Question about DTS HD Master audio - AVS Forum | Home Theater Discussions And Reviews
Old 04-19-2012, 09:51 AM - Thread Starter
HighlandLassie's Avatar
I recently purchased an Onkyo TX-SR876 reciever that supports both of the HD audio formats.
When I play a Blu-ray,(Sony BDP-S580) that features one of these HD audio sources, the Onkyo does not display that it is receiving the specified HD source.
Am I getting the benefits of HD audio, and just need to pick whichever listening mode I prefer?
Or am I missing something?
Thanks for answering a newbie question.
HighlandLassie is offline
Old 04-19-2012, 10:42 AM
Ysay's Avatar
How is your Sony player set up? It might be outputing PCM instead of Bitstream.
Ysay is offline
Old 04-19-2012, 11:08 AM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
Or it could be outputting a lossy core audio, again depending on setup.
rdgrimes is offline
Old 04-19-2012, 11:45 AM - Thread Starter
I went into the BD setup, and did not see an option for bitstream,(that is what I was looking for) everything is set to "auto" from what I can see, I will need to go back in and check, what and where am I looking to make a change, exactly?
The sound is real good, but I was expecting to see something like "DTS-HD Master audio" displayed on the Onkyo if that is what is being input to it, as it is capable, and so should the Blu-ray player as it is less than a year old, and a decent unit.
Maybe I am wrong?
Old 04-19-2012, 11:50 AM
unavol's Avatar
Quoted: 43 Post(s)
Liked: 48
Are you using an HDMI cable to connect your BDP to your AVR? If so, check your audio settings on the Sony. Make sure you do not select the PCM options. The AVR should read DTS MA (or similar) when you have the settings right.
unavol
There's nothing to see here.
unavol is offline
Old 04-19-2012, 12:04 PM - Thread Starter
Yes, HDMI.
There seems to be only option choices for auto, or pcm.
All options are set to auto.
From the manuel:
AUTO
Normally select this. Outputs audio
signals according to the status of the
connected HDMI device. selected
PCM downmix-Not selected
x[Dolby Digital]
[Downmix PCM]: Converts to output Linear
PCM signals. Select this when connecting an
audio device without a built-in Dolby Digital
decoder.---not selected
[Dolby Digital]: Select this when connecting
an audio device with a built-in Dolby Digital
decoder.------Selected
x[DTS]
PCM signals. Select this when connecting to
an audio device without a built-in DTS
[DTS]: Select this when connecting to an
audio device with a built-in DTS decoder.--Selected
Ysay's Avatar
Double check your player and make sure that it is capable of playing higher rez format. If not, PCM is just as good.
Ysay is offline
Old 04-19-2012, 12:23 PM
unavol's Avatar
Quoted: 43 Post(s)
Liked: 48
I have a Sony 570 and the setting you're looking for is called BD Audio Mix on the 570. Set that to "Off", which sounds backwards but it's what the manual says.
unavol
unavol is offline
Old 04-19-2012, 01:01 PM - Thread Starter
This might be it...
I need to double check it, but I think it could already be OFF.
It supports the formats:
from Sony website:
Dolby® TrueHD & dts®-HD internal decoding and bitstream output via HDMI™Dolby® TrueHD and dts®-HD (Master Audio and High Resolution Audio) codecs reproduces high definition sound with 7.1 channels of discrete audio so you can enjoy uncompromised au
Old 04-19-2012, 01:06 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
If you want to hear the sound effects that are provided in the menus or the secondary audio track(s), you have to turn mix on. When you turn mix on, the player has to output PCM. The receiver won't show either Dolby or DTS indicators because that's not what it's getting -- it's getting PCM. The receiver has no way to know what's actually on the disc.
In order to do the mixing, the player internally decodes the audio from the disc into PCM and mixes it with the audio used for the menu. The player then has no choice but to output the resulting PCM: the player doesn't have the computational power (or the license) to recreate either DTS or Dolby high-def compressed audio bitstreams from the mixed audio.
Selden
Selden Ball is offline
Old 04-19-2012, 02:04 PM - Thread Starter
I will make sure the mix is turned OFF and check back with results.
Old 04-20-2012, 09:09 AM - Thread Starter
Audio mix WAS set to on.
Hopefully this will change thing.
Will watch a BD tonight and verify.
Thanks for the help with this guys.
Old 04-20-2012, 09:49 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
It's not going to change how the soundtrack sounds. Either way, PCM or bitstream, you should get the same sound quality. The difference is where the decoding is being done. When you decode at the player, the player sends multichannel PCM to the AVR and all the AVR knows is that it is receiving some sort of multichannel PCM. It doesn't know which codec that multichannel PCM came from originally, which is why there is no display of a particular codec.
As pointed out, what WILL change if you pass bitstream instead of PCM, is that some of the audible menu beeps and clicks that you might have heard when navigating discs' menus, when passing PCM, will no longer be there.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
Old 04-20-2012, 10:01 AM
Liked: 1494
Using bitstream also disables "secondary audio" which is used by PIP "Bonus View" options on some discs.
Selden
Old 04-23-2012, 08:58 AM - Thread Starter
Well, yes, I now have the AVR recognizing the HD audio.
Then what is the benefit of DTS-HD master audio at the AVR level?
Seems to be a selling point that AVR's have the capability, what difference does it make if the AVR has the capability, if it is decoded just as well by the blu-ray player?
