increase in the potential of larger DIY AT screens for those with 3000 Lumen Pjs and above.
Too bad is is over 2x more expensive.
MississippiMan is online now
Reply DIY Screen Section
