Too many options!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-13-2013, 09:56 PM - Thread Starter
Roscoe's Avatar
I have a Sony BDP-S790 and an Onkyo TX-SR606 receiver. The recover has a ton of listening modes, but I don't understand the tables at all (and I'm not a dummy). I recently watched Ironman 3 with 7.1 DTS and I noticed sound coming out of the front surround speakers but not the back 3 (I have a 6.1 setup). I found a setup that put sound out the rear, but in retrospect I think it was a setting that pushed stereo to surround speakers. I'm pulling my hair out trying to understand these tables in the manual.
Bottom line, can anyone help me set my BD player for audio output and the mode that will best will reproduce DTS 5/6/7.1 sounds the best?
Roscoe
Roscoe is offline
post #2 of 5 Old 10-14-2013, 12:53 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Roscoe, in the S790 audio menu set "HDMI Audio" to Auto and "BD Audio Mix" to Off for the receiver to decode.
In the SR606 Listening Mode menu set each audio presets DD to DD, DTS to DTS, TrueHD to TrueHD, DTS HD MA to DTS HD MA, D.F 2Ch and Analog/PCM to PLII etc....
JChin is offline
post #3 of 5 Old 10-14-2013, 10:05 AM - Thread Starter
Roscoe's Avatar
Thanks (I saw your other post as well...)
How do I do that? I don't recall seeing that before... (But sounds right...thanks)
Roscoe
Roscoe is offline
post #4 of 5 Old 10-14-2013, 10:40 AM - Thread Starter
Roscoe's Avatar
What about the Dolby Digital / DTS setting? I assume if the other settings are as you suggest then this doesn't matter? Or should it be set to Bitstream.....
Roscoe
Roscoe is offline
post #5 of 5 Old 10-14-2013, 12:58 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Leave as Bitstream (default setting) as it has no effect on HDMI audio (I believe), only for digital coaxial and optical output.
JChin is offline
Reply Surround Music Formats
