Salvaging a bad screen painting attempt - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-05-2004, 03:59 PM - Thread Starter
Riktar's Avatar
After trying to paint my screen with XO rust aluminum and finding out what the definition of Hot-spotting (With capital NEON letters) was I opted to go back to just painting over it (one coat) with my Ultra-White Latex paint that I originally used.
The end result was surprising: It seems that I am now getting higher gain from the screen. I am assuming that the white paint is translucent to some degree and it is allowing me to achieve a bit more gain from my screen.
Don't get me wrong it ain't night and day but the effect is noticeable enough that I can actually get a decent picture without having to go into total cave mode.
Riktar is offline
post #2 of 2 Old 01-05-2004, 06:05 PM
scoob5555's Avatar
You'll be interested in how MississippiMan makes a living painting screens: basically he paints a few layers of Behr Silver Metallic then a few thin coats of white on top of it to get exactly the effect you've seen.
You may want to check out his and CMRA's recent posts (since Thanksgiving) on a new DIY project dubbed SuperDeluxe with "MississipiMud" top coats.
Something profound
scoob5555 is offline
Closed Thread DIY Screen Section
