DSD from my computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 09-12-2013, 02:23 PM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
I'm new to the lossless audio and DSD music so forgive my naive questions but I am looking to start building a music collection of DSD from streaming audio sites. I am guessing my computer will not output lossless audio from a digital coaxial output to my reciever? What computer do I need or what connection? This is going to a Rotel tuner, emotiva then 802N. Thanks for any help.
alanhenson is offline
post #2 of 34 Old 09-12-2013, 05:01 PM
rdgrimes's Avatar
Quoted: 1995 Post(s)
Liked: 1326
Its not generally possible to output a DSD stream from a PC. HDMI would be the only connect capable. Your best option is to access DSD files directly from network connected playback devices. Very few support DSD files, Oppo being one.
rdgrimes is offline
post #3 of 34 Old 09-13-2013, 05:05 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Originally Posted by alanhenson View Post
I'm new to the lossless audio ...I am guessing my computer will not output lossless audio from a digital coaxial output to my receiver?.....This is going to a Rotel tuner, emotiva then 802N....
Just to add to what rdgrimes said, S/PDIF (digital coaxial or optical) doesn't support multi-channel lossless audio at all. You best bet may be to transcode to LPCM and send through HDMI. You can output muli-channel lossless over USB or a WiFi connection (is 802n your WiFi connection?).
Also your hookup chain doesn't make sense since there is no way to send audio (other than radio waves) into a tuner.
William is offline
post #4 of 34 Old 09-13-2013, 08:31 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
Sorry meant Rotel processor. I was referring to 802 Nautilus B&W speakers. So there's no computers or fancy sound cards I can buy for my computer that can output it through hdmi to my tuner? I was going to get an oppo blue ray if that helps. Sorry again. Just new to this. How are others doing it?
post #5 of 34 Old 09-13-2013, 08:42 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
which oppo device fits this?
post #6 of 34 Old 09-13-2013, 09:29 AM
rdgrimes's Avatar
Liked: 1326
Any Oppo player can output a DSD stream via HDMI, or convert it to LPCM and output that via HDMI.
Your processor needs the capability of accepting DSD over HDMI. However, any processor must convert DSD to LPCM in order to apply any digital processing like bass management, EQ, etc. So it makes little difference if you send DSD or LPCM to the processor in most cases. If you are working with stereo signals, some processors offer a direct DSD->analog pathway with no processing. The Oppo players also offer direct DSD->analog conversion via their analog outputs and internal DAC. So you have options to play with and can choose what works best for you.
Only the Oppo BDP-103 and BDP-105 can play DSD files directly, either from attached storage or via SMB network sharing. Previous players can play SACD-R discs, the 103/105 cannot. Any Oppo player supports SACD discs and DVD-A.
rdgrimes is offline
post #7 of 34 Old 09-13-2013, 10:21 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
Thanks so much for that great explanation. I am getting the 105 soon. My processor is the Rotel 1069 though which is a few years old so it might not work. Good excuse for a new one. I'm thinking about new rotel or emotiva. Any thoughts on those?
post #8 of 34 Old 09-13-2013, 10:55 AM
Patrick Collins's Avatar
Quoted: 47 Post(s)
Liked: 44
Limited as DSD files are, I'm considering Oppo's 103, going straight in to my 2 powered Meridians with coax. But in your case, adding a high quality stereo power amp to those great B&W 802s, you might consider the Marantz NA-11S1. It's a high end streamer (about $3500) and 2 channel preamp that happens emphasize it's DSD capabilities along with it's exceptional DAC. It's best served with a USB input. For your computer, the latest versions of J River Media Center support DSD. BTW I had my computer built with an SP/dif coax out connector in anticipation of things like this. One caveat, I think JRMC transcodes DSD files to PCM. At this level you might be able to hear the difference.
Patrick
Patrick Collins is offline
post #9 of 34 Old 09-13-2013, 12:10 PM
rdgrimes's Avatar
Liked: 1326
If you require analog connects from the player, the BDP-105 is worthy. If you intend to get a new processor with HDMI inputs, the BDP-103 is a more appropriate choice.
rdgrimes is offline
post #10 of 34 Old 09-13-2013, 02:36 PM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
is that really the only difference between the 105 & 103.
post #11 of 34 Old 09-13-2013, 03:28 PM
rdgrimes's Avatar
Liked: 1326
Yes, they are identical except for the analog board. They even use the same firmware.
rdgrimes is offline
post #12 of 34 Old 09-13-2013, 05:31 PM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
Wow a $700 difference for that? And HDMI will do everything the analog will do won't it?
