Setting Up Your SubWoofer 101 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 113 Old 03-06-2008, 07:03 PM - Thread Starter
DrPainMD's Avatar
Here are some tips on setting up your sub(s).
Subwoofer Setup, Placement and Theories
Audioholics - Crawling for Bass - Subwoofer Placement
Audioholics - Subwoofer Placement Tips for Cabinetry Installations
Audioholics - An Easy Solution To Subwoofer Calibration
Audioholics - Bass Management Basics – Settings Made Simple
Audioholics - Subwoofer Placement Guidelines
Audioholics - Subwoofer Placement - The Place for Bass
Audioholics - Connecting a Subwoofer to a Receiver
Audioholics - Connecting a Subwoofer to a Receiver with No Subwoofer Output
Audioholics - Subwoofer Calibration Using Rives Audio Test CD 2
Audioholics - Setting the Subwoofer / LFE Crossover for Best Performance
Audioholics - Subwoofer Measurement Tactics: A Brief, Topical Overview & Method Comparison
Audioholics - Subwoofer Connection Guide For A Multi Subwoofer System
Axiom Audio - How to Find the Best Place for Your Subwoofer
HTF - The Misunderstood 0.1 LFE Channel in 5.1 by Brian Florian
HTF - Sub Placement & Setup by Tom Nousaine, Chu Gai
HTF - AVIA: Subwoofer Calibration by Guy Kuo
SVS - How Do I Use A Sound Level Meter To Calibrate My Subwoofer?
HSU - Calibrate A Sub With A HSU MBM-12 Mid Bass Module By Cyberbri
Common Subwoofer Set-Up Errors by Edward J M
Subwoofer Setup Guide by Bossobass
AVS - Ed Mullen's Subwoofer Setup Tips
AVS - What's the Big Deal About Crossovers?
AVS - LFE, Subwoofers and Interconnects Explained
HT HiFi - Bass Management Woes: Trouble on the Slopes
Audio Pulse - Myths About Subwoofers
Audio Innovation - Subwoofer Design Theories
Subwoofers: Optimum Number and Locations by Todd Welti
eCoustics - 68 Subwoofer Articles
Quick and Effective Sub Placement, Period! By Carl Kennedy
Sound Thinking - Floyd E. Toole, PhD - Audio White Papers
Speaker Setup, Using SPL Meter
Techlore - How To Calibrate Your Surround System Using an SPL Meter
Audiophilia - Essential Accessories: The Radio Shack Sound Pressure Level Meter
Audioholics - Setting Speaker Levels & Distance in a Surround Sound System
SVS - Radio Shack SPL Meter Compensation Chart
AVS - Radio Shack SPL Meter Correction Tables
Shakers, ButtKickers and Tranducers
AVS - Shakers - Simple/Cheap Hookup - Visual Guide
Sound Treatments and Acoustics
Audioholics - Introduction to Acoustics
Audioholics - DIY Absorbers for the Less-than-Handy Man
Audioholics - Acoustical Measurements - What are They?
Audioholics - A Guide to Sound Isolation and Noise Control
Audioholics - Room Acoustics: Isolation & Noise Control
Audioholics - Reducing HVAC Noise in Theater Rooms
Audioholics - Early Reflections in Home Theaters: A Different Perspective
Audioholics - Building Great Bass Response In Your Home Theater
Audioholics - Audyssey Labs' MultEQ
Audioholics - The Perfect Room?
