Want to build portable cloth screen - AVS Forum | Home Theater Discussions And Reviews
Old 08-13-2007, 10:45 PM - Thread Starter
wrow's Avatar
I have a special situation that I cannot seem to find help for on this board. I know you guys have the answer though!
I go to a military college, and although we can have a projector our 2nd year, we can't have anything (posters, screens, etc) on the walls, or any sort of screen (unauthorized item) in the room.
So, my idea is to have 4x 90-degree (L-shaped) pieces of velcro up on the wall that could hold a cloth screen. I would like to be able to roll this screen up and be able to put it away when need be, because it will really only be up at night and on the weekends.
I have a brand new Acer 720p projector with 1000 lumens, and live in a room with no windows, so lighting shouldn't be a problem. The projector is going to be between 8 and 10 feet from the wall, and will not move. My idea is that I can measure the image on the wall, and cut a screen material to size that I could adhere to the velcro.
I haven't yet tested the screen on the wall as it is, but as a nasty, poorly painted white, I don't imagine it will look very good.
So my question for you: What are my options? Or am I out of luck? Thanks and I appreciate all the help in advanced.
wrow is offline
Old 08-14-2007, 07:54 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1768 Post(s)
Liked: 806
Hi wrow,
What Academy do you attend? My youngest Son just graduated from Faukland U's Army ROTC program and is now a 2nd Liutenent (Quartermaster Corps). It's hard for me to fathom my 22 year old walking out of school into 48k + yrly. But hey...he earned it! (3.997 GPA too!) Good luck to your plans!
An "Acer" eh? 720p? Zounds! You don't state which model you posses, but upon checking, the 720p DLPs they have range from 2200 to 4500 lumens.
OK...., I'm gonna suggest something I virtually never do, least wise not on the DIY Forum.
Get a "el-cheapo" manual Pull Down screen.
No "Cloth" that is not significantly "bottom" weighted and formed to be flat will do your situation justice. You could acquire some Black Out Cloth and using the shiny side, get a decent image, but unless it's stretched across a rigid framework, the wrinkles and folds will distract terribly from your viewing experience. Even "Waves"....slight variations of height (distance) from the wall will be quite noticeable.
The darn things cost just over to just under $100.00 on some web sites. (...yeah...a LOT of $$$ for a Student...) Below is a link to a 16:9 unit. A Web Search will find others for less.
http://www.projectorscreensdirect.c...Go.x=20&Go.y=10
Retracted, it will fit easily into a closet or under a bed. That is if "Inspections" would not take issue with such when it's stowed away neatly, out of sight..
Here's a plus. Unlike a Wall (see below) you can paint that screen with a Contrast enhancing coating, increasing your perceived CR considerably (Acers max out at 2500:1) if you want the room to remain "lit". Depending on which Acer you own, you've got lumens to spare, but those lumens, when reflected off the screen (or wall) will also splash out and onto every white surface around you, further reducing your observable "On Screen Contrast"
The other option is to get permission to re-paint the walls a clean shade of white. If possible, that would be the easiest route to take, owing to the fact that no "set-up / take down / stowage would be needed. That should be do-able. Just ask the OD as if you want to improve your room's appearance for Inspection.
Of course, if all the alternatives are crap.....then rolling out some BOC and hanging it on that Velcro is gonna work to some extent better than a poorly painted wall. Maybe. (...you'll have to take down the Velco too, yes?) I'd say you just gotta try that Acer out on that wall first, no matter what....then go from there.
Beyond all the above, I suggest you also ask the question of "where can I find a Cheap Pull Down Screen?" over on the "Screens Forum" because around here we are best suited for, and focused on true DIY applications. If you want to continue along in that direction, that is?
MississippiMan is offline
Old 08-14-2007, 08:58 AM - Thread Starter
wrow's Avatar
Thanks for your help Mississippiman, I believe I am getting to being on the right direction. Glad to hear your son is Army! I go to VMI. My real issue is all the rules I have to follow in order to comply with Institute regulations. We pride ourselves in our Spartan lifestyles, as we don't even have beds to sleep on! So when it comes to adding something technologically advanced, things get difficult. The projector we are using is the Acer PH530.
All of barracks is repainted every summer, and as you can imagine, when painting ~400 cadet rooms, the paint tends to be cheap. I believe by now it is several inches thick. Repainting the room on my own is not an option, as there is a specific punishment already laid out for doing just that.
Having a screen is pretty difficult, as far as they are concerned, if you don't NEED it, you can't have it. The projector is already pushing the limits, and with my room being inspected 3 times a week, it'd be tough to keep.
I guess I will further my research and take pictures when I return on the 26th and seek further advice. By then I'll have enough posts to post images, and be able to best set-up my room. I appreciate your help.
wrow is offline
