SPDIF on laptop - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-22-2010, 05:04 PM - Thread Starter
elvemr7's Avatar
I have a conexant 20561 smart audio hd on my laptop and for some reason it is not working. ive checked the other threads and i couldn't find any that related to my exact sound card. now i have a toslink to spdif cable and when i plug it into the headphone jack it won't work: control panel - hardware and sound - sound - right click on "SPDIF" - then "test." the toslink-spdif cable won't even show a red light at the other end when i do this. i have vista professional (32) and the computer is from school. is this there anyway i can fix this issue?
ive tried ac3 filter and ffdshow audio decoder.
help.
elvemr7 is offline
post #2 of 5 Old 06-23-2010, 05:04 AM
Steve Dodds's Avatar
help.
If you Google your soundcard you will find a bunch of threads requesting drivers. Could be that.
Otherwise I'd look at the cable.
I am of course assuming your laptop can output optical digital from the headphone output.
Steve Dodds is offline
post #3 of 5 Old 06-23-2010, 12:48 PM - Thread Starter
elvemr7's Avatar
i've tried the cable with an audigy 2 ZS sound blaster card (PCMCIA) and the cord works. i forgot to mention that i've reinstalled the driver, which made my internal laptop speakers not work, so i had to roll the old driver back. the conexant driver is listed as an SPDIF "interface" (when i go into the control panel - hardware and sounds etc.) and the audigy card is listed as an SPDIF "out", what's the difference? the audigy card works well, but it would be nice to just use my internal sound card for an spdif pass through.
elvemr7 is offline
post #4 of 5 Old 06-23-2010, 07:04 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
First try to find if your laptop actually has SPDIF. Driver is generic for a series of cards, but not all of them have SPDIF implemented.
ap1 is offline
post #5 of 5 Old 06-23-2010, 08:19 PM - Thread Starter
elvemr7's Avatar
yes, i looked up my specific sound card, i have a lenovo t400, and apparently the conexant 20651 doesn't have an spdif out. my apologies for starting this thread.
elvemr7 is offline
Reply Surround Music Formats
