Do i want to rip AC3 or DTS music from DVD-A/SACD ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-02-2008, 04:53 AM - Thread Starter
miks's Avatar
Hi,
i just learned to rip a multichannel sound from my DVD-A and SACD`s.
the question is this- do i want to get DTS or AC3 ?
there is a size difference, AC3 song takes 15MB and DTS takes 50MB to store.
as i believe bitrates are different(450kbps vs 1.5Mbps or something like that)
what is your opinion on which sounds better when it comes to 5.1 music?
dont make fun of my english, its 3rd language for me
miks is offline
post #2 of 14 Old 01-02-2008, 09:41 AM
Jeff Fire's Avatar
Typically, DTS will sound better.
Could you share (or point us to) your techniques for ripping?
Jeff Fire is offline
post #3 of 14 Old 01-03-2008, 02:20 AM - Thread Starter
miks's Avatar
sure
to rip ac3 i use "magic dvd ripper"
1. open DVD. copy DVD containing only 'main movie and ac3 sound stream'
2. open copied DVD. rip DVD with settings: 'split by chapter', output format mpeg2(original). thats how i get files track-1.mpg, track-2.mpg etc
3. open each track with VirtualDub-mpeg2. and save track as *.wav. that way it cuts off video from file and i get ac3 sound stream in file track-1.wav etc. then simply change filename to track-1.ac3
to rip DTS i use "SmartRipper"
1. open DVD
2. in track selection select one track only at a time
3. in streaming section select DTS only
4. press start and you get file track-1.dts
5. do the same with other tracks one by one
*if program cant open selected Disc, i simply copy VIDEO_TS folder to HDD, then with magic-iso i make cd image, then mount it on virtual drive and it always works
to playback i use Zoomplayer with installed and settedup 'AC3/DTS source filter/splitter' and 'AC3filter decoder'.
if you need more detailed help on that just ask
miks is offline
post #4 of 14 Old 01-03-2008, 02:59 AM
SiriuslyCold's Avatar
this works for SACD?
Boo!
SiriuslyCold is offline
post #5 of 14 Old 01-03-2008, 05:22 AM - Thread Starter
miks's Avatar
i have tried with hybrids. i believe transfering 'SACD-only' to DVD would not be as simple as copy layer.
miks is offline
post #6 of 14 Old 01-03-2008, 07:43 AM
are you sure this is all legal?
Boo!
post #7 of 14 Old 01-03-2008, 10:30 AM
gregf70's Avatar
I think it would be legal as long as he doesn't distribute his "back ups". If they are for his own personal use, there should be no problem.
That is how I understand it.
gregf70 is offline
post #8 of 14 Old 01-03-2008, 11:07 AM
anyway, I don't think he's getting any hi-rez material
for "dvda"
for sacd
PC drives cannot read the SACD layer i.e no multichannel sound
Boo!
post #9 of 14 Old 01-03-2008, 12:17 PM
rynberg's Avatar
Me either, as nothing he's doing indicates anyway of decoding the MLP-encoded PCM tracks off DVD-A, nor the DSD layer from an SACD.
rynberg is offline
post #10 of 14 Old 01-08-2008, 09:29 AM
mrrame's Avatar
how do I play these tracks (other than my PC) ?
I have lpcm multi channel(6) 48khz wav files. When I burn them as audio CD, I get only 2 channels and others are discarded. Also, Audio CD downsamples my 250MB file to 5mb.
I would like to take audio out of my dvd and play in my car(cd/dvd-a palyer). Is this possible?
mrrame is offline
post #11 of 14 Old 01-08-2008, 10:25 AM
razel's Avatar
Quoted: 13 Post(s)
To play in your car, you got some choices:
1) buy a car headunit that plays DVDs
1) buy a car headunit that plays dvd-audio discs.
2) use audio software to downmix the 6 channels 48k to 2 channel 44k CD audio
3) use a laptop pc to plug into the (if any) standard line-in to your car headunit
4) buy dc/ac adapter, bring your universal (dvd-a/sacd) player in the car and output via standard line-in (if any)
I too wanted to get higher resolution playback in my car and so far my best hope was to find a car headunit that played loseless WMA. I researched Crutchfield up to a certain price point and didn't find any. If you find any let us know. For your situation, the simplest is to buy a car headunit DVD player. If you must rip then converting to loseless multichannel WMA or buying a headunit that plays DVDs and DVD-A (JVC makes one for retail under $1k) may be your best bets.
razel is offline
post #12 of 14 Old 01-23-2008, 04:06 AM
}{eywood's Avatar
1. open DVD
I tried the above steps and all I get is another set of vts files (vob, ifo, etc.), not any .dts files, nor do I see any option to make any. My goal here is to take a DVD-A (The Beatles Love album in this instance) and make an audio CD of DTS files I can play on a DVD player. This isn't working like you said. What am I doing wrong? (I'm using SmartRipper 2.41)
}{eywood is offline
post #13 of 14 Old 01-23-2008, 11:36 AM
Sherbona's Avatar
Hi }{eywood,
Welcome to avs
Your terminology is a little confusing since CDs don't have anything to do with DTS.
- Is your goal to create a DTS Music disc (sometimes inaccurately called "DTS CD")? This could be played back by any device/system that can handle DTS music discs. To create a DTS Music disc you need to purchase software that can do it, i.e., SurCode
- Or are you trying to create a DVD that only contains DTS in the DVD files (vob, ifo) etc..? This is what you would do if you were creating an audio only DVD for playback from a DVD player as opposed to demuxing to .dts files (see below).
- Or are you trying to demux so you have just .dts files? If so then I believe regular DVD players won't know what to do with those files if burned to a DVD for playback - but you could use .dts files if playing back using a computer as your playback device. So if trying to demux to .dts files I (or someone else) can probably work on steps/troubleshoot, but maybe include some detail on your intended playback setup as far as hardware (hardware dvd player? dts music disc? analog or s/pdif connection?).
Also just to make sure you're aware, you are getting the audio from the 'normal' portion of the DVD and not the hi-res portion or the DVD-A, which is fine if you are only going for the AC3 or DTS audio.
Sherbona is offline
post #14 of 14 Old 01-23-2008, 07:21 PM
Goatspeed's Avatar
AFAIK, the actual SACD multi channel DSD track has never been cracked. Shh, don't tell the h4x0rs.
Goatspeed is offline
Reply Surround Music Formats
