Supertramp Crime of the Century 5.1 MLP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 58 Old 03-31-2009, 10:42 PM - Thread Starter
scooterdog's Avatar
Liked: 36
I was browsing one of my sites I find things at and noticed someone decided to remux the famed Supertramp Crime of the Century album into a DVD A MLP 5.1 mix. Granted he was quite straight in letting everyone one know that this was done from a stereo recording and he goes on to explain the equipment and process he uses to turn this into a 5.1 recording at 24/96.
I decided to take the 15 plus hours to obtain this and hear what this would sound like I was able to finally burn it onto a dvd. I plopped it into my dvda player and wow was I impressed. Granted its not remastered in the way studios do these but in all honesty it is pretty darn good. Nice and clean with good surround. I had to bring down the surrounds a bit as it tended to be a little hot. But there was good surround from left to right in the rear not to mention front to back. Vocals were placed in the center for the most part.
There was very good discreet surround taking place and the overall sonic value was tasteful. So if you are a Supertramp fan and you want to get a hold of this then poke your head around the web, its out there.
scooterdog is offline
post #2 of 58 Old 04-01-2009, 02:10 AM
David Scott's Avatar
I found several upmixes for that album. Is it the one that's 2.47gb's?
David Scott is offline
post #3 of 58 Old 04-01-2009, 05:58 PM - Thread Starter
scooterdog's Avatar
Liked: 36
Yep thats the one
post #4 of 58 Old 04-02-2009, 09:24 AM
ca1ore's Avatar
Supertramp is one of those bands I always thought would sound great in hirez 5.1 - great shame there has been no back catalog treatment.
Certainty and conviction are a sure sign you don't know what you're talking about! The world is not black and white, rather shades of grey!
ca1ore is offline
post #5 of 58 Old 04-06-2009, 10:02 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
will someone pm the link PLEASE.
phantom52 is offline
post #6 of 58 Old 04-06-2009, 02:53 PM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
+1 for me. Thx.
audiman is offline
post #7 of 58 Old 04-06-2009, 05:18 PM
The_Nephilim1's Avatar
Quoted: 33 Post(s)
check PMs guys Gals
The_Nephilim1 is offline
post #8 of 58 Old 04-10-2009, 02:31 PM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
Could you PM me too? TIA
BizarroTerl is offline
post #9 of 58 Old 04-11-2009, 09:42 AM
Quoted: 38 Post(s)
Liked: 46
Downloading now. Thanks.
post #10 of 58 Old 04-12-2009, 10:29 AM
jwhitta's Avatar
Could you please pm me the link?
jwhitta is offline
post #11 of 58 Old 04-12-2009, 04:59 PM
curtlots's Avatar
Quoted: 81 Post(s)
Liked: 112
Please, please, me too! I've had this recording on 8-track (really), cassette, Mobile Fidelity Master Recording vinyl and MFMR CD. If it comes out on anything in the future, I'll have that too!
curtlots is offline
post #12 of 58 Old 04-12-2009, 07:52 PM
Quoted: 33 Post(s)
Sent you a PM .. I was curious How does one go about transforming a Stereo mix into a 5.1 mix?? What equipment, Programs would I need I would like to attempt this ??
post #13 of 58 Old 04-13-2009, 05:57 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Have no idea, but would suspect it would be a very expensive venture. Something I have no knowledge of. If it was easy and in-expensive we wouldn't be held captive by the companies on what we as far as SACD's/DVD-A's go.
post #14 of 58 Old 04-13-2009, 06:26 PM
jwhitta's Avatar
Please????
jwhitta is offline
post #15 of 58 Old 04-13-2009, 06:29 PM
lawrence99's Avatar
thanks
Eldon Tyrell:
"The light that burns twice as bright,
burns half as long. And you have burned
so very very brightly, Roy."
lawrence99 is offline
post #16 of 58 Old 04-13-2009, 08:41 PM
elee532's Avatar
Quoted: 78 Post(s)
I would appreciate the link as well. Thanks!!
elee532 is offline
post #17 of 58 Old 04-21-2009, 02:14 AM
andrewh13's Avatar
thanks
andrewh13 is offline
post #18 of 58 Old 04-22-2009, 06:53 AM
curtlots's Avatar
Quoted: 81 Post(s)
Liked: 112
Thanks to The_Nephilim1 for the PM/link. It took nearly two days to download and I attempted to burn to DVD. Record Now opened up and prompted me to rip it to DVD which I did, but it won't play. I also tried dvd decrypter but couldn't get it to work. What are the steps needed to burn this file?
curtlots is offline
post #19 of 58 Old 04-22-2009, 10:39 AM
Quoted: 33 Post(s)
Hi, check you PM
post #20 of 58 Old 04-22-2009, 11:07 AM
force10's Avatar
I burnt it twice, once on DVD+R and DVD+RW and it will not play.
force10 is offline
post #21 of 58 Old 04-22-2009, 12:52 PM
andrewh13's Avatar
thanks
Anyone?
post #22 of 58 Old 04-22-2009, 02:58 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
iso-burner.
post #23 of 58 Old 04-23-2009, 06:53 AM
curtlots's Avatar
Quoted: 81 Post(s)
Liked: 112
iso-burner.
I down loaded iso-burner and iso-burned two more coasters. I get to 90% and it says burn error. Are there specific settings to use? Sorry, but I'm totally new to this kind of thing, I just want to hear Supertramp in 5.1.
curtlots is offline
post #24 of 58 Old 04-23-2009, 07:05 AM
Bill Misencik's Avatar
Thanks for the tip Scooterdog. I remeber when the UHQR vinyl disc came out with this recording from Mobile Fidelity but I was too poor to buy it at the time. The recording does sound good although the volume level of the surrounds is a little high for my preferences. Great effort and much approciated from its creator.
Those having problems should try ImageBurn software. Its free and I've found it to be very reliable for burning discs. Remember to not burn at high speeds and use quality media and I doubt you'll have problems.
Bill Misencik is offline
post #25 of 58 Old 04-23-2009, 07:17 AM
Kfcosby's Avatar
PM link please and a link for the technical article
thank you
Kfcosby is offline
post #26 of 58 Old 04-23-2009, 07:42 AM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
thank you
Can you please PM me to plus the tech notes.
HeffeMusic is offline
post #27 of 58 Old 04-24-2009, 10:09 AM
007james's Avatar
Quoted: 12 Post(s)
I've tried searching for this as well and came up with nothing. I'd appreciate it if someone could PM the link to me as well......
007james is offline
post #28 of 58 Old 04-24-2009, 03:06 PM
elee532's Avatar
Quoted: 78 Post(s)
2nd request. Please and thank you in advance!
elee532 is offline
post #29 of 58 Old 04-25-2009, 11:24 AM - Thread Starter
scooterdog's Avatar
Liked: 36
Your very welcome...Yes the surrounds are a bit hot but that was an easy fit. For those having problems burning it I think someone mentioned IMGBURN, thats what I use and used it on this and it worked with no problems.
Glad I found this little gem for us all to enjoy.
post #30 of 58 Old 04-25-2009, 12:32 PM
curtlots's Avatar
Quoted: 81 Post(s)
Liked: 112
I downloaded IMGBURN and am still getting a burn error. I'm starting to believe I have a bad DVD drive. I'm going to load everything onto a portable hard drive and see if I can burn it at work. Otherwise, if there are any special settings to use beyond the 'stock' settings, please somebody let me (and others) know what they are.
curtlots is offline
Reply Surround Music Formats