post #13 of 34 Old 09-13-2013, 09:29 PM
rdgrimes's Avatar
Liked: 1326
Its a VERY extensive and well built analog board which includes digital (SPDIF) input and USB-DAC input as well as dedicated stereo outs and headphone amp. $700 is cheap. But yes, if you can use HDMI then the 103 is all you need.
rdgrimes is offline
post #14 of 34 Old 09-15-2013, 12:18 PM
acebreathe's Avatar
Quoted: 171 Post(s)
Liked: 98
Take a look at www.audiostream.com. They have compiled a lot of useful info on everything relating to DSD.
acebreathe is offline
post #15 of 34 Old 09-15-2013, 12:51 PM
oOOBillO0o's Avatar
Addition to Audiostream's portal, PS3 can play DSD via DSD Discs and best played via the Multi AV Analog. See Korg Audiogate for DSDDisc creation.
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
post #16 of 34 Old 09-15-2013, 02:44 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
A PS3 is much more likely have inferior analog circuitry (and D/A converters) than the OP's Rotel processor. So I would only use HDMI on the PS3. If going analog out you should have a quality source like the OPPO BDP-105.
William is offline
post #17 of 34 Old 09-15-2013, 02:45 PM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
thanks man
We don't allow video games in the house or I'd be all over it.
post #18 of 34 Old 09-15-2013, 02:59 PM
oOOBillO0o's Avatar
Sure, that's logical, but is it true.. ??
Side note: http://archimago.blogspot.com/2013/09/measurements-pcm-to-dsd-upsampling.html
post #19 of 34 Old 09-16-2013, 08:31 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Interesting set of results. They show excellent performance for the equipment being tested.
What nobody is doing is bringing in what is known about the thresholds of human hearing for noise and distortion. Draw a line across every test at -100 dB, and would be an unconditional and highly conservative statement of the ear's capability, well beyond what can be observed in actual listening tests of a professional grade.
I can't find any online full technical tests of the PS/3 and its chip complement is mostly proprietary chips so it is hard to figure out what its actual performance is. However the idea that a high end DVD player like the BDP 105 outperforms it seems to me to be likely.
arnyk is offline
post #20 of 34 Old 09-16-2013, 09:05 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
So the Oppo 105 says it supports DSD. Can I just plug y computers USB into the Oppo and play the files straight from there?
post #21 of 34 Old 09-16-2013, 09:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
What about post #6?
arnyk is offline
post #22 of 34 Old 09-16-2013, 09:31 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
Yeah I guess that answers it. I guess I was just concerned about my computer not having an HDMI output but it seems only the Sony VAIO has the capacity to output DSD from an HDMI in that case. I guess USB will carry the file to the Oppo unchanged.
post #23 of 34 Old 09-16-2013, 09:40 AM
oOOBillO0o's Avatar
http://schiit.com/products/loki
If it hasn't been shared, this is the $149 entry point into DSD from your computer.
post #24 of 34 Old 09-16-2013, 10:03 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
Holy Schiit that looks cool. Sorry, had to.
post #25 of 34 Old 09-16-2013, 10:09 AM - Thread Starter
alanhenson's Avatar
Quoted: 32 Post(s)
That would make this stereo only and not 5.1?
post #26 of 34 Old 09-16-2013, 11:26 AM
oOOBillO0o's Avatar
Sorry, no 5.1 -
I feel the entire company's sense of humor lies in it's naming convention. Schiit nailed it.
post #27 of 34 Old 02-03-2014, 11:16 PM
harri009's Avatar
Quoted: 16 Post(s)
I am up to about 1300 albums on DSD so I would say I am firmly planted at this point!! smile.gif
VPI avenger w/ Transfiguration Proteus
Zesto Andros 1.2
Zesto Leto 1.5
Zesto Eros 300's
Magnepan 3.7's
www.referenceanalog.com
harri009 is offline
post #28 of 34 Old 02-04-2014, 12:33 AM
HomerJau's Avatar
Quoted: 37 Post(s)
Liked: 37
You can always convert to 24bit PCM as WAV or FLACs to escape that smile.gif
HomerJau is offline
post #29 of 34 Old 02-04-2014, 12:37 AM
harri009's Avatar
Quoted: 16 Post(s)
Not something I am trying to escape. I am quite happy with the sound.
Zesto Andros 1.2
Zesto Leto 1.5
Zesto Eros 300's
Magnepan 3.7's
harri009 is offline
post #30 of 34 Old 02-04-2014, 02:34 AM
SeeMoreDigital's Avatar
Quoted: 467 Post(s)
Liked: 197
Jeez... That's a huge number. How many GB/TB is that lot?
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
Reply Surround Music Formats
