Dolby Pro Logic IIx explained? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 72 Old 01-15-2012, 02:27 PM
Slickman's Avatar
Quoted: 153 Post(s)
Liked: 98
To me Pro Logic iiX Music mode sounds better for converting 5.1 sources to 7.1. To me the surrounds sound louder with music mode, which I like. I'm watching football now and it really feels like I'm in the crowd.
Slickman is offline
post #32 of 72 Old 04-25-2012, 07:10 PM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
Can someone explain what happened with my setup? I use a phantom center. (Anthem AVM50v). When I use the LPCM setting on my Oppo BDP83, and engage Prologic IIX, ALL center channel information disappears. I have to use bitstream to get it back. Also, if I remember correctly, only Dolby True HD has this problem; DTS Master Audio doesn't. Why is that?
RobertR is offline
post #33 of 72 Old 04-26-2012, 01:22 AM
Roger Dressler's Avatar
Quoted: 1851 Post(s)
Liked: 983
If the problem is a bug in the AVM50v, which is where it must be if the center channel disappears in phantom mode but not when the C speaker is activated, then it cannot be different based on the source codec.
If you are using the PLIIx Movie mode, try the Music mode, then adjust the Center Width control to max width (phantom C). Does that restore the center info? If so, it is a bug in the AVM.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #34 of 72 Old 04-26-2012, 05:26 AM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
Thanks Roger. I'll try Music Mode. And you're right. I remember now that I had the same problem with Citizen Kane in DTS-MA mono.
RobertR is offline
post #35 of 72 Old 04-28-2012, 07:35 PM
chikoo's Avatar
I have been using Dolby Pro Logic IIx on my HK AVR 2600 for some time now, and it appears to my ears that the HK Logic 7 Movie format is more pleasing to my ears when I am watching TV programming. So what is the difference between the two?
chikoo is offline
post #36 of 72 Old 04-28-2012, 08:52 PM
Liked: 983
Is your TV programming mainly 5.1 or 2.0?
post #37 of 72 Old 04-29-2012, 08:28 AM
chikoo's Avatar
The tv programming input is pcm 48khz 2 channel.
chikoo is offline
post #38 of 72 Old 04-29-2012, 11:47 AM
Liked: 983
In that case, it is a well worn path. Have a look at this thread, which gives both operational insights and personal opinions. A search will turn up more such discussions.
post #39 of 72 Old 04-29-2012, 01:58 PM
chikoo's Avatar
Thanks Roger. That link was very helpful.
chikoo is offline
post #40 of 72 Old 08-20-2012, 08:15 AM
carp's Avatar
Quoted: 2821 Post(s)
Liked: 2129
Sorry to bring up an old thread, but I want to make sure I understand something.
I just went from 5.1 to 7.1 and was wondering what is the difference between DD ex and pro logic IIx movie mode when watching a 5.1 source?
thanks
carp is offline
post #41 of 72 Old 08-20-2012, 08:42 AM
rdgrimes's Avatar
Quoted: 2440 Post(s)
Liked: 1755
thanks
EX is a 6.1 format. PLIIx is 7.1. They also have differences in how they matrix the rear channel(s). An EX-encoded 5.1 track is specifically designed for EX decoders to do their stuff, but the decoder can extract the rear channel from any 5.1 source that has sufficient stereo audio in the surrounds. PLIIx is just a decoder that is intended to be used on any 5.1 source.
rdgrimes is online now
post #42 of 72 Old 08-20-2012, 10:19 AM
carp's Avatar
Liked: 2129
Ok, thanks for the quick reply. So, in other words, if I'm watching a Blu-Ray that has 5.1 I would be better off setting the receiver to Pro-logic IIx movie mode than using DD EX? The reason being that in Pro-logicIIx the surround rears have 2 different signals while DD EX the surround rears just have the same signal?
I'm so used to wanting the receiver to say "Dolby Digital" so that I know I'm getting 5.1 sound, so I assumed that DD EX would be better but from you answer I was wrong.... right??
thanks rdgrimes
carp is offline
post #43 of 72 Old 08-20-2012, 10:37 AM
rdgrimes's Avatar
Liked: 1755
Depends on your AVR. Most will sent a mono signal to both rears for 6.1 audio. Some do not.
PLIIx is your go-to decoder for 5.1 sources. I leave it on all the time here.
post #44 of 72 Old 08-20-2012, 10:44 AM
carp's Avatar
Liked: 2129
Cool, I'll give it a try. I never used pro logic II when I had just 5 speakers for anything but 2 channel sources so this will be new to me. thanks
carp is offline
post #45 of 72 Old 08-20-2012, 11:32 PM
sdurani's Avatar
Quoted: 5072 Post(s)
Liked: 3546
Careful not to confuse the compression codec with surround processing. Dolby Digital and DTS are lossy compression codecs (like MP3), and don't necessarily have to be 5.1 channels (I have plenty of DVDs that have 2-channel Dolby Digital tracks). Blu-rays can also contain Dolby TrueHD and DTS-HD Master Audio tracks, both of which are lossless packing algorithms (like zipping a computer file). Again, these can be any number of channels.
