DVD-Audio decoder for foobar2000 - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 413 Old 01-29-2014, 08:12 AM
SeeMoreDigital's Avatar
Quoted: 494 Post(s)
Liked: 208
Originally Posted by originalsnuffy View Post
Hi all,
I have been happily using this plugin with foobar 1.29. The version on my main PC is 0.4.8.
I have a new install of foobar on the downstairs rig running Windows 8.1. I had downloaded the latest version of this dll, whcih is 0.4.11 and nothing seemed to play with Foobar 1.29, 1.31 or 1.3.1.
The new setup will play SACD files using that plug in.
Any suggestions in terms of downgrading Foobar itself or trying the old dll (0.4.8) ?
I admit I am a big confused as to where to go next.
Hi originalsnuffy,
Exactly which Foobar plug-in can play SACD (I presume you mean DSD) streams?
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #392 of 413 Old 01-31-2014, 02:44 PM
scolumbo's Avatar
Liked: 36
Hi all,
I was using Foobar 1.29 with the 0.4.11 DVD-A plugin. Your post prompted me to update Foobar to 1.3.1.
No problems here using that version of Foobar with the DVD-A plugin. SACD plugin (0.6.6) also still works. I'm running it on a Win 7 pc.
scolumbo is offline
post #393 of 413 Old 01-31-2014, 02:45 PM
scolumbo's Avatar
Liked: 36
Originally Posted by SeeMoreDigital View Post
Hi originalsnuffy,
Cheers
http://sourceforge.net/projects/sacddecoder/
scolumbo is offline
post #394 of 413 Old 02-01-2014, 03:47 AM
Quoted: 494 Post(s)
Liked: 208
post #395 of 413 Old 06-06-2015, 10:17 PM
Liked: 0
Unhappy 96kb 4 channel ISO file will not play
I have a number of ISO albums with both 4 and 2 channel tracks inside.
These were 4 channel tapes originally. (Q8)
When starting Foobar 1.37 I get the following.
"Unrecoverable playback error: Unsupported stream format: 96000 Hz / 16-bit / 4 channels"
If I select stereo tracks in the DVD-Audio preferences it says 2 channels but same error.
Properties of a track shows:
Duration : 1:21:54.560 (471 797 760 samples)
Sample rate : 96000 Hz
Channels : 4 ( 2 for the stereo downmix)
Bits per sample : 24
Bitrate : 9216 kbps
Codec : MLP
Encoding : lossless
If, repeat, IF, I remember correctly I could play them in an earlier version of Foobar, but I've gone back as far as 1.31 with no luck.
These files play perfectly in SMPlayer using the built in MPEG PS demuxer and FFmpeg AC-3 codec but I want to convert them to 2 channel FLAC's since I no longer have a 4 channel system. SMPlayer won't do that.
Any help would be appreciated.
The following ISO file plays perfectly in Foobar as do many others.
Duration : 40:39.867 (6 886 279 680 samples)
Sample rate : 2822400 Hz
Channels : 2
Bitrate : 5645 kbps
Codec : DSD64
Encoding : lossless
Name:	Sm info 1.jpg
Down_South is offline
post #396 of 413 Old 06-06-2015, 10:57 PM
Liked: 0
Bitrate : 9216 kbps
Codec : MLP
Encoding : lossless
Channels : 2
Bitrate : 5645 kbps
Codec : DSD64
Encoding : lossless
Cancel above post. 1.31 portable worked.
post #397 of 413 Old 06-07-2015, 06:58 AM
Michael Sargent's Avatar
Quoted: 199 Post(s)
Liked: 175
This is an excellent example of why I rip everything to FLAC files. That includes CD's, dts-CD's, DVD Audio's, music DVD's and music Blu-Ray's. Now everything is on one disk (plus backups) in one format (FLAC). I can either play everything, or nothing. I don't have to worry about keeping old hardware running or finding the correct versions of software to play old media.
I rip CD's with dBpoweramp CD Ripper and most DVD and Blu-Rays with DVD Audio Extractor. Blu-Rays with dts-HD MA tracks take a little bit more effort (MakeMKV with a dts-HD decoder, then some post-processing).
Most are stereo, but about 5% are multichannel. Here are some stats:
Sample rate : 44100 Hz (89.4%); 48000 Hz (5.4%); 96000 Hz (4.2%); 192000 Hz (0.6%); 88200 Hz (0.5%)
Channels : 2 (94.2%); 6 (4.6%); 1 (1.0%); 4 (0.1%); 5 (0.1%)
Bits per sample : 16 (91.5%); 24 (8.5%)
Duration : 27wk 6d 2:45:02.278
Total size : 1.88 TB (2 071 459 876 657 bytes)
All the old physical media is still around, should I even need to re-rip it, but hopefully I never will. Even if FLAC goes out of favour, I simply need to transcode everything from one format to the new format. It'll take a while, but it's a fairly simple thing to do.
