Thinking of upgrading from Mirage S12 to Paradigm Seismic 12 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-23-2008, 03:32 PM - Thread Starter
ocZZZZ's Avatar
I have a fairly large room and have been thinking of upgrading from my current Mirage s12 to a Paradigm seismic 12. I recently picked up some studio 100's and studio-cc center and it would be nice to stick with Paradigm. My question is: do you think this would be a significant improvement over my current sub? I am looking to spend around 800 for the seismic 12. Thanks in advance for any feedback.
ocZZZZ is offline
post #2 of 10 Old 09-23-2008, 05:23 PM
Toolatecrew's Avatar
If your room is large do you have a requirment for the sub to take up a small floorspace?
Studio 100s are big speakers but maybe you have other limitations that require a small footprint sub. If so then my opinion is yes there would be an improvment.
If you do not require a small footprint then my opinion is that you will get much more improvment and fill a large room much better with bass if you spent your $800 elsewhere. Paridigm make a fine sub. I've had several. The seismic sues some excelent technology to get big sound from a small box. But you are paying for that technology just like you pay more $ for a compact laptop then for a much more "powerful" desktop. I'm not goiong to recommend a specific sub as this has been done over and over. If you have more floor space look at some of the internet direct sub manufacturers and buy a fukll sized $800 sub from them (or even 2 depending on what you pick) to fill a "large" room .
Toolatecrew is offline
post #3 of 10 Old 09-24-2008, 06:26 PM - Thread Starter
ocZZZZ's Avatar
Thanks for the advise/feedback. Can anyone else speak to this sub?
ocZZZZ is offline
post #4 of 10 Old 09-24-2008, 07:12 PM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Based on everything I've read about it, I'd agree. If you can fit a larger sub in your room, get that vs. the Seismic. Actually, I think the Mirage S12 would be a better performer than the Seismic in your large room.
For $800 you can get:
SVS PB12NSD
AV123 MFW-15 (what I would choose if I were you)
HSU VTF3
Several others that would do much better than the Seismic.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #5 of 10 Old 09-24-2008, 08:37 PM - Thread Starter
ocZZZZ's Avatar
Also thinking of a used HSU Research vtf-2 mk2. Would that be a pretty nice upgrade or about the same as the S12?
ocZZZZ is offline
post #6 of 10 Old 09-25-2008, 10:54 AM
warpdrive's Avatar
Liked: 48
the vtf-mk2 is about the same. The VTF3 Mk2 is a slight improvement.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #7 of 10 Old 09-25-2008, 11:56 AM
Redskin's Avatar
I have owned a lot of small subs in the past, and the Seismic 12 was the best one I owned. I now own the JL F113, but that is an entirely different league. The Seismic did a great job in my 3000 cubic foot room.
Redskin is offline
post #8 of 10 Old 09-25-2008, 02:06 PM - Thread Starter
ocZZZZ's Avatar
Thanks for the feedback everyone. I think I am going to go with the Outlaw LFM-1 EX for 600 or so. It's a better deal than the used seismic 12 and I like how it's also downfiring.
ocZZZZ is offline
post #9 of 10 Old 09-25-2008, 02:08 PM
cacihome's Avatar
Quoted: 37 Post(s)
Nice
Cacimar Hernandez
cacihome is offline
post #10 of 10 Old 09-25-2008, 02:14 PM - Thread Starter
ocZZZZ's Avatar
I am actually torn between the Outlaw and A3 - 300. I like the smaller form factor of the a3-300 but that month wait doesn't sound so hot.
ocZZZZ is offline
