Proper set up of Denon DVD-1930ci for SACD playback? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-13-2008, 07:03 PM - Thread Starter
Scott_lb's Avatar
Liked: 47
Greetings! I recently purchased a Denon DVD-1930ci for SACD and DVD-Audio purposes. I have it hooked up to my new AVR-2809ci via HDMI (and only HDMI - no analog outputs) and am rather certain that I have my player and receiver settings correct. My lossless Blu-ray discs sound great (from my PS3) as do my DVD-Audio discs from the Denon (listening to Metallica was like hearing it for the first time!). When I pop in a SACD disc, the player reads and plays the discs and I can select the different SACD tracks as seen on the player's display. However, I cannot get any sound from SACDs on my system (sans standard CD audio for SACDs which also feature standard CD audio). Can anyone point me in the proper direction? Thanks
Scott_lb is offline
post #2 of 7 Old 10-13-2008, 07:08 PM
Kal Rubinson's Avatar
Quoted: 748 Post(s)
Liked: 518
I do not think the 1930ci will output SACD over HDMI.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 7 Old 10-13-2008, 07:38 PM
sivadselim's Avatar
Quoted: 248 Post(s)
Liked: 216
ooops
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #4 of 7 Old 10-14-2008, 07:20 AM
The_Nephilim1's Avatar
Quoted: 33 Post(s)
I have this Player you need to use the Analog Outs for SACD and DVD-A lossless. As for the DVD-A and using HDMI you Probally Not listening to the DVD-Audio but to the Lossy versions. To Test This theory Do you have "Love by The Beatles??
If so Put that DVD-A in if it Doesnt Play you havent got it hooked up correct. AS the Love DVD-A Only has a DVD-A Track No Lossy Tracks on it??
Or On your TV When you put in a DVD-A Disk and it Plays that you will See DVD-Audio words Show up on the Screen top right.
you also need to change a setting in the Menu to Play DVD-A. I can get the exact menu Option you need to change..
The_Nephilim1 is offline
post #5 of 7 Old 10-14-2008, 07:24 AM
Quoted: 748 Post(s)
Liked: 518
According to Denon: HDMI 1.1 (HDCP Compatible - SiL9030) - With Selectable Scaling - 480p/720p/1080i/*1080p and DVD-Audio Output
Notable absence of SACD.
Kal Rubinson
post #6 of 7 Old 10-14-2008, 11:50 AM
sivadselim's Avatar
Quoted: 248 Post(s)
Liked: 216
The player should pass DVD-A via HDMI just fine. Maybe your receiver can't decode DVD-A via HDMI properly. Or you haven't set the player's video resolution to a setting that will allow you to pass DVD-A via HDMI.
What it can't do, as noted, is pass SACD via HDMI.
post #7 of 7 Old 10-14-2008, 11:55 AM
konoyaro's Avatar
The Love Special Edition DVD has DTS and Dolby Digital in addition to MLP/DVD-Audio.
konoyaro is offline
Reply Surround Music Formats