Mike
Michael Sargent is offline
post #398 of 413 Old 06-07-2015, 02:24 PM
captainbrent's Avatar
Quoted: 347 Post(s)
Liked: 399
I've heard that this can be done. Would you mind elaborating on this process, please? Thanks in advance!
Cheers
captainbrent is offline
post #399 of 413 Old 06-08-2015, 05:48 AM
Quoted: 199 Post(s)
Liked: 175
The trick is to find a copy of an old release of ArcSoft TotalMedia Theatre 6, which still has the dts decoder DLL. I found (somewhere) and eval copy and installed it, but I doubt I ever ran it. I just grabbed the DLL, copied it away for safe keeping and pointed MakeMKV at it. Then I could tell MakeMKV to rip a dts-HD MA disc and convert from dts-HD MA to FLAC. The result is a .mkv file with FLAC audio imbedded. Then I use mkvextract to get the chapter breaks and use mkvmerge to split the large .mkv file into separate track. Then I convert each track using eac3to to convert from .mkv to .flac files. Then add the correct metadata and you are done.
Mike
post #400 of 413 Old 06-08-2015, 07:42 AM
Quoted: 494 Post(s)
Liked: 208
Cheers
Once you've extracted the A/V streams from the Blu-ray Audio (HFPA) disc, I use an application called UsEac3To (v1.1.7) with eac3to (v3.29) to encode the DTS-HD MA stream to Flac: -
EDIT: I forgot to mention that the newest version of eac3to v3.29 contains the newest version of 'DCAdec', which is now able to decode DTS-HD MA audio streams, without the need to install/register Arcsoft's (dtsdecoderdll.dll) decoder filter
Cheers
post #401 of 413 Old 06-08-2015, 10:10 AM
Quoted: 347 Post(s)
Liked: 399
^^^^ Gentlemen, thank you for that information, it is informative and appreciated. I wish that DVD Audio Extractor would extract the loss-less stream though!
Cheers
post #402 of 413 Old 06-08-2015, 10:23 AM
Quoted: 494 Post(s)
Liked: 208
Cheers
Actually, DVD Audio Extractor v7.2.0 can. If you have a Blu-ray disc decoding application, such as: DVDFab Passkey installed/running
post #403 of 413 Old 06-08-2015, 10:49 AM
Quoted: 347 Post(s)
Liked: 399
Oh really...very good news...thank you!
Also, I was looking around the MakeMKV site and saw this update which indicates that they will have their own decoder soon.
http://www.makemkv.com/dtshd/
Cheers
post #404 of 413 Old 06-08-2015, 11:35 AM
Quoted: 494 Post(s)
Liked: 208
Indeed, no doubt they'll be using a build of 'DCAdec'
post #405 of 413 Old 06-11-2015, 07:44 PM
Sherbona's Avatar
Be careful with using it for extracting DTS-MA, unless they have changed their DTS decoder you are actually only getting lossy instead of full lossless. See details here: Blu Ray audio extractor
Sherbona is offline
post #406 of 413 Old 06-11-2015, 07:54 PM
Quoted: 199 Post(s)
Liked: 175
I have asked their support folks about dts-HD MA support a couple of times. The answer is always: No.
Maybe if a few more people, customers preferably, were to ask...
Mike
post #407 of 413 Old 06-12-2015, 01:47 AM
Quoted: 494 Post(s)
Liked: 208
Mike
Thankfully, now that DCAdec has been created. It shouldn't be long before all our applications of choice move over from Arcsoft's (no defunct) decoder filter
post #408 of 413 Old 06-12-2015, 06:34 AM
Quoted: 199 Post(s)
Liked: 175
I pointed that page out to the DVD Audio Extractor folks, and they said "Thanks".
No idea if they'll actually do something about it.
Mike
post #409 of 413 Old 09-09-2015, 06:10 PM
ThurstonX's Avatar
which track goes with which... track?
Greetings all.
I recently discovered the glory of the foobar2000 DVD-A component, not coincidentally as I was discovering the glory of King Crimson. I've now got all but two of the 40th Anniversary Series CD+DVD-A releases. I have no problem playing or converting to FLAC the stereo versions of the DVD-A MLP tracks, but several of the albums have both the Steve Wilson remixes and the earlier 30th anniversary remasters in 24/96 MLP.
