Available sizes for screen Material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-04-2006, 06:15 AM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
Hi,
I am building my own screen using stretchers bars, material, and GOO. I found Best stretcher basr that had an aluminum core so I dont have to worry about frame strength.
I would like to go to with a 105"-110" screen. problem is that it seems that everybody offers 54" widths. I need 2 1/2" on each side to wrap around the frame. Does this material normally come in wider widths?
Since I am going to use Goo, I was planning on using Dazian 3pass blackout foam.
Your opinions are appreciated.
Logan
loganross is offline
Closed Thread DIY Screen Section