By comparison, EX and PLIIx are surround decoding/processing. They're designed to scale the number of channels in the soundtrack to the number of speakers in your set-up (just like a video processor scales the number of pixels in a standard def DVD to the number of pixels in your hi-def display). PLIIx is format agnostic, so it can be applied to any of the lossy or lossless codecs.
PLII can only be used for set-ups of 5 speakers or less. As such, it can only be applied to 2-channel sources. You can't apply PLII to 5.1 sources because...well, what would it do: convert 5.1 to 5.1? It's only when you go beyond 5.1 speakers that your receiver will allow you to use PLIIx (for 6 or 7 speakers).
Sanjay
sdurani is offline
post #46 of 72 Old 08-21-2012, 10:46 AM
carp's Avatar
Liked: 2129
Ok, now I'm back to my original thinking. So you are saying that if I am watching a source that is 5.1 (most blu-ray's, some cable content) I should NOT use PLIIx? My options in those instances are:
1. Dolby Digital 5.1 - I don't want to use this because I want to use my 2 surround rear speakers.
2. DD EX - I was inclined to use this at first because my 2 rear channel surrounds will be playing, but they will be playing the same thing if I understand correctly.
3. PLIIx - I am still confused if I should use this or not. I know it uses the 2 rear surround channels but are the rest of the channels discrete? It looks like in you reply above that is not the case.
Remember, I have a 7.1 speaker setup now.
carp is offline
post #47 of 72 Old 08-21-2012, 11:19 AM
rdgrimes's Avatar
Liked: 1755
do not confuse PLII with PLIIx.
PLIIx is intended for use on ANY audio, stereo or 5.1 and always generates 7.1 audio.
post #48 of 72 Old 08-21-2012, 12:05 PM
sdurani's Avatar
Liked: 3546
Where did I say that? I simply explained that PLII can only be applied to 2-channel sources, not 5.1 sources. This was in reply to you saying that you had only tried PLII with 2-channel sources on your 5.1 set-up. My point was that you didn't have a choice: with 5 speakers you can only use PLII (PLIIx will be grayed out by your receiver), and only apply it 2-channel sources.
If you have a 5.1 source AND more than 5 speakers (6 or 7), you can use PLIIx to scale the number of channels in the source to the number of speakers in your set-up. For the record, I would recommend leaving PLIIx on for all sources, 2-channel and 5.1-channel.
When PLIIx is applied to a 5.1 source, only the front channels remain discrete. 3 channels, 3 speakers, nothing to process. Each channel is routed to its respective speaker.
The processing happens in the surround field, where the contents of the 2 surround channels are steered over your 4 surround speakers. Sounds that are mixed to both the left AND right surround channels, and would normally phantom image behind you, are extracted and sent to the speakers behind you. Sounds that mixed mostly in either the left OR right surround channel are kept at your left or right side. This is how you get rear-vs-side separation in the surround field. Since each surround channel is separated into two parts, side and rear, they are no longer discrete (i.e., no longer exactly what was on the disc).
Sanjay
sdurani is offline
post #49 of 72 Old 08-21-2012, 02:45 PM
carp's Avatar
Liked: 2129
Ahhhhhhh *lightbulb goes on*
Ok, I got it now. Sorry, I'm a bit slow sometimes. Thanks for the detailed response sdurani and rdgrimes, I appreciate it. I feel a little out of my element wandering out of the subwoofer forum but I'm glad I did. smile.gif
BTW, I cannot stop listening to music in PLIIx music for 2 channel music. When I had 5 speakers I preferred dts neo 6, but with 7 speakers I am absolutely loving PLIIx. I adjusted the center width a bit, and it's heaven.
carp is offline
post #50 of 72 Old 10-11-2012, 02:33 PM
jcarcher's Avatar
This has been very helpful to me trying to figure out whether to use PLIIX or Neo:6 for 5.1 sources. Just to add another question / complication though: if you've set up Audyssey room correction on your receiver / processor, how does it work when adding PLIIX to a DTS-HD MA or DD-TrueHD 5.1 source? Though the Audyssey set up takes all 7 speakers into account in it's room correction calculation, how if at all is it implemented when PLIIX is added to a DTS-HD MA + PLIIX 5.1 sources? Is the Audyssey equalization still applied?
jcarcher is offline
post #51 of 72 Old 10-12-2012, 09:28 AM
Liked: 983
There is no relation between what happens upstream (audio decoding, surround processing) and downstream (room EQ). The room EQ works the same regardless.
post #52 of 72 Old 10-12-2012, 09:42 AM
Kevin C Brown's Avatar
Quoted: 12 Post(s)
Liked: 27
DPL IIx Music and center width control: this is only active for 2.0 sources? I have a Marantz AV7005. and that setting disappears for 5.1 sources. I have a buddy with a Denon AVR, and the same thing happens. No center width control for 5.1 sources.
