rear projection screen material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-18-2007, 07:48 PM - Thread Starter
blindbartimaeus's Avatar
I am going to make a screen on the back wall of our church so our Pastor can see what is on the screen behind him by looking past the people on the back wall. I don't need a rear projection screen as I am thinking about taking out the area of a screen and making/stretching one and making it fit into the open spot. There is an area to mount a projector behind the wall.
blindbartimaeus is offline
post #2 of 5 Old 01-18-2007, 08:16 PM
Clarence's Avatar
Quoted: 305 Post(s)
Liked: 12327
Was there a question we can help you with?
Clarence is online now
post #3 of 5 Old 01-19-2007, 12:09 AM - Thread Starter
I don't need a screen setup...I need the rear projection screen material to make my own screen...where can I get some affordably?
post #4 of 5 Old 01-19-2007, 05:14 AM
Clarence's Avatar
Quoted: 305 Post(s)
Liked: 12327
http://archive2.avsforum.com/avs-vb/...38#post3638038
http://www.rosebrand.com/search/resu...?search=screen
Rosebrand Grey Projection Screen Material
"Grey projection screen is best for rear projection, but can be used for front projection. This neutral color blends into the background and reflects less ambient light than white screens. It is good for outdoor use. 55", 86", 94", 114" and 180". The 110" wide material is 2 widths of 55" welded together.
55"w = $15.70/yd.
86"w = $76.05/yd.
94"w =$69.00/yd.
Custom Rear Projection Screens without Edge Finishing
Vertically welded without any edge finishing for your insertion into your set. Larger screens will be folded for UPS shipment, unless instructed otherwise.
Technical Specifications
Unit Weight: 1 oz.
Width: your dimensions
Thickness: 4 mils (0.004 inches or 10 millimeters)
Price: $3.00 per Square Foot
Dazian also on ebay
Da-lite
http://www.projectorzone.com/sfastfold.html
$278+...
+ $345 for 65"x116"
+ $65 for Cinema Vision?
(=$688!)
Rosco
http://www.rosco.com/us/screens/roscoscreen.asp
Gerriets Optitrans
http://gi-info.com/projection_screens_rear.html
http://www.iweiss.com/curtains/scree...n-screens.html
https://secure.room2.co.uk/harknesshall/
Rear Projection Screen Surfaces
- Translite
- Polacoat
- RP230
Front and Rear Projection Screen Surfaces
- Translite Super 2
Goo
"We have also introduced a very exciting new product. Goo Systems has engineered a new rear projection screen coating designed to provide exceptional results in both home and business applications. Any rigid transparent surface can now be cost effectively transformed into a high quality dual-sided projection screen."
http://www.goosystems.com/index.php?cont=products
Title: Rear Projection
Sku: 4730
Price: $750 CAD
Da-Lite Rear Projection (Da-Tex and Dual Vision are RP)
- - http://www.cambridgeworld.com/Da-Lit...n_surfaces.htm
- - http://store.cousinsvideo.com/cut-to...n-surface.html
You can also search and find people that have had some measure of success with gray frosted $5 shower curtains from WalMart.
Or you can search ebay for "fastfold" and find a Da-Lite RP snap screen for as low as $9 (this is your best bet for cost/performance).
post #5 of 5 Old 01-19-2007, 10:39 AM - Thread Starter
Thanks...good stuff
Reply DIY Screen Section
