Getting the most from my DIY - AVS Forum | Home Theater Discussions And Reviews
Old 01-26-2004, 03:41 PM - Thread Starter
mastahkaz's Avatar
I was able to find some Parkland material over the weekend. So i got that and picked up some wood, trim, bher silver metallic paint, primer, matte black paint, screws, T and L brackets, and some velcrow strips.
I built a nice 64" x 48" frame with two mid-supports. All the peices to the frame are attached with L and T brackets and screws. I plan on attaching the Parkland to the outer frame with screws then use the velcrow for the mid support. I'm going to paint the trim peices black then attach them over the parkland either via adhesive, nails, or velcrow.
I had read a little thing about painting the back of the Parkland with Silver Metallic so i got some of that and plan on doing so. Are there any other quick things i can apply to my screen to give that little extra edge?
It'll be set up in my room using an X1 projector. I'll be using it for PC, gaming, consoles, movies, and HDTV.
Any advice would help, thanks.
mastahkaz is offline
