Newbee Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 02-23-2013, 03:47 PM - Thread Starter
420 benz's Avatar
Having a problem with Surround Sound.
TV: UN55D8000
Receiver: HT: S590
I have a Diagram of my setup in the Gallery but don't know how to post it.
The problem is when i play a movie on Netflix and turn on the receiver the sound of the previous TV program is in SS and the Netflix movie is in TV sound both sounds are on at the same time.
420 benz is offline
post #2 of 30 Old 02-23-2013, 04:38 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
It's unclear from your post how the devices are connected and which devices are playing the sources. But, from your description, it looks like the receiver is still set to the input with the TV program source while the TV is set to the Netflix input.
BIslander is offline
post #3 of 30 Old 02-23-2013, 05:38 PM - Thread Starter
420 benz's Avatar
How can I post the diagram I uploaded into the Gallery?
420 benz is offline
post #4 of 30 Old 02-23-2013, 05:40 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
No need. Words work fine.
post #5 of 30 Old 02-23-2013, 05:48 PM - Thread Starter
420 benz's Avatar
If you see the diagram you could tell me what I did wrong. I am not very good at this stuff..
420 benz is offline
post #6 of 30 Old 02-23-2013, 06:16 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi 420 benz, is NetFlix from the 3D/DVD player or from tv internet app? And how is optical 1 and optical 2 assigned on the S590?
JChin is offline
post #7 of 30 Old 02-23-2013, 06:43 PM - Thread Starter
420 benz's Avatar
Netflix is from the TV. There is only one optical output on the TV and it goes to the Receiver.
420 benz is offline
post #8 of 30 Old 02-23-2013, 06:48 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
What input on the receiver is associated with the output of the TV? You need to select that input on the AVR to hear sound from Netflix on the TV. You may also need to enable the optical output on the TV.
post #9 of 30 Old 02-23-2013, 06:58 PM - Thread Starter
420 benz's Avatar
The receiver has two optical outputs,one to the TV and the other to the Direct TV DVR.
BTW: How do I enable the optical output on the TV?
420 benz is offline
post #10 of 30 Old 02-23-2013, 07:12 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
That may, or may not, be necessary. The manual should explain. Some sets send audio out the digital port by default. Others have a setting where you can switch between TV speakers and the optical output.
Meanwhile, if you were hearing Direct TV instead of Netflix, then your receiver was set to the wrong input.
post #11 of 30 Old 02-23-2013, 07:18 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
So on the S590 remote, which button is for DirecTV DVR and which is for Tv?
JChin is offline
post #12 of 30 Old 02-23-2013, 07:26 PM - Thread Starter
420 benz's Avatar
There is no switch on TV from TV speakers to optical output.
420 benz is offline
post #13 of 30 Old 02-23-2013, 07:37 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Its not a actual physcial switch on the tv, you find the TV Speaker option in the tv "Audio" menu.
JChin is offline
post #14 of 30 Old 02-23-2013, 07:39 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Do you mean a physical switch? It would be a setting in the TV menus.
post #15 of 30 Old 02-23-2013, 07:46 PM - Thread Starter
420 benz's Avatar
None of the above. The s590 remote has an input selector for V1-V2-V3- DVD -CD-Tuner-Tape.
The setup now is V2 for Surround Sound.
420 benz is offline
post #16 of 30 Old 02-23-2013, 07:59 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
The optical ports are assignable, you most likey have DirectTv DVR plugged into optical 1. If so then the TV optical cable is pluuged into optical 2 which by default is "CD". So if you didn't assign the optical ports then press the "CD" button on the remote.
JChin is offline
post #17 of 30 Old 02-23-2013, 08:09 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Yes, V2 selects one of the inputs. Unless you've changed the assignments, V2 is associated with Optical 1 and CD is associated with Optical 2. At any rate, in order to listen to different sources such as your DVR or Netflix from your TV, you need to select the correct inputs on the receiver. If you leave it on V2, you will only hear whatever is playing on that audio input. That's almost certainly why you are hearing Direct TV instead of Netflix.
post #18 of 30 Old 02-23-2013, 08:41 PM - Thread Starter
420 benz's Avatar
I will play around with the receiver tomorrow.