Audioholics - Room Acoustics: Acoustic Treatments
Audioholics - Acoustics 101 Course by John Dahl of THX
Audioholics - Acoustics Facts and Fiction by Ethan Winer
Audioholics - Bass Traps - Not Just for Fisherman! by Ethan Winer
AVS - Acoustical Treatments Master Thread
HT HiFi's - Acoustical Room Treatment: A Survey of Methods and Materials
Loudspeakers and Rooms - Working Together by Floyd E. Toole from Harman
Maximizing Loudspeaker Performance In Rooms by Floyd E. Toole from Harman
Audio – Science in the Service of Art by Floyd E. Toole from Harman
Jon Risch's DIY Acoustic Treatments
AVS - Video On Cutting Rigid Fiberglass for Bass Traps
Bob Gold's Absorption Coefficients
Acoustic Treatment and Design for Recording Studios and Listening Rooms by Ethan Winer
Real Traps - Acoustic Treatment Overview
ATS Acoustics - Sound Absorption and Acoustical Panel FAQ's
GIK Acoustics - Acoustics Primer - Some Basics On Acoustics
Ready Acoustics - Acoustical Primer
Sensible Sound Solutions
Sonopan Acoustics
Quiet Rock - THX Certified Drywall
Green Glue
Auralex SubDude
Owens Corning Rigid Fiberglass 700 Series Insulation
Equipment
Behringer Feedback Destroyer Pro DSP1124P
HTS - BFD Guide
HTS - BFD Links
Audioholics - Active Room Correction: A Primer to Audyssey MultEQ Pro
Sound Pressure Level (SPL) Meters
Radio Shack Digital-Display Sound-Level Meter
Radio Shack Analog Display Sound Level Meter
SVS's Radio Shack SPL Meter Compensation Chart
CHECK MATE Series Of SPL's
Software
Ovation Multimedia - Avia II: Guide To Home Theater DVD
Digital Video Essentials: Get The Most Out Of Your Home Entertainment System DVD
AVS - jeffreylebowski's Free Software for First Reflection Points
AVS - Room EQ Wizard Help Thread
HTS - Room EQ Wizard
HTS - BFD Guide
HTS's BFD Links
SPL Calculator by C.M.Collins
Harman Kardon - Waves & Modes-A Room Resonances Locater (XLS spreadsheet)
TrueRTA Audio Spectrum Analyzer
AVS - TrueRTA For Dummies
Audio Spectrum Analyzer - Spectrum Lab (Waterfall Chart)
Test Tones, DVD's
Realm Of Excursion (Download Section)
RealTraps - Test Tone CD
Bink Audio Test CD
Stay in Tune with PentaTone
AVS - DIY Audio Test DVD
VB-Audio - Sine Wave Generator - "LF Generator"
Ground Loops and Hum
Audioholics - Thinking in Isolation – A Primer on Ground Loops
Audioholics - Ground Loops - Eliminating System Hum and Buzz
HUM FAQ by Bill Lummus
Home Tech - RF Attenuators, Filters, & DC Blockers
Impact Acoustics - Isolation Transformers
For more Info on Setting Up the rest of your Home Theater, see these threads:
http://www.avsforum.com/avs-vb/showt...2#post10118822
http://www.avsforum.com/avs-vb/showthread.php?t=1045531
super dirty , super clean , pow
DrPainMD is offline
post #2 of 113 Old 03-06-2008, 07:25 PM
OvalNut's Avatar
Please, sticky this thread!
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
post #3 of 113 Old 03-06-2008, 07:27 PM
deneb's Avatar
Wow, excellent work!
+1 for making this a sticky
deneb is offline
post #4 of 113 Old 03-06-2008, 07:56 PM
NewOrlnsDukie's Avatar
Liked: 29
dang!
DrPain bringin' it. Going for sticky #2!
NewOrlnsDukie is offline
post #5 of 113 Old 03-06-2008, 08:39 PM
Pete Hul's Avatar
Very nice - thanks!
Pete Hul is offline
post #6 of 113 Old 03-06-2008, 10:08 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Now I know why you call yourself Dr Pain. You make things painlessly easy!
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #7 of 113 Old 03-07-2008, 01:10 AM
maseo503's Avatar
Great "prescription" to many questions....thanks doc!
maseo503 is offline
post #8 of 113 Old 03-07-2008, 05:34 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
Great thread, not that you don't have enough, but in case you missed it, I really
like this one
http://www.robbroy.net/HT/SubwooferErrors.cfm
Maybe you can add that one as well.
And this needs to be a sticky.
It ain't easy being green.
My System
MIkeDuke is offline
post #9 of 113 Old 03-07-2008, 05:49 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Excellent job, Pain!
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is online now
post #10 of 113 Old 03-07-2008, 06:15 AM
Dennis M's Avatar
Excellent Post Pain.
Sticky this puppy.
Toshiba HD XA2 & PS3 Owner
Format Neutrality is the place to be.
Dennis M is offline
post #11 of 113 Old 03-09-2008, 08:47 AM - Thread Starter
DrPainMD's Avatar
like this one
its there under "Common Subwoofer Set-Up Errors by Edward J M"
thanks to all for the kind words.
DrPainMD is offline
post #12 of 113 Old 03-09-2008, 08:33 PM - Thread Starter
DrPainMD's Avatar
Originally Posted by NewOrlnsDukie View Post
dang!
it would actually be #3
DrPainMD is offline
post #13 of 113 Old 03-11-2008, 05:37 PM - Thread Starter
DrPainMD's Avatar
bump back mountain
DrPainMD is offline
post #14 of 113 Old 03-11-2008, 08:36 PM
Hunter844's Avatar
Originally Posted by DrPainMD View Post
bump back mountain
Excellent efforting!
