Up-sampling Vs Down-sampling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-30-2012, 08:08 AM - Thread Starter
Chrjz's Avatar
I'm not sure if these are the correct terms for what I'm talking about but I have an 88.2 kHz file that foobar won't play (for whatever reason; either my video card doesn't support it even though it'll play all the way up to 192 kHz, or it's an issue with WASAPI).
Either way, I figured the quick and dirty solution was to change the sample rate. So I was wondering if there are any negative consequences from changing it to 96 kHz just so that it's playable on my current set-up? Would I have any reason to use a lower rate like 44.1 kHz or 48 kHz? Mind you, if I'm honest with myself, I probably can't hear a difference between 44.1 kHz and the higher sample rates...
Oh, and if anyone has any insight as to why foobar won't play my 88.2 kHz, please share.
Chrjz is offline
post #2 of 2 Old 05-31-2012, 07:40 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
I would suggest to find and fix problem with playback chain. You always can change sampling rate, but keep it at Nx of original. It means conversion like 44-88-176 or 48-96-192. That way you minimize changes to the record. Any sampling rate can be converted to any other, the question is how much it changes an original sound.
ap1 is offline
Reply Surround Music Formats
