Whats the purpose of pressurizing a room with a sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-14-2008, 10:46 PM - Thread Starter
terminatorbob's Avatar
I hear a lot of talk about making sure the sub is able to pressurize the room you are putting it in. What does this do exactly? If the sub can't pressurize the room what are you missing?
Panasonic TH-42PH9UK
terminatorbob is offline
post #2 of 5 Old 04-15-2008, 08:36 AM
combos99's Avatar
Envelopment and realism, When an explosion happens in a movie, most people want FEEL it. Pressurizing a room does exactly that.
I like turtles.
combos99 is offline
post #3 of 5 Old 04-15-2008, 12:08 PM
Ethan Winer's Avatar
Quoted: 267 Post(s)
Liked: 363
Pressurize refers to frequency versus room dimensions, and the term is often tossed around incorrectly. At very low frequencies, where a single wavelength cannot fit in the longest dimension, the frequency can still be heard. But instead of being a true wave it's a change in pressure. For example, a 40 Hz wave is 28'3" long, so playing 40 Hz in a room shorter than that will "pressurize" the room. That's an overly simple explanation, but hopefully makes the point.
What really matters with subwoofers are:
1) How low in frequency they can play to
2) How loudly they can play
3) How much distortion they produce at various sound levels
--Ethan
Ethan Winer is offline
post #4 of 5 Old 04-15-2008, 12:27 PM
MKtheater's Avatar
Quoted: 1756 Post(s)
Liked: 1348
Like the others have said, It creates a real environment like you are there. I remember when I was at a restaurant and a big dump truck pulled up to the stop light. It was at idle, the windows were shaking, the room just pressurized, and you can just feel its prescence(from 30 feet away). That is what to strive for, real events in your HT.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is online now
post #5 of 5 Old 04-15-2008, 12:42 PM
OvalNut's Avatar
Like the others have said, It creates a real environment like you are there. I remember when I was at a restaurant and a big dump truck pulled up to the stop light. It was at idle and the windows were shaking and the room just pressurized and you can just feel its prescence(from 30 feet away), that is what to strive for, real events in your HT.
Applause ... Applause! That's exactly it.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
