Laminate Screen Material and Testing! - Page 92 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What are your screen requirements? (Pick as many as apply)
I want something that is easy to install. 425 18.54%
I want something as inexpensive as possible. 373 16.27%
I want something less than $100. 270 11.78%
I am willing to spend whatever amount is needed as long as it's the best. 70 3.05%
I want a simple one can painted screen option. 68 2.97%
I want an advanced paint mix screen option. 52 2.27%
I want a single material screen option. 290 12.65%
I want something durable. 271 11.82%
I want an ambient light screen. 245 10.69%
I have light control and want a white screen. 238 10.38%
Multiple Choice Poll. Voters: 2292. You may not vote on this poll
Old 06-24-2011, 10:17 AM
thedukeo8's Avatar
Good to know. Do you happen to know what percentage of the back of the laminate has to be adhered to a frame for it to hold?
Myu question might be quite arbitrary. But your frame looks fairly complex, by that I mean, more surface area for the DW to adhere to.
I was looking into making a frame that looked like:
Now obviouslt that isn't to scale as it is far more vertical than horizontal. I'm an ACII art noob. But that is the basic framing I am looking to create on a 16x9 screen. I would only apply the adheseive to those bars. I think it will probably be ok. But I just wanted some peace of mind.
thedukeo8 is offline
Old 06-24-2011, 10:18 AM
thedukeo8's Avatar
well damn. That took all the spaces out of my "image"
Old 06-24-2011, 05:52 PM
stubeeef's Avatar
Well when you look at mine only the tan wood is glued, the black part is "Gator board" used by framers. So the glue is really only on the 4 inch wide portions. This is a 110" screen and seems to work great. Been 2 years maybe 3 this August.
WAF
stubeeef is offline
Old 06-27-2011, 05:50 PM
w84no1's Avatar
I used the glue for my frame also. I used 3" pieces for my frame and it has worked for about 3 years. Make sure you only glue the outer part of the frame, don't use glue on any of the inner support pieces.
w84no1 is offline
Old 06-29-2011, 07:38 PM
thedukeo8's Avatar
Excellent, it had been my hope to only glue it to the perimeter of the frame.
Did you use the laminate floor glue, or contact cement? I got conflicting answers at Lowes.
The contact cement has to be applied to both the frame and the laminate and then let dry for 15-20 min; after which you apply a lot of pressure. Did either of you go through that, or did you apply the glue and then mount it on the frame pretty quickly?
I just want to make sure I get this right. Don't want to have to start over.
Old 06-29-2011, 08:07 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
you can adhere the inner frame for support and keep it from bowing... but it has to be a FOAM based adhesive that will not shrink and create a dip in your screen.
here's a good tip... at the same time as you are gluing the outside with standard laminate adhesive...squirt a bead of foam insulatin on inside supports.
pb_maxxx is offline
Old 06-29-2011, 08:42 PM
w84no1's Avatar
I used 3M 90-24 Spray Adhesive 17.6-Ounce. You still have to apply it to both the laminent and the frame, but it sets up a whole lot quicker.
w84no1 is offline
Old 06-30-2011, 09:19 AM
nickmo's Avatar
I've built three laminate screens over the last 4 years, and I've never had any luck with glue. The first glue down I tried I had to scrap and start over because it caused so much rippling and bending of the screen around the edges.
I've used a staple gun a couple times with much better success. I also think the spray adhesive is probably a better option for even application that won't cause ripples, but I've never tried it.
nickmo is offline
Old 07-05-2011, 09:45 AM
PeterB123's Avatar
Originally Posted by luebster View Post
It seems to me, after over 6 months of lurking around and occasionally posting in DIY laminate screen threads, people having problems with the laminate staying "flat" mounted it to a wood frame. We all know that wood expands, contracts, warps, and so on given changes in temperature and humidity. Even if those changes are 1/8 of an inch, the laminate will show it. As one wood working website once wrote, "The tendency of wood to contract and expand, shrink and swell cannot be stopped. You must plan for it. Design and build with dimensional change in mind."
One poster here constructed a wood frame with spring loaded tensioners that allowed him to tighten and loosen the frame as the wood changed in size. Have a search for that if you're determined to use wood.
If you're interested in something more "rigid," may I suggest a frame constructed of lightweight extruded 1" aluminum tubing sold by the 80/20 company. You can read about one poster's build here. Over 2 years later, he has had zero problems with it. Some other pros to 80/20's Quick Frame aluminum tubing are: lightweight, cut to your exact specifications, and easy to assemble.
To be fair, wood frame pros include easy to acquire, easy to cut, easy to assemble, some woods are lightweight.
For my money, however, aluminum tubing is the way to go. And I'll be going that way Monday when I call to place my order.
Good luck, dmac.
I went with the aluminum frame as well, and I have loved it. Light, rigid and will never warp, swell or contract.
Sure it costs a little more, but with the money you save by going WA and the long haul durability of the complete screen, it's worth the extra IMHO.