420 benz is offline
post #19 of 30 Old 02-24-2013, 09:53 AM - Thread Starter
420 benz's Avatar
OK Removed the optical cable from the DVR to the Receiver and replaced it with an RCA cable thinking maybe the cable was bad. No change. Now i only have one Optical cable from the Receiver to the TV so i moved it from one Optical output to the other while switching from V2 to CD and still no change. The end result is that i cannot get Netflix to play through the Receiver.
420 benz is offline
post #20 of 30 Old 02-24-2013, 12:39 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Why remove the optical cable from DVR to Receiver? That has nothing to do with having no audio from your tv.
Why move the tv optical cable to the other when all you had to do was press the CD button.
Since you moved the optical (tv to receiver) cable now, press V2 and not CD.
JChin is offline
post #21 of 30 Old 02-24-2013, 12:56 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Benz - You need to follow the steps on p35 of the manual for assigning the digital inputs. There are two optical inputs on the AVR. The chart on p35 shows what selector names those inputs are associated with. If you have the Direct TV DVR plugged into Optical 1 and that input is associated with Video 2, then you need to choose V2 on the AVR to hear the sound. If the TV is plugged into Optical 2, then you need to look at the settings menu to see what selector name is associated with Optical 2. By default, Optical 2 is associated with the CD selector position. But, you may have changed it at some point. At any rate, look at the back of the AVR to see where the TV is plugged in, look at the menu to see which selector name is associated with that input, and then choose that selector name on the AVR or the remote.
Your problem is not a bad optical cable
post #22 of 30 Old 02-24-2013, 03:40 PM - Thread Starter
420 benz's Avatar
My problem is not getting SS to the TV,it is with Netflix.I just reset the Receiver to V2 and the TV still gets SS (only on a TV channel). When I turn on Netflix the sound comes through the TV. As soon as I turn on the Receiver SS the original TV program sound is in SS and the Netflix movie sound comes through the TV. Now I can watch and here the Netflix movie and also here but cannot see the TV program.
420 benz is offline
post #23 of 30 Old 02-24-2013, 03:51 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
When you turn on the receiver, you have to select the AVR input associated with the TV audio. if you leave it on the input for the Direct TV box, you will hear Direct TV. The receiver doesn't know that you want to hear the TV audio instead of Direct TV. How could it?
Until you explain how you have things connected, it is hard to help. For audio, I assume you have the Direct TV box connected to one optical input and the TV output connected to the other. You need to select the correct sources on the receiver in order to switch from one to the other. For video, you have the TV, of course, but we don't know how the Direct TV is connected. Is it connected to the receiver or directly to the TV?
At the end of the day, you need to select the correct inputs on the device handling the video and on the device handling the audio. It is clear you are not doing that right now. But, the solution is not clear because you haven't explained how the equipment is connected.
post #24 of 30 Old 02-24-2013, 03:52 PM - Thread Starter
420 benz's Avatar
Whatever setting or connection is supposed to turn off the TV program and allow the SS to switch to Netflix is not working.
420 benz is offline
post #25 of 30 Old 02-24-2013, 04:00 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
I am not aware of any such setting. You need to do that yourself.
post #26 of 30 Old 02-24-2013, 04:20 PM - Thread Starter
420 benz's Avatar
Well I think I did all you guys suggested but all of those settings are working fine for the TV I don't think they have anything to do with Netflix.
420 benz is offline
post #27 of 30 Old 02-24-2013, 04:43 PM - Thread Starter
420 benz's Avatar
The above is just my humble opinion.
420 benz is offline
post #28 of 30 Old 02-24-2013, 05:20 PM
Bill Mac's Avatar
Quoted: 1564 Post(s)
Liked: 1810
You do realize that this is the "Surround Music Formats" forum. So for help with the issue you are having it might be better if you went to the correct sub forum. A sub forum that has fellow UN55D8000 and S590 owners that are familiar with both components.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #29 of 30 Old 02-24-2013, 05:57 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
That's odd because neither of us made any suggestions about your TV, just your receiver. I realize you are referring to your Direct TV box when you say TV. But, the only way you hear that sound is by selecting the correct input on your receiver. The same goes for hearing Netflix on your surround system. You must select a different input on your receiver.
post #30 of 30 Old 02-24-2013, 05:58 PM - Thread Starter
420 benz's Avatar
Thanks I will do that. I do want to thank the guys on this forum for allot there help and for putting up with me.
420 benz is offline
Reply Surround Music Formats
