Ported box size for 2 Jl 12w3 - AVS Forum | Home Theater Discussions And Reviews
Old 09-12-2008, 11:18 AM - Thread Starter
saad813's Avatar
I wanted to make a ported box for my 2 jl 12w3v3. I found a calculator for the dimensions and it gave me the following:
Depth- 16.26 inches
Height- 43.9 Inches
Width- 27.1 Inches
To me this seem a bit too much, as my boot is only 23 inches in height.
Does this mean i will have to face my subwoofers facing up?
the box needs to be 11.515 Cubic feet in volume.
according to the calculator i need to tune the port to 21.92 hertz and i wanted to know how i find out the size of the port vent.
saad813 is offline
Old 09-12-2008, 11:41 AM
MIkeDuke's Avatar
Quoted: 466 Post(s)
Liked: 190
You may want to post that here
http://www.avsforum.com/avs-vb/forumdisplay.php?f=155
DIY
It ain't easy being green.
My System
MIkeDuke is offline
Old 09-12-2008, 01:33 PM - Thread Starter
saad813's Avatar
oh yes thanks for tht
saad813 is offline