PeterB123 is offline
Old 07-06-2011, 07:17 AM
luebster's Avatar
Just a quick followup:
I completed my WA DW, 80/20 aluminum QuickFrame installation on Super Bowl Sunday (Feb 6, for the uninitiated). The screen measures roughly 92" wide by 52" tall for a 103" diagonal. If the math is off, don't flame me. I'm at work and don't have the exact numbers in front of me.
I used industrial strength Velcro to fix the laminate to the frame and Goo Systems black Screen Flock tape directly on the screen for the border. 5 months later, the only problem I've had is the Flock tape contracting at the corners. My bad for stretching it too much during application.
As for the laminate and the frame: perfection. The screen is still as flat, waveless, and perfect as the day I hung it. Do yourself a favor, eliminate future headaches, and go with an aluminum frame.
luebster is offline
Old 07-13-2011, 09:56 PM - Thread Starter
wbassett's Avatar
Location: Been all over. Currently living in upperstate NY in the Capital District area.
More proof that complex just for the sake of being more complicated isn't always better, it's just more complicated.
Fashion Grey still works as an N8 gray screen, and people really should look at OTS grays. The only way to really know if a complex method works or is even better is to have a baseline and try something as simple as an OTS method. Most people will be amazed how well the simple methods really do perform. Of course people that are advocates of the complex methods will argue about this. Try it for yourself and make your own decision...
"Make everything as simple as possible, but no simpler." - Albert Einstein
wbassett is offline
Old 07-14-2011, 06:01 AM
w84no1's Avatar
I used white mdf board to build my frame and Fashion Grey for the screen. Attached it with the 3M 90 adhesive I mentioned early. I too used the Goo Systems Black Screen Flock tape. Everything has been going great for 3 years.
w84no1 is offline
Old 07-18-2011, 06:27 AM
the-pred's Avatar
So i failed miserably on my first attempt. I glued the inner of the laminate to my frame and when it dried it warped the laminate in a bunch of places. Way too many waves for me to ignore. I was thinking of just ordering a new piece of WA and this time screwing it right over the warped piece. What is the best method of screwing? Where to start, how many (120" screen) Do you guys use washers so u don't risk little indents where the screws pinch the laminate? Any help would be appreciated. Already out $150 for first piece of laminate.
the-pred is offline
Old 07-18-2011, 09:13 AM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
not unless you want to waste another $150.
honestly this is one of the very reasons/areas that 6mm sintra has a huge advantage over laminate.
if you're gonna build a frame for laminate rather than using a solid substrate... do not... and it's been stress here over and over... not to glue the laminate to the inner frame.
if for some reason you have to do so for support... such as bowing in the middle... then you must use a NON-SHRINKING adhesive... preferably one that is FOAM based.
in fact, my personal tip here is not an adhesive at all... instead... use a bead of foam based insulation/gap filler from a can for the inner supports. it takes a day to cure/dry but once it does... it'll be plenty strong enough to hold the thin laminate and keep it from bowing without shrinking and creating waves.
pb_maxxx is offline
Old 07-18-2011, 12:54 PM
the-pred's Avatar
This time I was not going to glue the inner at all. I was going to try and screw all around the outer and my 2 inch border will cover this. Is this the best way?
the-pred is offline
Old 07-18-2011, 01:49 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
two issues pop out...
1st - the laminate is thin enough to flow the ripples/waves of the laminate underneath it. it might not be as heavy, but it will be there.
2nd - should you choose to use screws you must pre-drill the holes and you must not rachet them down enough to buckle (ie perimeter waves) and/or break the laminate.
pb_maxxx is offline
Old 07-18-2011, 07:15 PM
the-pred's Avatar
ya definetly pre drill. If it is not glued at all then I can always unscrew if it shows the ripples from underneath.
the-pred is offline
Old 07-19-2011, 01:10 AM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
I had a local laminate shop cut and make my screen for me. The best thing is they only charged me $40. They glued it to 1/2" MDF with contact cement. The most important thing to do they said is to glue a sheet of "backer laminate" to the back of the MDF. This keeps the MDF and laminate from buckling as the glue dries. They also told me to use the iron-on melamine on the 4 edges of the MDF, which I did. I then hung it on the wall with 3 french cleats.
Jim McC is offline
Old 07-31-2011, 09:56 AM
thelordofthelink's Avatar
My Laminate screen 92"
thelordofthelink is offline
Old 07-31-2011, 10:02 AM
the-pred's Avatar
What frame method did you use. How did you attach laminate?
the-pred is offline
Old 08-01-2011, 07:11 AM
I used wood framing and attached laminate on a plywood board by gluing.
Old 08-08-2011, 07:12 PM
msamblanet's Avatar
Originally Posted by Bob7145 View Post
Made a screen to experiment before finalizing the design for the 4 x 8 WA DW awaiting mounting. Others have tried it in the TWH thread. Glued a sheet 1/2" rigid foamboard insulation to the TWH. Lightweight, self standing capable, easily handled by 1 person, From what I learned doing this I will most likely use 3/4" rigid foamboard with a 1" x 4" or 6" wood perimeter frame for the WA DW mount. Instead of hanging the screen it will set on something like a shelf or 2x2 screwed to the wall. Ya, low budget and quick assembly.
