CMRA's S-I-L-V-E-R solution starts here: - Page 26 - AVS Forum
 1Likes
post #751 of 763 Old 08-24-2014, 07:04 PM
DIY Grand Dad (w/help)
MississippiMan's Avatar
Quoted: 356 Post(s)
Liked: 272
Originally Posted by Debonaire View Post
Mm,
CMRA'S original darker version was 192,193,185, yours was lighter. The darkest a Basics silver and Heavy Body iridescent silver can get at 2:1 is 170,170,170. I wish I had RGB of your Liquitex Basics screen. But even Basics Silver alone full strength can't get darker than 171, 171, 170.
Switching first to Delta Ceramcoat Silver (my first several S-I-L-V-E-R S) and then having a few do S-I-L-V-E-R using the Liquitex certainly created lighter versions than what was the result from the Behr Faux Silver. Beyond the depth of Gray the silver imparts, as well as the concentration of Silver within the mix, it's all about the degree of translucency and the White Base behind.
To quote James T. Kirk;
"I'm laughing at the superior intellect"
http://www.invisiblestereo.com
MississippiMan is offline
post #752 of 763 Old 08-24-2014, 07:25 PM
greg1292's Avatar
Quoted: 35 Post(s)
Originally Posted by narhic_fd View Post
greg...i to have the graco 1900 unit and am curious as to how much water you had to add for the s-i-l-v-e-r to spray out properly. I havent tried to spray any of the paint mixes on here with the 1900 unit and could use some info on water amounts.Have you sprayed silver fire with it??? If so how much water did you end up using for silver fire??
I have made both screens and S-I-L-V-E-R is a great screen for me as I have total light control and like running my JVC on eco
mode. I tried the liquitex and Martha Stewart but prefer a professional grade air brush aluminum. I used 1 quart of faux glaze,4 oz air brush aluminum and 12 oz of water applying 8 dusters. Just threw my screen away and am going to make a larger version tomorrow.
Going from 92" to 110". I will post some pics of the process. Unless Mississippi has another mix he thinks I should try????
Happy Holiday's
greg1292 is online now
post #753 of 763 Old 08-24-2014, 09:19 PM
Debonaire's Avatar
Quoted: 142 Post(s)
Which brand and color? Was it one of these?
http://www.dickblick.com/airbrush/colors/
My guess is its Createx Pearl Silver.
greg1292 likes this.
Debonaire is online now
post #754 of 763 Old 08-26-2014, 02:15 PM
greg1292's Avatar
Quoted: 35 Post(s)
yes sir...
Happy Holiday's
post #755 of 763 Old 08-26-2014, 09:54 PM
Debonaire's Avatar
Quoted: 142 Post(s)
yes sir...
Which brand and model sprayer with nozzle size used?
post #756 of 763 Old 08-27-2014, 07:37 AM
greg1292's Avatar
Quoted: 35 Post(s)
Graco with 1.0 tip
Happy Holiday's
post #757 of 763 Old 08-29-2014, 10:42 PM
Debonaire's Avatar
Quoted: 142 Post(s)
Graco with 1.0 tip
I was going to get the Wagner CS with the 1.5mm tip. So that means your mix will be too wet. How much less water for a 1.5mm tip compared to a 1.0mm?
post #758 of 763 Old 08-30-2014, 11:32 AM
greg1292's Avatar
Quoted: 35 Post(s)
Can't help you with
that I do advise a 1.0 tip
Happy Holiday's
post #759 of 763 Old 08-30-2014, 11:46 AM
narhic_fd's Avatar
Quoted: 27 Post(s)
Be careful when buying the wagner control spray. I think they now come with a slandered 2.0 tip instead of 1.5 tip but i may be wrong. I know the replacement tips you can buy from gleam are only 2.0 tip now and when i was thinking about buying the Wagner CS i couldnt find a replacement 1.5 tip to buy anywhere. Try to find a refurbished graco 1900 if you need to go easy on money. You will still need to buy a 1.0 tip though for the gun. The 1.0 needle tip is different for the graco 1900 unit though. Here's a link to a previous post about the 1900 that i made:
Refurbished Graco 1900 for GREAT price!!
when i bought the 1900 from the website it had it for $49 i think but now it's gone up to $99 and you will need to look on amazon or somewhere else. I think it Will be getting little hard to find the graco, 2900, 3900 spraystation units since i believe graco has discontinued them due to there newer model the HV2901....I could be wrong on that.
narhic_fd is offline
post #760 of 763 Old 08-30-2014, 05:46 PM
narhic_fd's Avatar
Quoted: 27 Post(s)
Have you sprayed a Silver Fire screen with the 1900 unit?? If so, do you remember how much water you ended up using for the gun to spray properly?
post #761 of 763 Old 09-09-2014, 08:59 AM
greg1292's Avatar
Quoted: 35 Post(s)
I have 122" screen with a Mitsubihi HC-5 1176 hours on lamp in eco mode. Iphone 5 does not do the image justice but 1.0 tip is awesome. Simple but amazing and cheap paint
solution. In fact 20.00 in paint what a deal.
No idea on water just add till the viscosity is right.
ID:	254498   Click image for larger version
ID:	254506   Click image for larger version
ID:	254514   Click image for larger version
ID:	254522   Click image for larger version
Happy Holiday's
post #762 of 763 Old 09-11-2014, 08:22 AM
Liked: 3
Great looking images Greg
mediahomesireland is offline
post #763 of 763 Old 09-11-2014, 09:50 AM
greg1292's Avatar
Quoted: 35 Post(s)
Credit
All credit goes to Mississippi abd PBmaxx still learnig the HC5 picture is getting better. Thanks for the kind words.
Happy Holiday's
Reply DIY Screen Section
