DIY Masking Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-07-2004, 09:22 AM - Thread Starter
smyth22's Avatar
I have a dalite hi power pull down screen which is a little too big for my current projectors throw range and the size of my room. I want to do two things - Mask off the 2-3" of screen top and side not covered by my projected image and to mask off 1.33 and 2.35 boxes within the area covered by the projected image. I was thinking of using duventyne tape for the border areas and cutting some black gator foam sections to mask off the boxes. Iwas thinking of attaching some velcro strips to the black border portion of the screen to secure the gator foam strips. Does anybody have some better ideas? Will the duventyne tape be removeable from my screen and if so will it leave marks behind or otherwise spoil the screen? Has anybody tried using the velcro method for attaching masking material and if so have you any tips for me?
Peter
smyth22 is offline
Closed Thread DIY Screen Section