Bob7145,
I am considering a similar approach as I have a bunch of left-over 1" and 2" XPS rigid foamboad from my basement finishing. Did you use foamboard glue (such as PL300) or something else?
Also - for anybody who has done a borderless Wilsonart screen - any recommendations from those who have treaded into the borderless lands how much one can/should undersize the frame as compared to the laminate sheet without having problems with the edge?
msamblanet is offline
Old 08-09-2011, 07:07 PM
Bob7145's Avatar
Liked: 36
Sorry, don't remember what kind of glue but used a caulk gun to apply it. Used the whole tube. Think it was Liquid Nails?
Edit, ya I think it was foamboard glue. The trick is to apply the glue in a pattern that won't trap air. I bought spray glue for the next screen.
2nd Edit: I like the foamboard backed screen because it is light enough to move by myself.
Bob7145 is offline
Old 08-10-2011, 09:57 PM
msamblanet's Avatar
Thanks Bob - I presume your 2nd screen was not foamboard since I am pretty sure most spray glues will melt the foamboard...
I was thinking with a little work I could spread the glue out into an even thin layer (and make a nice big fun mess at the same time )...your idea of spreading the glue to not trap air might be easier...some tests are in order...
BTW - how do you hang the foam screen? Did you just glue a cleat to the foamboard?
Old 08-11-2011, 05:10 AM
Bob7145's Avatar
Liked: 36
Wait, I never said "spread the glue". I said "pattern".
I used lines and dots. TWH is not laminate but paneling about 1/4" thick. Does not need a lot of support so 1/2 foamboard is enough to stiffen it. You could get glue in a can and use a trowel to spread it but the caulk gun works with TWH and foamboard.
It is a freestanding screen, no cleats, hardware or wood.
Spray glue - ya, could not get an answer from anyone about melting foamboard but have not assembled the WA laminate screen yet. Bought several cans of glue to test.
Lightness and portability of the screen is what I am after.
Edit: I may just glue the WA laminate to the TWH and then Foamboard on the back of the TWH. No melting then.
Bob7145 is offline
Old 08-11-2011, 10:55 AM
msamblanet's Avatar
I realize you did not suggest spreading the glue - that was my thought...but the more I think about it, the more I like your approach
If you are looking to our the WA over your existing TWH that makes sense...but if doing a new screen then I don't see a reason to add an extra layer.
Foamboard is cheap enough so some glue tests are easy enough. Once I run some tests I will post my results...
Old 08-11-2011, 05:52 PM
Bob7145's Avatar
Liked: 36
Right, it's just that 1/2" or 3/4" foamboard (the only thing I have access to) is not stiff enough to apply to WA laminate. Your 1' or 2" foamboard is better.
I bought the spray glue for the WA laminate because the caulkgun method would produce wrinkles/waves.
Bob7145 is offline
Old 08-22-2011, 09:49 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hey folks,
what are the techniques for building laminate screen with wood frame that won't bowed/waved?
i built an 80" screen using 3" pine frame, with 2 vertical bars for support, yet this small screen has too much bowing/waving. i screwed laminate to the frame.
i am now wanting to build a bigger screen, 120" but i think with its size, it's going to have much more wav/bows.
thanks
smokarz is offline
Old 08-22-2011, 02:05 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 690
hey folks,
thanks
wood moves with humidity, it's a fact.
I've seen 2 ways that work.
1) have the laminate "float" so it's held with grip but not hard, so as the frame moves/flexes the lamiante won't take a bad buldge, member "larrychief" did that
2) Have the frame constructed so it absorbs the movement. Somewhere in this thread there was a ingenious construction method where the frame end joints were such that they allowed relative movement of the joining member, and not cause the laminate to bow/buldge.
IMO, if you really want laminate , which I really love the picture quality, then use some of the sq alum tub methods/vendors people have posted about.
mtbdudex is offline
Old 11-12-2011, 10:29 PM
redeye42's Avatar
I wanted to pass along a thanks to the thread starters here on the Quickframe material on a WA DW screen.
I had been needing to do a proper mounting for my screen for some time. I ordered a Quickframe to my spec, not unlike the 20fan setup, and took a bit from sovremennik's post to use readily available (and cheap - about $4) permanent carpet tape to mount the WA to the frame.
I ordered on Friday and then left town for a couple day work trip and the drop ship Quickframe bits where here when I got back.
The Quickframe goes together like a breeze and is quite solid but light. Tracing the frame on the back of the WA with a pencil provides a tape guide. The whole thing took about 20 minutes to do and it's back on the wall.
Great stuff, Quickframe. I have always liked the WA screen but did not quite have a perfect flat mount - this stuff is it. Perfectly flat, light, simple. Could not have asked for better, and not expensive.
Thanks again.
redeye42 is offline
