kicker solo baric s12d 12" 8 ohm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 08-17-2008, 11:47 PM - Thread Starter
insanedrunk's Avatar
anyone got some specs on these oldschool round solo barics, they have been sitting in my garage and i wanted to get them running, on the back of them there is a sticker that states that they are 8 ohm. please any input would help, thanks in advance. peak watts? rms?
insanedrunk is offline
post #2 of 19 Old 08-18-2008, 05:56 AM
_Noah_'s Avatar
I just did a quick search and couldn't find any specs. You should just email Kicker. I owned a pair of L7 Solobarics and they were rated at 750rms/1500peak each. I seem to think that the round style was around 400-500rms/1000peak, if that helps.
_Noah_ is offline
post #3 of 19 Old 08-18-2008, 10:47 AM - Thread Starter
Thanks ill try but im open to more help, i have researched before i posted, but also found nothing.
post #4 of 19 Old 08-18-2008, 11:01 AM
datgai's Avatar
Did you email kicker?
You might have more luck down in the Car Audio Forum
datgai is offline
post #5 of 19 Old 08-18-2008, 11:22 AM - Thread Starter
thanks for bringing that to my attention, i will ask in the car audio aswell.
post #6 of 19 Old 08-18-2008, 04:26 PM
CannondaleSV's Avatar
I had a set of those subs hooked in parallel to a 1200 watt amp in a .66cf per sub box.
CannondaleSV is offline
post #7 of 19 Old 08-19-2008, 12:18 AM - Thread Starter
thanks, im guessing that you wired them in parallel to get them down to 4 0hms?, now i know what range of amplifier to use, thanks CannondaleSV and to all that helped or will be helping..
post #8 of 19 Old 08-20-2008, 12:55 PM
2003cobra's Avatar
I had a pair when I was in highschool. They were 4 ohm each and wired them paralell to make 2 ohm lead on a PPI a600....600x1 4ohm. It was a rockin setup. That old school PPI metered at 850 rms power output, and my Solobaric 12's hit really nice and are a VERY accurate sub. If I had thoes I would get into my car or design the right box and make a home sub out of them ( again very accurate ). Oh the good old days.
2003cobra is offline
post #9 of 19 Old 08-20-2008, 03:05 PM - Thread Starter
More pictures, to help you guys help me, ive seen the 4 ohm from the bottom, it looks different, any matter, do the 4 and 8 ohm models have the same rms rating?
post #10 of 19 Old 08-20-2008, 07:23 PM
scotthulbs's Avatar
wanna sell em???
scotthulbs is offline
post #11 of 19 Old 08-22-2008, 09:11 AM
IAMSMOOVE's Avatar
Here are some specs...
No matter which ohm 2, 4, or 8, the max rms power handling is 600 watts.
Recommend sealed enclosure is .88 cu.ft.
Minimum sealed enclosure is .66 cu.ft.
Mounting depth for sealed is 5-5/8.
These speakers can also be placed in a bandpass box, I don't have the specs, will need kicker to fax them to you.
FYI concerning the power handling
I've installed these speakers many times, and have put some serious wattage towards them and form what I can tell, the more wattage you give them, the better they perform.
My setup is all old school (cause thats when amps were real amps),
Phoenix Gold Titanium series 1000 watt amp, pushing 3 kicker 12 solo's. All 8 ohm which made a 2.66 ohm load, which was mono'd makin it a 1.33 ohm load.
2 wordS, FKN INSANE!!!
BTW, if you want to sell them, I'll buy them hands down, I'm looking to repeat
my system for another car of mine. If you dont get around to installing them, keep me in mind. Hope this helps...
IAMSMOOVE is offline
post #12 of 19 Old 08-22-2008, 06:55 PM - Thread Starter
Thanks for the help IAMSMOOVE, i want to build the box and install them to feel accomplished, maybe ill consider selling them, im not to sure... ill report back once im done building a box for them.
post #13 of 19 Old 08-22-2008, 10:29 PM
scotthulbs's Avatar
If you decide to sell be sure to PM me!
post #14 of 19 Old 08-25-2008, 12:54 PM - Thread Starter
i have one last last question, can a 4 ohm amp handle an 8 ohm load? i have a hitron 1400 watt amp 2 channel, i want to test them directly 8 ohm load, then in Parallel on it before i buy a good amp
post #15 of 19 Old 08-25-2008, 01:18 PM
oachalon's Avatar
nice find on those subs. Those were very good sq subs and they also got loud.
oachalon is offline
post #16 of 19 Old 08-25-2008, 02:02 PM
Down's Avatar
Ah, the old PPI Art series WERE great amps.
Down is offline
post #17 of 19 Old 08-25-2008, 05:13 PM
Yes the amp will only put out about half the rated power as in 4 ohm, but you can then hook the two 8 ohm in parallel and then be at your four ohm load.
Down I had some of the Art Series and still have a couple of the Pro Mos PPI amps.
post #18 of 19 Old 08-26-2008, 10:33 AM
brimorga's Avatar
I've got a 15" one of these in a sealed box sitting in storage. Was considering buying a HT sub but this thread has got me inspired, plus it will fit perfectly behind a chair in the corner. Any recommendations for a cheap, preferably used amp to power a 4ohm version of one of these? I'm thinking <$200 or as cheap as possible. Only need to drive 1 channel and it's a stopgap solution for now.
brimorga is offline
post #19 of 19 Old 11-09-2008, 07:59 AM
IAMSMOOVE's Avatar
If the amp is 4 ohm stable, it will have no problem handling 1 8 ohm speaker. Now if 2 - 8 ohm speakers are hooked up in parallel your amp will read a 4 ohm load, and if that is bridged, you now are running 4 ohm mono, which is the same as 2 ohm stereo. In this case you would want a 2 ohm stable amp. Example as follows...
600 x 1 (mono) = 300 x 2 (stereo)
So to future explain, if you have 1 - 4 ohm speaker bridged, you will get the same power as if you have 2 - 2 ohm speaker series. note: (Most amplifiers have peak ratings for 4 ohm mono loads cause this is the ideal load you want for your speakers, the lower the load, the less control you will actually have of your speakers. With that being said, you will usually get more power out to the amp in a 4 ohm mono vs. a 2 ohm series.)
Unless its the cheapest amp I've ever seen (even though its 4 ohm stable), testing the speakers with that amp should not fry the amp. The fuse should blow b4 that happens. Long term, get a better amp, bass peaks may trip the amp to protection mode or blow the fuse.
fyi... the person that had that PPI amp was running a 1 ohm load (back then, that was the best quality amp made.
Any more questions I'll be happy to help, btw I do take tips =]
