smart TV wont play surround sound while using the smart internet apps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-25-2014, 07:20 PM - Thread Starter
Liked: 0
HI all
I have a Panasonic Flat screen with Viera smart technology. I sometimes use the volume on the TV but I also have it hooked up to a surround sound through HDMI I beleive. When I use the smart App to go on youtube for example it works fine as far as the picture. For some reason however it will only play the sound through the TV and not the surround Sound. Surround works pefectly on normal Cable channels. Am I doing something wrong? Does it need a certain connection to play the smart apps through surround? Thanks everyone
k23ms123 is offline
post #2 of 10 Old 08-25-2014, 08:53 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Your TV may have a setting to enable the external speakers. How are you sending audio from the TV to the sound system?
BIslander is offline
post #3 of 10 Old 08-25-2014, 11:13 PM
acebreathe's Avatar
Quoted: 171 Post(s)
Liked: 98
You may have to enable external speakers like B I suggested but you might also have to assign the HDMI to a particular input like Cable or DVD etc if you are going in to a AV receiver then choose that input when you want to hear it from the receiver. You might need to turn the sound down on the tv too if the tv menu doesn't say anything about external speakers.
acebreathe is offline
post #4 of 10 Old 08-26-2014, 06:22 AM - Thread Starter
Liked: 0
I believe everything is connected to hdmi wire. When I put surround system I tv normally always recognized that and sys found through surround. It just simply won't do it through the smart apps
k23ms123 is offline
post #5 of 10 Old 08-26-2014, 07:09 AM
acebreathe's Avatar
Quoted: 171 Post(s)
Liked: 98
Go in to tv menu. Scroll down to setup. From there choose Viera link settings. From there look for a setting for audio. The default setting is for the TV's speakers. I also have a Panny with Viera apps and just looked at settings. It should work but if not get out the owners manual and see what it says. It's possible but not likely that you may have to run a separate audio cable.
post #6 of 10 Old 08-26-2014, 08:40 AM
SeeMoreDigital's Avatar
Quoted: 467 Post(s)
Liked: 197
Sufficed to say, don't expect to hear surround audio from any YouTube video. At the most they'll all be 2Ch (stereo)...
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #7 of 10 Old 08-26-2014, 09:28 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Are you saying the TV and surround system are connected with a single HDMI cable and there's no optical cable that would send sound from the TV to the surround system? If so, do both devices support ARC (audio return channel) and is the HDMI cable plugged into an ARC cable input in the TV?
post #8 of 10 Old 08-27-2014, 01:19 PM - Thread Starter
Liked: 0
hmmm let me check maybe its possible I do have an HDMI and optical cable If thats the case do I need to do something different for youtube to play through my surround?
k23ms123 is offline
post #9 of 10 Old 08-27-2014, 03:55 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
You have to decide how you are feeding the audio from the set to the receiver and configure the equipment accordingly.
post #10 of 10 Old 08-27-2014, 07:45 PM
acebreathe's Avatar
Quoted: 171 Post(s)
Liked: 98
Once you do what BI said you need to go in to the set up on the TV itself and assign the speakers for the Viera app thru the set up menu.
Reply Surround Music Formats
