Sample rates - I'm confused - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-18-2007, 11:55 PM - Thread Starter
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Sorry if this is a really dumb question.
I have a Samsung HD-950 connected to my Pioneer VSX 1011 AVR via 6 analogue connections for HR and a coax digital connection for LPCM, DD and DTS. Usually I select the MULTI IN to listen to my limited collection of HR discs in surround. Most of the DVD-A discs I have 96K for both the 5.1 and the 2CH version on the cover notes.
I have found that if I select the 2CH version of the audio, that I can also use the digital connection. It only passes the L R in this mode so I have to select 2CH or I miss the content of the other channels. When I listen to a 2CH CD, I also select the DIRECT mode. In listening to the difference between the analogue and digital in for the 2CH version, I found that digital seemed a little more crisp.
So here is my dumb question - why does the AVR display 88K if these discs are sampled at 96K?
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #2 of 8 Old 05-23-2007, 03:16 AM
neil wilkes's Avatar
Misprint on the disc cover?
neil wilkes is offline
post #3 of 8 Old 05-23-2007, 07:45 AM
obie_fl's Avatar
Liked: 33
DVD-As are in fact 96K for the most part. My guess is your player is re-sampling it to 88K before transmitting it out over S/PDIF.
obie_fl is offline
post #4 of 8 Old 05-23-2007, 10:17 AM
It's nonsense to say that DVD-A are 96K for the most part.
There are serious numbers at 48KHz, and a fair quantity at 88.2 as well.
Any player that is resampling to 88.2 before outputting is clearly not up to spec either, as the stereo component will also be MLP Lossless and the output must be exactly the same as the input to pass spec.
Most likely explanation is the disc is 88.2.
What title are we talking about?
post #5 of 8 Old 05-23-2007, 01:16 PM
sivadselim's Avatar
Quoted: 269 Post(s)
Liked: 226
Yeah, I have some @ 88.2. Pat Metheny's "Imaginary Day" comes to mind.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #6 of 8 Old 05-25-2007, 06:40 AM
obie_fl's Avatar
Liked: 33
When I made the original statement I was only thinking of high sampling rate discs, I was aware of 48Khz discs. What I wasn't aware of was 88.2 discs, although I have seen players that output 88.2 when converting DSD or upsampling. Sorry for the confusion, I'll have to go back and check some of my discs for 88.2Khz, just never noticed any,and I have quite a few DVD-As.
obie_fl is offline
post #7 of 8 Old 05-25-2007, 05:31 PM
sdurani's Avatar
Quoted: 5129 Post(s)
Liked: 3610
Makes sense, since the sampling rate for DSD is 64 x 44.1 (CD sampling rate). My Oppo player outputs DSD converted to PCM at 88.2; I think the PS3 lets the user choose 88.2 or 176.4 kHz.
Sanjay
Sanjay
sdurani is online now
post #8 of 8 Old 05-26-2007, 04:54 PM
obie_fl's Avatar
Liked: 33
Exactly the two players I was thinking of Sanjay.
obie_fl is offline
Reply Surround Music Formats
