best DIY screen for hd1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-25-2007, 08:34 PM - Thread Starter
prime21's Avatar
i want to make my own screen for my hd1000 but i am still unsure what the best screen would be. Painting the wall, BO cloth, some kind of plas-tex or substrate or whatever? I have total light control but i do like a little ambient light in the rear of the room. (probably wouldn't affect the picture much) ..i just need help finding out what the best screen is for this PJ. and what gain i should be looking for.
Also, what methods are you guys using to eliminate the black bars when in 2.35-1 or 4:3 mode ?
Thanks for any help.
The only thing i REALLY know about PJ's is that my wife hates the fact that she was wrong about them.
prime21 is offline
post #2 of 11 Old 02-26-2007, 02:07 PM
jrolson16's Avatar
i have a diy plastex (parkland) screen w/ my hd1000u...love it! i made a frame for mine...lumber and other materials < $110.00
Xbox 360 Live Gamertag: IAHAWKFAN16
jrolson16 is offline
post #3 of 11 Old 02-27-2007, 12:09 PM - Thread Starter
prime21's Avatar
I guess i am leaning toward the Wilsonart Laminate DW, but i really am not sure still what i wanna do...I was actually thinking of the Plastex before but i'm not really sure what goes best with the hd1000.
I want a little ambient light in the room so i assume i need something with a touch of grey in it. What kind of gain does the wilsonart DW have, anyone know?
prime21 is offline
post #4 of 11 Old 02-27-2007, 05:19 PM
muzz's Avatar
Quoted: 753 Post(s)
Liked: 507
That 1000U is pretty bright, I personally wouldn't be too worried about gain, and start paying attention to Neutral for honest color rendition.
JMO
How big is the screen you are thinking of? Throw distance?
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #5 of 11 Old 02-27-2007, 07:24 PM - Thread Starter
prime21's Avatar
JMO
Probably a 110" screen with about a 14' throw...I was thinking of trying the Fneasy solution at first with just primer and then adding tint IF i still need it. Sound ok?
prime21 is offline
post #6 of 11 Old 02-27-2007, 07:37 PM
Baylo's Avatar
Take this for what it's worth, because I have no basis for comparison, but I just did the FnEasy treatment with my HD1000 and I'm pretty happy so far. I did the slight grey tint noted in the thread. White's still look great.
Good luck!
Mark
Baylo is offline
post #7 of 11 Old 02-28-2007, 06:48 AM
skyman00's Avatar
Prime,
Gain of DW is 1.24. -j
skyman00 is offline
post #8 of 11 Old 02-28-2007, 12:20 PM
muzz's Avatar
Quoted: 753 Post(s)
Liked: 507
I think it's a good starting point, and if you feel the want/need to go to a more advanced mix, it won't be difficult to upgrade, because you'll have a better idea of what you need with your PJ, in your conditions.
It sounds to me like you won't have too much Ambient Light, so it will get you started.
I had a white screen(Flat white ceiling paint), and it did fine when dark, but it began washing out quickly when I put lights on, so I painted a gray screen(with 2 topcoats of #780 Poly), and the results are MUCH improved when lights are on.
It all depends on how much effort you want to put into the initial screen, if you want or need the BEST AL performing screen right away, I would suggest you look at some of the more advanced mixes.
If PJC is anywhere near correct, you'll be around 16fl at that size screen, which is according to them " Recommended brightness for dark Rooms", I think it's PLENTY bright myself, according to them I'm at like 12fl, and mine is plenty bright to me.
Thats IMO, others may have different views on the matter.
muzz is offline
post #9 of 11 Old 03-01-2007, 05:20 AM
jimwhite's Avatar
where is this calculator with FL calculations ??
Jim White
St. Petersburg, FL
jimwhite is offline
post #10 of 11 Old 03-01-2007, 05:37 AM
neekos's Avatar
Quoted: 80 Post(s)
Liked: 66
it's just under and to the left of the mock projector in the middle of the box where you put in your calculations.
neekos is offline
post #11 of 11 Old 03-01-2007, 05:39 AM
neekos's Avatar
Quoted: 80 Post(s)
Liked: 66
neekos is offline
Reply DIY Screen Section