The problem is determining which tracks, as presented by loading the IFO file in foobar, are which. I've had an email exchange with Neil Wilkes, who works for Opus Productions, and authored most of the DVDs in the 40th Anniversary Series (In The Court Of The Crimson King being one exception, though he is credited on that release). He claims that it's not possible to tell how the foobar component displays the contents in relation to how the DVD was authored. Thus, he would not give a definitive answer. As he's the author, I can only take him at his word.
Without getting into too much detail about the back-and-forth, these are the two relevant replies from Neil re: Starless And Bible Black:
"The 2 40th anniversary streams (stereo & surround) are in the same VOB in the Video_TS and the same AOB in the Audio_TS."
and later...
"Sticking strictly to the Audio_TS, it was set up like this:
Group 1 = 40th Anniversary Steven Wilson remixes.
Content set as both surround & stereo in the same group - this is known as "PGC Blovk" [sic: presumably he meant "PGC Block"] authoring, and is done to make the disc work 100% by simply loading the disc, waiting for the main menu to load & hitting PLAY or ENTER to get straight to the new content in the stream setup your player is configured for - The 5.1 is stream 1 and the 2.0 is stream 2 ( or stream 0 & stream 1, depending on how the player displays the information)
Group 2 is the 30th anniversary stereo mix at 24/96 in MLP Lossless
All other content is in Video_TS only."
That's all well and good, but doesn't help those of us without DVD-Audio players. Perhaps the component creator or someone more knowledgeable than I can weigh in.
At this point I'm reduced to listening to the two versions of a given song, trying to find differences in the mixes, and then comparing that section to either the 30th or 40th anniversary CD versions. That's the theory, at least. As you might imagine, that's a tedious task, and not one I've yet had the time to tackle.
As I'm still researching this, perhaps there is some freeware DVD-A ripping app I've not come across that can deal with the .AOB files directly. I'm going to assume Neil's explanation of the remixes being loaded first applies to all the DVDs. I don't like assumptions, though.
ThurstonX is offline
post #410 of 413 Old 09-09-2015, 07:47 PM
rdgrimes's Avatar
Quoted: 2446 Post(s)
Liked: 1762
I've never messed with Foobar for this. DVDAExplorer (freeware) will display all the files with appropriate labels so you know exactly what you're ripping. In truth there is no real standard for authoring DVD-A and a lot of variations are seen. But I never had DVDAExplorer fail to correctly rip one.
rdgrimes is online now
post #411 of 413 Old 09-09-2015, 07:55 PM
ThurstonX's Avatar
Thanks for the quick reply. I just finished skimming through the thread, and have a tab open for DVDAExplorer. I'll give it a shot tomorrow. I've ripped all the DVD-As I have perfectly with foobar and the component, but track names in the detail pane of foobar are entirely generic. So if there are two versions of the same album as 24/96 MLP files, only the track numbers and times vary (generally by a few seconds, nothing more). So while I can rip them to FLAC and play them... which is which?
Maybe I'll give DVDAExplorer a quick run-through now...
if the latest is from 2008, it's pretty old. Doesn't mean it won't work, of course. Anyway, comparing the track layout to what the foobar component displays, it's the same. Being used to foobar, I'll stick with that.
One thing I learned re: In The Court Of The Crimson King DVD-A is that the printing on the outside box definitely corresponds to the DVD-A track order as displayed by these two methods. That's important, because the order in the booklet is not the same, and is definitely not right for this album.
As to the other DVD-As... the box vs. booklet listings for them is also different, and in the same way. Artists... pih! ....
post #412 of 413 Old 09-10-2015, 08:12 PM
rdgrimes's Avatar
Liked: 1762
Yes well DVD-A is a pretty old format - and a dead one.
The sad truth is that there never was any real standardization to the way they were authored, and some formats that were not really DVD-A got called DVD-A.
post #413 of 413 Old 09-11-2015, 07:03 AM
ThurstonX's Avatar
True enough. By the time I got around to hi-res releases, most I wanted were available for download. That said, I'm not complaining that Fripp decided to release the 40th Anniversary Series in DVD-A. foobar, DVDAExplorer, et al., certainly make it easy for those of us without a standalone player, and who prefer PCs as sources for music. I don't know how much more hi-res I'll buy in the future, but I hope some are released in DVD-A (or downloadable FLACs) vs. SACD or whatever format represents unobtanium for me.
re: how to determine which KC 24/96 MLPs are which (40th Anniversary vs. 30th), only three of the six albums I own (still waiting on their second album to get back in stock at Amazon) required a listening comparison. The other three were distinguishable via differences in 40th vs. 30th (edited versions, bonus tracks, etc.). The listening tests were surprisingly easy. I picked relatively quiet songs and used rips of the included 40th Ann. remix CDs as the baselines. Two were apparent within the first five seconds, while one took about five minutes of effort to discern a difference.
Reply Surround Music Formats
