Phase Control on SVS sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 03-17-2008, 10:00 AM - Thread Starter
sourbeef's Avatar
Liked: 25
I have a Phase Control knob on my SVS SB12-plus. It has been all the way to the left (on zero) since I got the sub a few weeks ago. What is the significance of this setting? The owners manual has a brief paragraph about it but it does not tell me anything useful. Is it recommended to move this knob to another position for movies or music?
TV - Panasonic 58PZ700U plasma
L/R - Ascend Sierra Towers with RAAL Tweets in piano black
C - Ascend Sierra Horizon with RAAL Tweet in piano black
Surr - Polk Fxi-A6
Sub - SVS PC-13 Ultra
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #2 of 22 Old 03-17-2008, 11:57 AM
mojomike's Avatar
Liked: 30
The phase adjustment has nothing to do with a movies or music dependent setting. It has to do with how your sub and your main speakers blend at the area of the crossover. The easiest way to properly set the phase would be to play a test tone that is close in frequency to the crossover point. Slowly turn the phase knob to the point at which the output is the loudest. That could very well be at "0", but not necessarily.
mojomike is offline
post #3 of 22 Old 03-17-2008, 12:19 PM
chartwel's Avatar
its a little more easier in my opinion to reverse the black and red wires to your fronts and then play the test tone and look for the output to be lowest. then put the speakers wire back correctly and you will be set. well, that was easiest for me, it was hard to find the loudest point in my opinion.
chartwel is offline
post #4 of 22 Old 03-17-2008, 12:23 PM
OvalNut's Avatar
Either of the above methods works fine, but don't try to do it by ear. Get an SPL meter to measure the output, then follow either of the 2 methods above.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
post #5 of 22 Old 03-17-2008, 01:26 PM - Thread Starter
sourbeef's Avatar
Liked: 25
So if I were to persue this, I would need one of those calibration discs people often mention on here in order to get a test tone in the desired frequency? In other words, the generic test tone from my Onkyo 705 receiver wouldn't probably be the desired frequency to start with.
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #6 of 22 Old 03-17-2008, 02:08 PM
mojomike's Avatar
Liked: 30
You can download the test tone that you need form here:
http://www.ronelmm.com/tones/
Then you can burn it to a disc and run it through your system. A word of caution: When using sine waves or test tones, make sure they are used at reasonably low levels so you don't damage anything. 80db is a safe level.
mojomike is offline
post #7 of 22 Old 03-17-2008, 03:07 PM - Thread Starter
sourbeef's Avatar
Liked: 25
You have a lot of faith in me.
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #8 of 22 Old 03-17-2008, 03:14 PM
mojomike's Avatar
Liked: 30
C'mon. You can do it.
mojomike is offline
post #9 of 22 Old 03-17-2008, 05:02 PM
Brewed's Avatar
Is it logical for me to assume that using either of these methods for phase control (loudest/softest) that the mains are set to SMALL in the pre/pro?
This sounds like a great tweak for my new PC Ultra 13. Perhaps a little more pace and rhythm from my system.
Brewed is offline
post #10 of 22 Old 03-17-2008, 06:36 PM - Thread Starter
sourbeef's Avatar
Liked: 25
If I do this, will I be listening for the subwoofer to be at its softest point. Should I be listening for any cues coming from the fronts (assuming it is even safe to cross black/red lines like that)? I can only imagine the theory behind this....how does this sound....by "messing up" the sound of the fronts, and lining up the sub to be at its weakest point, then this somehow puts the fronts and sub in proper sync or phase or whatever
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #11 of 22 Old 03-17-2008, 06:46 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Or you can leave the speakers wired "normally", adjust the output to be lowest, then add or subtract (whichever is appropriate) 180° from the result and adjust the knob accordingly.
The idea in this case, sourbeef, is to intentionally wire the speakers out-of-phase, set the knob to the setting that produces the LOWEST output, then flip the speaker's polarity back to "normal", which should then realign the sub and speakers' phase properly, and (in theory) provide the highest output.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #12 of 22 Old 03-17-2008, 07:10 PM - Thread Starter
sourbeef's Avatar
Liked: 25
This is what I need clarification on. After I switch the red/black wires on the fronts to put them out of phase, what am I listening to or for? A test tone only to the subwoofer
to be at its weakest point? I guess I should also ask, does it matter which end of the speaker wire I switch, the red/black end that goes into the speakers, or the red/black end that is connected to the receiver?
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #13 of 22 Old 03-17-2008, 07:15 PM - Thread Starter
sourbeef's Avatar
Liked: 25
Not that I doubt your word on this, but this goes against the conventional wisdom which says.... 2 wrongs don't make a right
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #14 of 22 Old 03-17-2008, 07:18 PM - Thread Starter
sourbeef's Avatar
Liked: 25
Ed Mullen, if you are out there, can you or one of your techs address this?
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #15 of 22 Old 03-17-2008, 07:23 PM
Hot Grits's Avatar
If you type setting phase on subwoofer in google. Almost every page gives the same advice that sivadselim gives.
Hot Grits is offline
post #16 of 22 Old 03-17-2008, 07:31 PM - Thread Starter
sourbeef's Avatar
Liked: 25
Like I said I do not doubt he knows what he is talking about. But I still like to do things that make sense to me before I do them.
Surr - Polk Fxi-A6
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #17 of 22 Old 03-17-2008, 07:47 PM
Hot Grits's Avatar
which test tones do you recomend using? Everything in the 20 - 80 hz range?
post #18 of 22 Old 03-17-2008, 08:09 PM
mojomike's Avatar
Liked: 30
For phase setting, it's best to use a tone that is close or the same as the crossover frequency.
mojomike is offline
post #19 of 22 Old 03-17-2008, 08:31 PM
Hot Grits's Avatar
Thanks for the quick reply. Burning this in mp3 format to a cd would work fine?
post #20 of 22 Old 03-17-2008, 08:44 PM
mojomike's Avatar
Liked: 30
If your CD or DVD player plays Mp3 files, you can burn it as a data file. If not, burn it as an audio CD which will play on anything that plays CDs.
mojomike is offline
post #21 of 22 Old 03-18-2008, 10:50 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
So, do your own research so that it will "make sense" to you.
Why don't you go straight to the source and email SVS?
post #22 of 22 Old 03-18-2008, 12:02 PM
John Ballentine's Avatar
Yep - whenever I e-mail them - they always get back to me ASAP. SUPERB customer service.
John Ballentine is offline
