Will DTS-HD / DD TrueHD work with just 5.1 speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-02-2012, 12:46 AM - Thread Starter
HelloHelloHello's Avatar
Or do I need 7.1?
HelloHelloHello is offline
post #2 of 4 Old 07-02-2012, 03:45 AM
nicklemarr's Avatar
Will work just fine on 99% of receivers supporting it.
nicklemarr is offline
post #3 of 4 Old 07-02-2012, 03:55 AM
LB06's Avatar
Yes it'll work. The far majority of mixes are 5.1 anyway and those which are 6.1 or 7.1 can easily be downmixed to 5.1 while retaining the high resolution qualities of TrueHD/DTS-MA/FLAC.
LB06 is offline
post #4 of 4 Old 07-02-2012, 12:37 PM
sdurani's Avatar
Quoted: 4476 Post(s)
Liked: 2896
Originally Posted by HelloHelloHello View Post
Or do I need 7.1?
DTS-HD MA and TrueHD (not DD TrueHD) are lossless data packing algorithms. Think of it as zipping a large file on your computer; you're not throwing out any of the data, just packing it more efficiently in a smaller space. That's what DTS MA and TrueHD are. Nothing more complicated than that.
As such, DTS MA and TrueHD soundtracks can be any number of channels from 1 to 7.1 (the BD spec doesn't allow for more than 8 audio channels). Since those codecs aren't fixed to a certain number of channels, you don't have to use a certain number of speakers.
Besides, modern receivers scale the number of channels in the source material to the number of speakers in your set-up. 2-channel can be upmixed to your 5 speakers and 7.1-channel material can be downmixed to your 5 speakers.
So set up as many (or few) speakers as you can accomodate, and don't worry about how many channels or which audio codec the soundtrack uses. You won't have any problems during playback.
Sanjay
sdurani is online now
Reply Surround Music Formats
