Blackout cloth vs white matte paint for ctr - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-10-2004, 08:04 PM - Thread Starter
Spyjoe's Avatar
Hi, just wondering what would give best results (IQ, brightness etc) if using either a blackout cloth or a matte white painted surface. The projector is a crt (specifically an electrohome 4100ecp). I realize that the blackout cloth would have the advantage of being perfectly flat since it can be stretched over a frame but for the sake of discussion lets assume i can achieve the same flatness with the painted surface.....thanks for all your help
Spyjoe is offline
post #2 of 2 Old 02-10-2004, 10:09 PM
b2bonez's Avatar
By all accounts, a wall painted with 2 coats of Ultra Pure flat white paint
is the cheapest and easiest ~1.0 gain DIY screen around.
Everything else is harder, more expensive and has more chance of
not giving a reasonable return on a cost-effort basis.
b2b
"Listen, You Pencil Neck Geeks.." 'Classy' Freddie Blassie ~ 1918-2003
A Toshiba spokesman, said that "from an engineer's point of view, the Blu-ray is a masterpiece.."
b2bonez is offline
Closed Thread DIY Screen Section
