man of steel z+ audio skipping - AVS Forum | Home Theater Discussions And Reviews
Old 06-12-2013, 06:42 PM - Thread Starter
Mark Dymek's Avatar
Quoted: 86 Post(s)
Liked: 44
anyone else hear the audio skipping in the z+ app? also as for 11.1 don't notice any difference. is the app bugged?
Mark Dymek is offline
Old 06-13-2013, 07:51 AM
JD NC's Avatar
Liked: 40
I heard reports of the music skipping if it was playing in the background while using another app. If it's happening while in the foreground, try quitting background apps.
I heard a difference with the DTS versions but it wasn't as dramatic as the demo with zimmers' voice coming from the different "speakers." The DTS version had fuller bass, and I heard a few cool directional effects, but that's about it.
Also, I'm a broken record on this (see my thread below), but be sure that you don't delete the app on your phone if you downloaded the full album using the redemption code - if you delete the app, the DTS tracks are gone forever, and you can't redownload.
JD NC is offline