The reason I ask, is that if I have a 4.0 or 4.1 source, no center channel, I'd like to mix some of that L & R into the center, but it doesn't seem possible.
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #53 of 72 Old 10-12-2012, 10:20 AM
Quoted: 12 Post(s)
Liked: 27
Originally Posted by Roger Dressler View Post
Maybe I can clear up the PLIIx modes, since I created them. Core operation of Movie and Music modes is identical. The Ls/Rs of the 5.1 source are processed into 4 new surround outputs. The only difference is that the Music mode offers a kind of "Center Width" control, so that when Ls and Rs carry the same (mono) signals, the decoder can map that signal across all 4 outputs rather than steering only to the rear speakers. This is very useful for movies with mono surrounds (i.e., Out of Africa), or just highly correlated surrounds, and of course for music mixes where hard steering can detract from the spaciousness of the mix.
If you are familiar with regular PLII when decoding 2-ch sources, the Center Width control allows the decoded center signal to be output from only the center speaker (CW=min) or only from L/R (CW=max) or several steps in between using all three speakers. PLIIx is using that same kind of control for the Music mode, but it is just internally preset somewhere in the middle.
Maybe my understanding has been wrong. For both DPL IIx Music and Movie, the center and L & R are untouched?
The "center" width control is only controlling what's happening in the 4 surrounds?
Seems like "center" is the wrong word then for DPL IIx ... ?? Should be "rear matrix depth" or something ...
post #54 of 72 Old 10-12-2012, 02:04 PM
Quoted: 12 Post(s)
Liked: 27
Chattin' with a bud offline.
Maybe this is the case? For 5.1 content, DPL IIx (Music or Movie) doesn't mess with the L/C/R content, but for Music, the "center width" like control between the sides and surrounds is "internally preset somewhere in the middle". So no setting we have access to.
The actual "center width" parameter for DPL IIx is only active for 2 ch sources, like for DPL II, but does the same thing between the C and L/R channels.
post #55 of 72 Old 10-13-2012, 01:08 AM
Liked: 983
Correct.
Not possible.
Correct.
The actual "center width" parameter for DPL IIx is only active for 2 ch sources, like for DPL II, but does the same thing between the C and L/R channels.??
Correct.
post #56 of 72 Old 10-13-2012, 12:03 PM
Quoted: 12 Post(s)
Liked: 27
post #57 of 72 Old 07-21-2015, 04:41 AM
John Stockton's Avatar
Quoted: 18 Post(s)
Quote:Originally Posted by tony123
You can use Movie or Music mode for any genre of content, in either 2 or 5.1-channels. Most newer movies work best with Movie mode. But there are examples of movies in 2.0 or 5.1 that work better with Music mode. These tend to be cases where the stereo is essentially mono, or the surrounds are either mono or highly correlated, and in a 7.1 system that would cause all the surround audio to come from the rear speakers only. It is usually nicer to have all 4 surrounds involved, and 5.1 Music mode does that..
Sorry for resurrecting an old thread. Correct me if I am wrong, so:
--All modern 5.1 films with Stereo surrounds like Skyfall, should be played back in PLIIX Movie
--Older 5.1 films that originally had mono surrounds in the theatre like Cocoon, should be played back in PLIIX Music
-- All stereo 2.0 films should be played back in PLIIX Music, since they all have mono surrounds.
John Stockton is offline
post #58 of 72 Old 07-21-2015, 09:16 AM
Liked: 983
Re: 7.1 playback systems:
Yes.
Wouldn't hurt.
2.0 mixes might be derived from any kind of original content, even 7.1 or Atmos. The choice of how to process it at home with PLIIx comes down to what sort of effect you like to hear for any given soundtrack. I just leave it in Movie mode until something draws my attention as being wrong. Pretty seldom.
post #59 of 72 Old 07-22-2015, 05:38 AM
Quoted: 18 Post(s)
Re: 7.1 playback systems: Ye
And what thing(s) would you consider as being, wrong ??
Also can you please name me some 2.0 mixes where you preferred the Music mode over Movie ??
post #60 of 72 Old 07-27-2015, 05:39 AM
ChromeJob's Avatar
Quoted: 1190 Post(s)
Liked: 622
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
I wasn't aware that Music versus Movie effected the surround channels at all. In my understanding Music shares the Center content with Left and Right to "widen" the soundstage.
My AVR doesn't play 5.1 discrete content through PL II at all. Why would it? Only if it's 2.0 channels encoded in DD or DTS .
If it's a mono movie encoded in 2.0 (thank you ), I'll use Music so I have a wider center. I hate when they're locked into the center as I don't have a full range tower for my center speaker.
“Phil? Phil Connors?!”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is offline
Reply Surround Music Formats
