How to put Hi-Rez 24/96 tracks in proper track order - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-03-2012, 08:12 AM - Thread Starter
ThePrisoner's Avatar
Quoted: 286 Post(s)
Liked: 202
I just downloaded The Doors from HD Tracks yesterday. Format is 24/96 FLAC. When I copy these to my USB thumb drive I have tracks 10 & 11 right after track 1. The rest are in order. How can I sort them in the proper order?
Dolby Atmos/DTS:X 5.2.4
Samsung 65JS8500 (calibrated by Gregg Loewen); Marantz SR6010 + Onkyo M-5010; Oppo UDP-203; Apple TV (4th Gen); PS4; Definitive Technology BP-8060ST, CS-8060HD, SR-8040BP, ProMonitor 800; SVS PC12-NSD (2)
ThePrisoner is online now
post #2 of 10 Old 03-03-2012, 08:21 AM
rdgrimes's Avatar
Quoted: 2480 Post(s)
Liked: 1785
This is a function of the device you are using, or of a DNLA server software.
With that type of sorting, you'll need to re-name the files to "001", "002", etc.
rdgrimes is offline
post #3 of 10 Old 03-03-2012, 08:35 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 202
Thank you. I'm using PS3 Media server with my Oppo BDP-93 and I'll also use a USB drive. How exactly do I go about re-naming the files. Do I re-name in the HD Tracks music folder?
Thanks again!
EDIT: I renamed 001, 002, etc. Did not work, it still did:
001-Break On Through
0010-Take It As It Comes
0011-The End
002-Soul Kitchen
the rest are fine
post #4 of 10 Old 03-03-2012, 09:53 AM
rdgrimes's Avatar
Liked: 1785
That's going to be a "feature" of the server software, and it's probably using something other than the file names for sorting. (tags, etc). After re-naming them be sure to re-scan the server library. From a USB drive, the player should list them correctly.
You could try opening the files in Foobar or some other tool for naming and tagging and see how they look.
rdgrimes is offline
post #5 of 10 Old 03-03-2012, 10:06 AM - Thread Starter
Quoted: 286 Post(s)
Liked: 202
You know whats funny, they are not listed right even from my USB drive which has me perplexed.
Forgot to mention I'm on a Mac
post #6 of 10 Old 03-03-2012, 10:41 AM
rdgrimes's Avatar
Liked: 1785
All I can tell you is that tracks with similar names are listed correctly here with the BDP-93. They have names: "01 track01", "02 Track02", etc.
0011-The End
002-Soul Kitchen
Just noticed, that should be 001, 002, 010, 011. Not 0010, 0011.
rdgrimes is offline
post #7 of 10 Old 03-03-2012, 10:58 AM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 136
Actually, it should be:
01 Name of first track
02 Name of second track
10 Name of tenth track
11 name of eleventh track
The sorting algorithm will "see" the 0 column digit first (the one in base ten that would be for 10s), then look at the 1 column digit, for two digits (there is no reason at all to make them three digit numbers unless you have over 100 tracks per album; why make it harder than it needs to be? Every digit you add just increases the chances for user input error, like we see by the OP here).
Will2007 is offline
post #8 of 10 Old 03-03-2012, 12:11 PM - Thread Starter
Quoted: 286 Post(s)
Liked: 202
Eliminating the extra "0" before tracks 10 & 11 did the trick. Everything is in order. I'll have to remember this step for other downloads.
Thank you.
post #9 of 10 Old 04-01-2012, 12:04 AM
blaven2's Avatar
will2007 hit the nail on the head
01
02
03
04
...etc
10
11
12
etc
blaven2 is offline
post #10 of 10 Old 07-29-2012, 11:07 AM
Philnick's Avatar
Quoted: 256 Post(s)
Liked: 115
The reason this happens is that the file system is not interpreting those as numbers but as words, and is alphabetizing them. It doesn't know how to sort by numbers at all.
Alphabetically, "10" through "19" come before "2". That's why you should make sure that all the track numbers are the same number of letters long (it doesn't think of them as "digits") by using leading zeros.
0 comes before 1 in the alphabet, so "02" would come before "10" - solving the problem.
Philnick is offline
Reply Surround Music Formats
