Best sub EQ under $400 - Page 60 - AVS Forum | Home Theater Discussions And Reviews
post #1771 of 1785 Old 07-03-2013, 03:11 PM
David Susilo's Avatar
Quoted: 628 Post(s)
Liked: 590
Oh forgot. If you use Paradigm, the PBK (Perfect Bass Kit -- essentially Anthem's ARC but for 150 Hz and lower only) is the best.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #1772 of 1785 Old 07-03-2013, 04:16 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 806
Originally Posted by David Susilo View PostOh forgot. If you use Paradigm, the PBK (Perfect Bass Kit -- essentially Anthem's ARC but for 150 Hz and lower only) is the best.
Too bad it doesn't work with other subs!
wse is offline
post #1773 of 1785 Old 07-03-2013, 04:30 PM
Quoted: 628 Post(s)
Liked: 590
Yeah. I've been bugging Paradigm to sell a universal PBK module such as DSPeaker to no avail frown.gif
my home theatre
post #1774 of 1785 Old 10-15-2013, 05:50 AM
saprano's Avatar
Quoted: 552 Post(s)
Liked: 547
Does simplify audio not carry the 8033S-II? I don't see anything about it on their site. And the only specs the they list are from the old 8033 model.
home theater addict
saprano is online now
post #1775 of 1785 Old 12-10-2013, 07:30 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4008
I have a SC-61 Elite coming and am looking at the 8033Cinema for my VTF15, and I think I may have asked this question in the wrong thread.
Do I understand correctly that I just run the 8033 setup first, then run MCACC after the 8033 has eq'd the sub? Does the sub gain have any bearing on the 8033 calibration, or is it OK to adjust once MCACC is complete? Is there anything to turn off or on in MCACC to no conflict what the 8033C is doing to the sub signal already?
gadgtfreek is offline
post #1776 of 1785 Old 12-10-2013, 03:27 PM
Quoted: 628 Post(s)
Liked: 590
Yes, you run the 8033 first , then run FULL AUTO MCACC, then go to manual speakef settings to fix crossover points, speaker size, set subwoofer to PLUS and also fix distances EXCEPT FOR SUBWOOFER.
my home theatre
post #1777 of 1785 Old 12-10-2013, 05:42 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 721
It is my understanding that EQ should be the last step in the chain. Running EQ before MCACC may lead to a change in the phase adjustment and time alignment after MCACC standing wave correction. Also, changing the distance set by MCACC will change the sub's response in the room. The distances set by MCACC do not have to match up with measured distances since it is based on the time it takes the bass to reach the mic in phase with the rest of the speakers.
I don't use this form of EQ for my Pioneer Elite avr but, I have found that trying to EQ to a flat response may not give the best results. I don't think you can treat the MCACC program like the people do with Auddysee. MCACC and Auddysee do not approach bass management in the same way. The standing wave function can do some things for the bass in the room that EQ cannot do.
derrickdj1 is offline
post #1778 of 1785 Old 12-10-2013, 06:31 PM
Quoted: 628 Post(s)
Liked: 590
Hence the running of 8033 and MCACC together.
my home theatre
post #1779 of 1785 Old 02-24-2014, 02:10 AM
jaydee2008's Avatar
Hi.
New behringer shark fbq100. Is this a cheaper option of the 8033?
jaydee2008 is offline
post #1780 of 1785 Old 02-24-2014, 04:07 AM
Quoted: 75 Post(s)
Liked: 112
Under $400 the Antimode gets my vote. The MiniDSP is good too for much less.
rnatalli is offline
post #1781 of 1785 Old 02-24-2014, 04:24 AM
ambesolman's Avatar
Quoted: 1098 Post(s)
Liked: 921
Doesn't minidsp work for the whole freq band but the 8033 just the bass?
ambesolman is offline
post #1782 of 1785 Old 02-24-2014, 05:24 AM
bear123's Avatar
Quoted: 1804 Post(s)
Liked: 2679
MiniDSP can be configured to work over any frequency range, but is more often used for subwoofer, and allows the AVR to eq above the crossover.  There are different types of miniDSP.  The common one for subs is called the 2 x 4 version, which has 2 inputs and 4 ouputs.  It works very well with REW.  I spent a couple hours with mine eq'g my new sub and will be experimenting a lot this Wednesday.  The first result I got was pretty good though, even though I think I can get my response a lot flatter.
bear123 is offline
post #1783 of 1785 Old 02-25-2014, 05:58 PM
mbartok's Avatar
Originally Posted by jaydee2008 View Post
Hi.
See Q & A in the attached link to the part listed on Parts Express. "This unit does not have a pmanual parametric EQ function like the other feedback destroyers that are used for this, so unfortunately it will not work for that application."
http://www.parts-express.com/behringer-fbq100-shark-automatic-feedback-destroyer--248-6676
mbartok is offline
post #1784 of 1785 Old 02-25-2014, 06:26 PM
jaydee2008's Avatar
Thanks mbartok. Good answer, that is what I throught it could do for a single subwoofer eq but i was wrong. and looks like anti-mode 8033cinema is the most ecomical and ease of seting up solution. Unless someone else have better value solution for single sub. cheers
post #1785 of 1785 Old 02-26-2014, 01:39 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
Got a 8033Cinema but would like if it outputted responses prior to any EQ and also after. That way I could use it as a stand alone unit to see if the other systems need an EQ. Would pay an extra £30 or so if it had a micro SD card so it saves responses. Can then disconnect the card, save the files, move AM to another system, do it again, take it round brothers etc.
fatbottom is offline
Room Equilizer Wizard Rew
