PCM 5.1 question - AVS Forum
post #1 of 19 Old 01-30-2008, 06:45 AM - Thread Starter
sdrph's Avatar
Some blu-ray discs say PCM 5.1 while other say UNCOMPRESSED PCM 5.1...Are they the same?
sdrph is offline
post #2 of 19 Old 01-30-2008, 06:47 AM
TheSimplePanda's Avatar
Yes, exactly the same:
5.1 Uncompressed =
5.1 PCM =
5.1 LPCM =
5.1 Uncompressed PCM
TheSimplePanda is offline
post #3 of 19 Old 01-30-2008, 08:08 AM
joe277's Avatar
I second that.
CAV Installations
URC Total Control  -  Vantage  -  Monitor Audio  -  Autonomic  -  Fusion Research  -  TiVo
joe277 is offline
post #4 of 19 Old 02-17-2008, 10:40 PM
MattS90's Avatar
will your DD 5.1 be uncompressed if you use HDMI and have loseless sound?
MattS90 is offline
post #5 of 19 Old 02-18-2008, 02:16 AM
William's Avatar
Liked: 35
DD stands for Dolby Digital and is compressed and lossy format. While it is uncompressed after decoding it is still lossy. Dolby TrueHD is compressed lossless format (as is DTS HD Master) and is lossless LPCM after uncompromising.
William is offline
post #6 of 19 Old 02-18-2008, 04:43 AM
SiriuslyCold's Avatar
Originally Posted by William View Post
... and is lossless LPCM after uncompromising.
im sure thats a typo, but its funny nonetheless
a note - If your player decodes Dolby Digital, what gets on the HDMI is also PCM, except that it is derived from a lossy source (as opposed to PCM derived from a lossless source)
if you are familiar with WAVs, FLACs and MP3s - think of it this way; the computer can only play PCM (WAV format)
so if you have an MP3, it will have to be decoded to WAV to play - the WAV is uncompressed, but it is sourced from a lossy MP3
Boo!
SiriuslyCold is offline
post #7 of 19 Old 02-18-2008, 06:38 AM
William's Avatar
Liked: 35
Originally Posted by SiriuslyCold View Post
im sure thats a typo, but its funny nonetheless ...
....but LPCM is uncompromising. Oh well I guess I should read before I post.
William is offline
post #8 of 19 Old 02-18-2008, 07:58 PM
MattS90's Avatar
i think i get it lol
MattS90 is offline
post #9 of 19 Old 02-18-2008, 07:58 PM
MattS90's Avatar
so i still need truHD for fully uncompressed ...from uncompressed source thru uncompressed hdmi audio to receiver that decodes the uncompressed truHD
MattS90 is offline
post #10 of 19 Old 02-19-2008, 04:43 AM
William's Avatar
Liked: 35
You seem to be confusing compressed with lossy (which many do). They are two different terms. Compressed means that the data stream is reduced from the origanal LPCM. Lossy is perceptually coded and has music information thrown out and missing. Lossy is always compressed but compressed is not always lossy. DD is always lossy/compressed, TrueHD is lossless/compressed, and LPCM is lossless/uncompressed. Once TrueHD is decoded it goes from lossless/compressed to LCPM lossless/uncompressed.
William is offline
post #11 of 19 Old 02-19-2008, 10:26 PM
MattS90's Avatar
i think my denon 1908 reciever does LPCM or maybe just PCM im not sure but i KNOW it doesnt do any TrueHD ... so what would be my best option?
MattS90 is offline
post #12 of 19 Old 02-20-2008, 05:46 AM
William's Avatar
Liked: 35
LPCM = (L)PCM (Liner) Pulse Code Modulation
Hook up your BD/HD DVD player by HDMI and set the player to decoded TrueHD and putput LPCM. You can chose LPCM or TrueHD from the audio menu and they will be same (all other things being equal).
William is offline
post #13 of 19 Old 02-20-2008, 02:53 PM
MattS90's Avatar
but my receiver doesnt decode TrueHD
MattS90 is offline
post #14 of 19 Old 02-20-2008, 05:30 PM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Your receiver doesn't need to decode TrueHD, the player does it. Your receiver just gets LPCM audio from the player.
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #15 of 19 Old 02-21-2008, 04:08 PM
boe
boe's Avatar
Quoted: 12 Post(s)
Liked: 48
Sorry for my ignorance but I'm still not sure I understand.
DTS -MA and DD HD usually sound great. If the disc says PCM 5.1, does that mean there was no loss at any point?
boe is online now
post #16 of 19 Old 02-21-2008, 06:33 PM
if the disc says PCM, Dolby TrueHD or DTS Master Audio there is no loss.
Boo!
post #17 of 19 Old 02-22-2008, 12:43 AM
MattS90's Avatar
shinksma
THATS AWESOME ty!
MattS90 is offline
post #18 of 19 Old 02-25-2008, 09:19 PM
mmountainbiker's Avatar
shinksma
Does that only apply to HDMI or can a optical digital cable be used?
I have a playstation 3 that decodes True HD but my receiver is not HDMI compatible
"There in no W.A.F. in my house. If She dont like it, She can live with her Mother"
mmountainbiker is offline
post #19 of 19 Old 02-25-2008, 09:53 PM
BIslander's Avatar
Liked: 122
Unfortunately, no. Toslink is limited to 2 channels of PCM. It takes HDMI to get multichannel PCM. The PS3 is not a good match for those us with older AVRs lacking HDMI.
BIslander is online now
Reply Surround Music Formats
User Tag List
