rear projection AND acoustically transparent? - AVS Forum | Home Theater Discussions And Reviews
Old 01-26-2007, 10:02 PM - Thread Starter
Dawn12's Avatar
I'm creating a video art project and am in need of several large projection screens. Due to the nature of the project, I need the screens to be rear projection as well as acoustically transparent. After doing some research, I'm not sure it's ever been done, or even doable.
Quality is important to me, but not so important that I'll spend thousands of dollars to get it. I was hoping to spend less than $1000 dollars for the screens. I'm very willing to do any work required to make one, but I want the quality to be good (meaning that ironed wax paper just won't cut it).
I've seen some good reviews on Dazian's CCC material, as well as some bad ones (comparing it to the SMX), so I'm curious as to whether it can be used as a rear projection material. It's been suggested, but I've found no conclusive answers. Can anyone using the Dazian CCC cloth let me know?
What about Dazian's Trapeze material? I've heard it is a porous material - would this let sound through?
Might anyone have any other ideas as to what I can do? The only other solution I've found is actually quite neat, but far too expensive - using the Goo to cover a plexi-glass surface, and then making the surface into a loudspeaker using Induction Dynamics' SolidDrive technology - again, really neat, but far too costly.
I really don't want to use bedsheets. Any help would be appreciated!
Melissa
Dawn12 is offline
Old 01-26-2007, 10:51 PM
wbassett's Avatar
Location: Been all over. Currently living in upperstate NY in the Capital District area.
Check out RoseBrand's website
"Make everything as simple as possible, but no simpler." - Albert Einstein
wbassett is offline
Old 01-27-2007, 09:04 AM - Thread Starter
Dawn12's Avatar
I checked out Rose Brand, and their projection material comes 110 inches wide. I need at least 122 inches wide... I called them about the only rear projection material they have that isn't bound by that width, and they said no sound would come through it. Thanks for the help though, wbassett.
Any other suggestions?
Dawn12 is offline
Old 01-27-2007, 11:15 AM
SmX
SmX's Avatar
Try Dazian CCC
Ruben
Follow SmX on Facebook
SmX Video Projection Screens and Masking Systems
WWW.SMXSCREEN.COM
SmX is offline
Old 01-29-2007, 10:05 AM - Thread Starter
Dawn12's Avatar
I contacted Dazian and they informed me that the CCC would not let light through, so it would not work as a rear projection material...
Dawn12 is offline
Old 02-07-2007, 12:29 PM
bugman72's Avatar
I believe that Dazian hasn't seen how MUCH light the CCC lets through. If I get a chance this evening I will try to take a pic of what my back wall currently looks like as well as the image that you can see from the back side of the screen. Right now, my back wall is completely untouched (white walls behind a metal stud false wall). You shouldn't have any issue in using the fabric as a rear-projection screen.
"Can I refill your eggnog, Eddie? Drive you out to the middle of nowhere and leave you for dead?"
Greg Jones
My Former Theater...The Escape
My DVD Collection
bugman72 is offline
Old 09-30-2013, 12:23 AM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Bringing a old thread back from the grave... Did you get a chance to test it out?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
