help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-05-2007, 08:03 PM - Thread Starter
Roachgod's Avatar
need to back up my sacd's and dvd audio disks beacause my fu@$%^$ dogs ate my remotes for my old dvd player and the new hd dvd player i have comeing in this week doesn't play those formats. I tried the search and gooogle but couldnt find squat.Any help would be greatly appreciated.
Roachgod is offline
post #2 of 6 Old 05-05-2007, 08:32 PM
sivadselim's Avatar
Quoted: 160 Post(s)
Liked: 154
SACD is not possible to put on your HD.
DVD-A may be doable with the right software and drive. Not sure, though.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 6 Old 05-05-2007, 09:38 PM
hotguy8289's Avatar
I don't get it. If your new hd player won't play these disks, it certainly won't play backup copies of these disks. It sounds as though you need a universal remote instead of a way to backup your disks. Did I miss something?
TonyW
hotguy8289 is offline
post #4 of 6 Old 05-06-2007, 04:48 AM - Thread Starter
Roachgod's Avatar
I would like to remove my old samsung hd 841 from my component rack when my new toshiba hda20 arrives later this week. If I could rip the music to my htpc now from my sacd's and dvd audio disc I would have no real need for the old dvd player anymore.
Roachgod is offline
post #5 of 6 Old 05-06-2007, 06:31 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3923
What will you use to playback the hi-rez PCM or DSD you rip from the discs?
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #6 of 6 Old 05-06-2007, 08:20 AM
Ovation's Avatar
Quoted: 102 Post(s)
Liked: 65
You can't do it for your SACDs. If they are hybrids, then you can rip the CD layer but you will not have a hi-res copy. Is your component rack that cramped for space?
Ovation is offline
Reply Surround Music Formats