Hunter844 is online now
post #15 of 113 Old 03-11-2008, 10:28 PM
froggyliver's Avatar
Great archive of info. for noobs like me!
froggyliver is offline
post #16 of 113 Old 03-14-2008, 01:31 AM
ThePlungerMan's Avatar
I second that. I just spent over an hour reading this so far. Good thing is I know more now, bad thing is I need more answers to the more questions I have.
Thanks very much.
ThePlungerMan is offline
post #17 of 113 Old 03-14-2008, 10:05 PM
ohills's Avatar
Great thread! Lots of great info, sticky plz!!!!!
ohills is offline
post #18 of 113 Old 03-15-2008, 12:24 AM - Thread Starter
DrPainMD's Avatar
lots of sticky requests ...oh my
DrPainMD is offline
post #19 of 113 Old 03-15-2008, 12:25 AM - Thread Starter
DrPainMD's Avatar
Thanks very much.
your welcome, and welcome to SUB land!
DrPainMD is offline
post #20 of 113 Old 03-15-2008, 01:01 AM
saginawjuggalo's Avatar
Quoted: 47 Post(s)
Liked: 51
Great job.. Thanks
JVC DLA-RS40 w/003 lamp,DIY False-wall 125" acoustically transparent screen,Darbee Darblet,Sanyo PLV-Z2000 (gaming),7.1 DIYSoundGroup 1099 x3 LCR & Slanted Volt 6 rears x4,Onkyo TX-NR818,Emotiva LPA-1,Behringer EP4000 (x2),Sealed Stereo Integrity HT18"s (x8),Balanced MiniDSP,Cross·Spectrum UMIK-1,DIY Acoustic Treatments,PS3,Sony BDP-S590,Seiki SR4KP1 Region Free BDP,Toshiba HD-A1,Roku,Outdoor Antenna,APC H15 power conditioner,Harmony Smart Control,Rebuilding*HTPC,Leather Theater seating etc.
saginawjuggalo is offline
post #21 of 113 Old 03-15-2008, 07:19 AM
SbWillie's Avatar
STICKY-icky-icky!
SbWillie is offline
post #22 of 113 Old 03-16-2008, 11:29 AM
WestTownsend's Avatar
It almost made to the second page!!!
Think for yourself... Question authority!
WestTownsend is offline
post #23 of 113 Old 03-18-2008, 04:36 AM
jhan1000's Avatar
Bump and +1 for sticky.
Life is good.
jhan1000 is offline
post #24 of 113 Old 03-18-2008, 04:52 AM
Lurendrejer's Avatar
Just a guide like a bassaholic like me needs. Thanks a lot.
And, btw: Hi everyone - first post here
Search for the truth, and be wary of those that claim to have found it.
Lurendrejer is offline
post #25 of 113 Old 03-18-2008, 06:00 AM
SbWillie's Avatar
welcome
SbWillie is offline
post #26 of 113 Old 03-19-2008, 06:27 AM - Thread Starter
DrPainMD's Avatar
DrPainMD is offline
post #27 of 113 Old 03-19-2008, 01:07 PM
jr07's Avatar
Hey great post thanks
I have a questions regarding the connection of my sub woofer
My amp has the Sub woofer out single RCA plug, but my subwoofer has a left / right RCA input on the back. To which of them should I connect it? Or should I use a cheap Y connection to make the single output from the receiver connect to both left and right on the sub?
thanks
J
jr07 is offline
post #28 of 113 Old 03-19-2008, 02:29 PM - Thread Starter
DrPainMD's Avatar
thanks
J
just hook it up to the left. btw what sub do u have?
DrPainMD is offline
post #29 of 113 Old 03-19-2008, 04:39 PM
jr07's Avatar
Mission 70as
I love it, its a big black mean looking machine box,.
but Im not sure Im getting the most out of it. I dont know what the X Over and Phase knobs are for, for instance, and Im not sure if it should be connected from the Subwoofer out RCA of my Dolby prologic HK AVI 250 or from the Subwoofer Out RCA plug of my HK ADP DD processor!
J
jr07 is offline
post #30 of 113 Old 03-24-2008, 04:16 PM - Thread Starter
DrPainMD's Avatar
bump
DrPainMD is offline
