Looking for a ~$400 sub for music, large room - AVS Forum | Home Theater Discussions And Reviews
Old 08-15-2008, 08:35 PM - Thread Starter
delmexi's Avatar
Thanks for all the help.
delmexi is offline
Old 08-17-2008, 12:39 AM
deneb's Avatar
Is it possible to put your theater on the short wall (the 12' wall) rather than the long wall as it's oriented currently?
deneb is offline
Old 08-17-2008, 02:51 PM - Thread Starter
delmexi's Avatar
Thanks for replying. Unfortunately, that's not possible. There's a lot of furniture set up in the surrounding area, and there's a closet in that wall that I need access to.
At this point, I'm mostly trying to decide between an A2-300 and a HSU STF-2, unless anyone has another suggestion. I'm at a total loss for one over the other.
delmexi is offline
Old 08-25-2008, 03:21 AM - Thread Starter
delmexi's Avatar
I'm about to pull the trigger on a HSU VTF-2 MK3. Anyone have a better suggestion for ~$610 shipped?
delmexi is offline
Old 08-25-2008, 04:44 AM
warlord260's Avatar
your buget sure did change
if you could scrape $100 more i would think the epik knight
would have lots of slam in that room
warlord260 is offline
Old 08-25-2008, 02:20 PM - Thread Starter
delmexi's Avatar
My budget is a little flexible, but not that flexible. $600 is a hard limit.
The only other thing I'm considering at this point is an Epik Valor. How would that stack up against a HSU VTF2.3?
delmexi is offline
Old 08-25-2008, 04:20 PM
VectorLabs's Avatar
Quoted: 71 Post(s)
Liked: 50
What about the SVS PB-12NSD? It measures extremely well and would probably do very well in your room.
Check the B-stock section at SVS to see if they have some you can get for less than $600.
Edit: b-stock for $519 https://svsound.com/store/index.cfm?...category_ID=12
VectorLabs is online now
Old 08-26-2008, 08:37 AM
Kinnithy's Avatar
i just picked up a used def tech supercube 1 for a lil under 300 to my door...
that thing can rock if you want something small and punchy with decent low freq response.
Kinnithy is offline
