SACD only playing 44.1 khz? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-28-2012, 10:53 PM - Thread Starter
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
I'm confused as to why my sacd's are only playing back in 44.1. THey do play in 5.1 but they all seem to be 44.1 and not high res. What the heck could be causing this issue. I haven't lost my mind SACD's are high res right. Genesis - Genesis album and Billy Joel album with only the good die young on it. Have I lost it?
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/2200 Sub
hdtv00 is offline
post #2 of 14 Old 06-29-2012, 12:07 AM
Kilian.ca's Avatar
Liked: 37
I can't tell from your list what SACD player you have.
You haven't lost it but you've missed it. There are two known possibilities both well documented.
1. Some players downsample DSD to 44.1kHz when decimating to PCM. Well documented in some Denon BDP threads.
2. Some AVRs notably Onkyo display 44.1 fs (NOTE: not kHz) when receiving DSD stream - it's all been queried, discussed and answered many times on AVS. Search old Oppo threads, other SACD threads and posts I replied to.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #3 of 14 Old 06-29-2012, 01:54 AM - Thread Starter
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
Yea I have an Onkyo 809 so it is playing high res it's just displaying 44.1fs then? Strange I swear my old onkyo displayed it normally. The 809 is getting DSD the display picks it up as DSD.
Checked it displays fs: 44.1 khz
I have a Pioneer DV-48AV I used for playback of SACD. I just don't remember it every just displaying 44.1 , but I've also not had this receiver for huge amount of time either. Maybe I never checked it before although I'm certain I did. So it's working fine and doing actual high res or is it down converting or something.
hdtv00 is offline
post #4 of 14 Old 06-29-2012, 06:39 AM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1330
If the AVR is receiving DSD, it is converting it to PCM. It's an open question whether the AVR is sampling the DSD at 44, 88 or what.
rdgrimes is offline
post #5 of 14 Old 06-29-2012, 07:39 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Pioneer should be able to send DSD stream. In that case Onkyo display usually shows DSD 2.0 or 5.1. IF it shows PCM 44.1, than that is what player sends. Look at Pioneer manual for a clue how to set it up properly for SACD playback.
ap1 is offline
post #6 of 14 Old 06-29-2012, 07:39 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
ap1 is offline
post #7 of 14 Old 06-29-2012, 07:57 AM
LineWalker's Avatar
Quoted: 67 Post(s)
Liked: 41
I had a similar problem with my Pioneer DV-49AV--it wouldn't stream DSD to the receiver properly. But then I discovered I had to have my TV on for that to work properly. Don't know why I have to, but when I have the TV on the player streams DSD to my receiver as it should. And I'm doing this over HDMI.
If your player streams DSD over HDMI, you might want to have your TV on, just in case. Makes little sense, I know, but if it works...
LineWalker is offline
post #8 of 14 Old 06-29-2012, 08:45 AM - Thread Starter
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
Yea tv is always on. Another little known tip. Not only does it have to be on. It has to be on a HD res video output wise or it doesn't work either. But maybe that's just the case for dvd-audio. Which works fine in proper rates. It's only now I noticed it saying 44.1 khz.
Yea it is showing DSD but when I look deeper in the display menu it shows 44.1. I did find thread discussing this anyway yea not entirely pleased with this non sense. Guess that's what happens when you go from receiver that can do Direct DSD to whatever the hell this one is doing.
If I do pcm on player side it then outputs 88.2 for the rate according to the Onkyo display.
hdtv00 is offline
post #9 of 14 Old 06-29-2012, 09:02 AM
rdgrimes's Avatar
Liked: 1330
In order for any player to send 5.1 DSD or LPCM audio over HDMI, the video must be set to 720p or better.
In this case it might be better to let the player decode DSD to PCM to avoid any question about what the AVR is doing.
rdgrimes is offline
post #10 of 14 Old 06-29-2012, 09:12 AM - Thread Starter
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
I guess really what my bigger question was that I didn't ask is , what is actually on SACD's audio rate wise. Are they all 5.1 24 bit 96khz or some other rate. I just was shocked to be seeing cd's rate of 44.1
hdtv00 is offline
post #11 of 14 Old 06-29-2012, 12:39 PM
rdgrimes's Avatar
Liked: 1330
What's on an SACD is DSD, which has no bit depth. Technically it's 1 bit at a sample rate of 350 KHz or thereabout. It's a multiple of 44.1, which is why DSD generally gets converted to 24/88.2.
Jeff Nussbaum likes this.
rdgrimes is offline
post #12 of 14 Old 06-29-2012, 08:13 PM
mtrot's Avatar
Quoted: 198 Post(s)
Liked: 65
I also have the Onkyo 809, along with an Oppo BDP-83 universal player. I just checked the display while playing a SACD, and yes it does display DSD, 2.0, 44.1. I used to have a Yamaha RX-V1800, which I thought was supposed to have DSD-direct, and the Onkyo sounds superior to me.
FAMILY ROOM SYSTEM--Legacy Signature II tower speakers, PSB Image 5T tower speakers, Denon AVR-X5200W, Krell FPB 400cx, Oppo BDP-83 universal disc player, RCA HD-DVD player, Samsung HL67A 750A TV
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Yamaha RX-V1800 receiver, Sherbourn 5/1500A 5-channel amp, Oppo DV 980H DVD player, Panasonic DMP DT210 Blu-ray player, Panasonic 60-ST60 plasma TV.
mtrot is offline
post #13 of 14 Old 06-30-2012, 01:40 AM
Kilian.ca's Avatar
Liked: 37
Look, you guys are over-interpreting and over-reacting to this. The Oppo 980 thread has the quote from HDMI 1.2 spec which has been repeated many times here and elsewhere. The HDMI 1.3 spec, says clearly in plain English:
Section 7.2.4
...For any L-PCM stream, the ACR fS value shall be equal to the audio sample rate....
Section 7.2.5
For any One Bit Audio stream, the ACR fS value shall be 1/64th of the bit rate. For One Bit Audio data from Super Audio CD (2.8224MHz) the ACR fS would therefore be 44.1kHz.
It's just the way different audio streams are handled. There's no downsampling, because the 44.1kHz displayed isn't in LPCM, but just a numerical representation as laid down by the spec. Do not keep dwelling on a non-issue.
post #14 of 14 Old 06-30-2012, 07:33 AM
mtrot's Avatar
Quoted: 198 Post(s)
Liked: 65
Section 7.2.4
Section 7.2.5
Cool! Thanks for that info.
mtrot is offline
Reply Surround Music Formats