Old 04-23-2012, 10:11 AM
Liked: 1494
Some players, especially when they mix in the menu sounds and secondary audio channels, only output standard definition LPCM instead of high definition. Whether or not you can actually hear that difference is arguable.
Selden
Old 04-23-2012, 12:23 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
There is no benefit to decoding in the AVR instead of the player, although some people like seeing the lossless codec on their AVR displays. You get the same PCM regardless of where the decoding is done and the AVR handles the rest of the processing (bass management, EQ, etc) either way.
In fact, there may be advantages to decoding in the player. You can mix in secondary audio for menu sound effects and PIP commentary tracks with player decoding. And, some AVRs lack the processing power to apply room correction or other DSPs when doing lossless decoding. So, in those circumstances, player decoding is better.
But, again, the PCM produced is the same no matter where the track is decoded.
BIslander is offline
Old 04-23-2012, 03:46 PM
rdgrimes's Avatar
Liked: 1321
Many players will use the lossy core for mixing with secondary audio, so it's not a given that decoding in a player is just as good as AVR.
rdgrimes is offline
Old 04-24-2012, 04:01 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Those players have settings that allow them to decode lossless tracks without secondary audio. I am not aware of any halfway recent player that cannot decode lossless to produce the exact same PCM as a receiver.
Old 04-24-2012, 06:50 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
I do not know how with current generation of players, but two years ago NONE of players on the market were able to mix secondary audio with lossless tracks. So if you want to hear lossless either in PCM or native mode you had to disable all sound effects in player.
ap1 is offline
Old 04-24-2012, 10:25 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
PS3s, Samsungs, LGs, and many Sony players will mix secondary audio when decoding lossless. That's always been the case with those players. In fact, most of them don't even have SA settings - there's no way to turn off effects audio - if you decode in the player you get whatever effects audio is present. Panasonics, Pioneers, and Oppos have the lossy limitation when mixing secondary audio.
But, it appears I have not been clear in making my point. I am saying there's no advantage to decoding in a receiver since you can get the exact same PCM when decoding in any player. There are also advantages to player decoding. Secondary audio is one of them. While it is true that some some players use the lossy track when mixing in effects, the only way to get SA is with player decoding. If you have a player with the lossy limitation, you can still get lossless decoding by turning SA off. The other potential advantage to player decoding is with receivers that lack the processing power to apply room correction or DSPs when decoding lossless tracks.
Old 04-24-2012, 02:56 PM
rdgrimes's Avatar
Liked: 1321
This is not the case with all players. But in those that re-encode S.A. it's usually to lossy DTS.
rdgrimes is offline
Old 04-24-2012, 05:00 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Of course it is. The original soundtrack must be decoded by the player in order to mix in the secondary audio. The fact that player is decoding the soundtrack on the disc may be transparent to the user who selects an output option such as re-encode. But, it happens nonetheless.
Players with a specific re-encode option mostly output DTS. But, players such as Panasonics, that have an SA option, re-encode with the original type - TrueHD as DD 5.1 and dts-MA as DTS.
Here's the point: if you bitstream lossless codecs to an AVR with lossless decoders, you cannot get secondary audio.
Old 04-24-2012, 05:25 PM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
It's not a matter of DSP power, it simply would serve no purpose to re-encode lossless audio since HDMI handles PCM just fine.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 04-24-2012, 05:32 PM
Liked: 710
The new Oppo 93/95 use HD audio when mixing secondary audio.
Old 04-25-2012, 09:36 AM - Thread Starter
I have no need for secondary audio.
I am looking for the best, cleanest, most hi tech audio possible.
Seeing it on the display at least makes me "feel" like I am getting the best audio feed possible, even if I might not really hear any difference.
I guess I was expecting a bigger difference in something called "HD" audio.
Thanks for all the replies, I learned quite a bit.
Old 04-25-2012, 09:51 AM
Liked: 1494
What??? You aren't going to watch the PIP descriptions of how scenes were developed while you're also watching the movie? Horrors! all that wasted effort by the producers!!!
Only a few BD discs include this feature, but it can be interesting at times.
In principle, you shouldn't be able to hear the difference between a high-bitrate DD or DTS soundtrack and the lossless equivalent. Both companies put a lot of work into the psychoacoustics involved in their lossy compression algorithms. As the bitrate goes down, there are more differences, of course, which eventually might produce audible effects.
You're quite welcome, of course.
Selden
Old 04-25-2012, 11:09 AM
rdgrimes's Avatar
Liked: 1321
Apart from that, letting the AVR decode and display the input codec also eliminates the chance of accidentally getting the wrong audio track from the player. Not all BD discs will default to lossless audio, and being able to see it on your AVR can be a help.
rdgrimes is offline
Old 04-26-2012, 11:45 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
There are some receivers, such as the expensive Marantz sr7002 and Marantz sr8002, that can either decode DTS-HD MA/TrueHD or apply Audyssey. These receivers lacked the processing power required to decode HD audio and apply Audyssey.
By having the player output pcm, these Marantz receivers had no problem with applying Audyssey just as you said.
audit13 is offline
Old 04-26-2012, 11:51 AM
Liked: 1494
The Marantz AV8003 pre/pro that I have (it's the predecessor to their current AV7005) has the same limitation: decode HD audio or use Audyssey, but not both.
Selden
