Playing via HDMI off PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-19-2010, 12:37 PM - Thread Starter
DistantQuasar's Avatar
Hi everyone,
I have been trying my hardest to get my audiophile surround files playing through to my new receiver. I have an HDMI cable coming from my ATI HD4870 graphics card, which supports up to 8 channel 24 bit 192kHz. I have been able to play DTS/DD DVD formats via Windows Media Player and DTS wav files via foobar2000 when I set for WASAPI and 16 bit (both work in multi-channel).
I want to especially play my MLP DVD-Audio files of 24bit 92kHz 5.1 sound, but so far have only achieved stereo via Winamp, VLC player, foobar2000, or WMP. When I try in foobar2k it says "stereo downmix", and when I check the settings for my HDMI in winamp->options->preferences->output->directsound output->speaker setup: stereo (unchangable). I would also like to play some of these that I have dl'ed as FLACs (I don't like converting audio due to inevitable loss of data on some level), and so far have not been able to play multi-channel in Winamp, WMP, VLC, foobar2000, XBMC - only outputs as stereo to my amp. I also have some AVCHD discs in multi-channel that I can play via TotalMedia Theatre 3 and get there quite well.
I have had great success with playing these through my analog 3.5mm jacks to my quad+sub sound system on my PC. I think the greatest setback is that I haven't figured out how to get my system giving multi-channel LPCM to my receiver - the only formats that have been getting there in multi-channel are either DTS or DD. If I hadn't already scoured the internet, I wouldn't be here. Thanks
DistantQuasar is offline
post #2 of 12 Old 09-19-2010, 02:25 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Have you configured the HDMI device as a 5.1 or 7.1 configuration in the Windows speaker setup through the sound option under control panel (hint: click on the "configure" button once you get to the sound panel)?
MSmith83 is offline
post #3 of 12 Old 09-19-2010, 02:34 PM
Steve Goff's Avatar
Quoted: 337 Post(s)
Liked: 159
I can play multichannel flac via hdmi using J. River Media Center 15 or the Dharma xbmc build by setting audio output to WASAPI. Make sure you get the latest hdmi audio driver for your video card and use WASAPI or ASIO out.
You can rip your DVD audio discs to multichannel flac using DVD Extractor. Flac is lossless, and you lose nothing in the conversion from MLP.
Steve Goff
Steve Goff is offline
post #4 of 12 Old 09-19-2010, 02:35 PM - Thread Starter
I'm in Windows 7 pro x64 if that makes any difference. I can't change much under my config for the HDMI except under "Advanced"->Default format (currently I have it set to "24 bit, 192000Hz (Studio Quality)). It shows the possible configurations under "Supported Formats"-> "Max Number of Channels: 8/HDCP: Supported/Bit Depths: 16-bit, 24-bit/Sample Rates:32.0kHz...192.0kHz/Encoded FormatsTS Audio, Dolby Digital Plus, DTS-HD, Dolby TrueHD, Dolby Digital".
I was just checking my receiver specs. and it can take Multi-ch Linear PCM 8ch 32-192kHz, 16/20/24bit, Bitstream DD, DTS, Dolby TruewHD, DD Plus, DTS-HD Master Audio, DTS-HD High Res. Audio, DTS Express.
post #5 of 12 Old 09-19-2010, 02:39 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
I also use HDMI for high-resolution multichannel PCM output from my PC. My comment was to make sure he has the basics right. I have seen a few people on AVS fail to properly configure their HDMI device in the speaker configuration option, thus causing the same issue mentioned here.
MSmith83 is offline
post #6 of 12 Old 09-19-2010, 02:39 PM
Steve Goff's Avatar
Quoted: 337 Post(s)
Liked: 159
O edited my post above while you were responding. I don't think you'll get MLP playback, but flac should work fine. Try the dharma beta of xbmc to get WASAPI output.
Steve Goff
post #7 of 12 Old 09-19-2010, 02:46 PM - Thread Starter
I haven't tried the Dharma build, so I'll go ahead and install that - get back to you in a few mins. Thanks
post #8 of 12 Old 09-19-2010, 02:50 PM - Thread Starter
OMG!!!! My bad, I was double clicking my HDMI output and I thought that automatically went into config. When I hit config I changed the setup to 5.1 from stereo. LOL thanks for the replies guys. I'll see if I can send the audio now.
post #9 of 12 Old 09-19-2010, 02:53 PM - Thread Starter
Thanks a bunch. Sending MLP 24 bit 96kHz 5.1 of the Beatles' Love. Sounds great. I assume all my other stuff will work as well, now. Funny when you think you've tried everything you miss one button or one option, then when someone points it out you feel so stupid for having gone through so much. Thanks again!
post #10 of 12 Old 04-06-2013, 03:58 PM
PrutikJr's Avatar
Can someone recommend what setting audio output should be set to ? Like distantquasar my Alienware x51 can do 16 or 24 bit and all the way up to 192 kHz via my Onkyo 708 receiver. Question is what will work the best?
PrutikJr is offline
post #11 of 12 Old 04-09-2013, 01:10 PM
Selden Ball's Avatar
Quoted: 3371 Post(s)
Liked: 1659
Some receivers can't apply Audyssey if high bitrate audio (>96KHz) is sent. Check the receiver's manual to be sure. If you've run the Audyssey calibration, the sound is going to be better when Audyssey room correction is being applied.
PrutikJr likes this.
Selden
Selden Ball is offline
post #12 of 12 Old 04-09-2013, 02:34 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Unless your computer is upsampling the original signal before sending it to your receiver, I don't think it would be wrong to set it to 192/24. I recommend using WASAPI to get as close to bitperfect audio as possible.
audit13 is offline
Reply Surround Music Formats
