"YOUR" subwoofer picture thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 298Likes
post #541 of 2739 Old 04-11-2009, 12:32 PM
counsil's Avatar
Originally Posted by Kain View Post
Do you have any problems with localization? With the subwoofers that close, can you feel the "wind" coming from that corner?
Not really. I think the pictures make the subwoofers look closer than they really are. They are 7.5' from the corner back of the couch. I used the center cushion as my 1st (main) listening position and Audyssey measured the subs as 9' away, which is spot on. I have never felt any wind in my hair when I am sitting on my couch. I sure can feel the bass on my back though.
When I play sine wavs I have a really hard time telling where all the bass is coming from. I have my mains set to large (they are rated +/- 3dB at 25hz - 20khz) and lfe+mains turned on. I have to go feel the subwoofers on my mains to determine if they are moving. Sometimes they aren't moving but the bass from the subs are rocking the front walls. The bass along all of my walls is crazy though for some reason (probably physics).
There is a lot of wind back there though. Once when I was measuring KFP at -5 MV at my main listening position, the wind from the sub blew the SPL meter over. It was 113dB in case you're wondering.
Never argue with an idiot; they drag you down to their level and beat you with experience.
Counsil Basement HT
counsil is offline
post #542 of 2739 Old 04-11-2009, 12:34 PM
counsil's Avatar
Originally Posted by otk View Post
my thinking was having all the ports near the floor and having the ports and drivers closer to each other might produce better "coupling" between the 2 subs. plus the "combined subs" might "couple" with the room more evenly because the bottom sub gets a bit more room loading than the top sub
couldn't hurt (except for your back) to try it
who knows, could make things worse or better
I'll have to try that one of these days. These subs are heavy and Audyssey takes 30 minutes minimum to do in all 8 positions. I'd also like to try the 15hz mode too.
Counsil Basement HT
counsil is offline
post #543 of 2739 Old 04-11-2009, 04:14 PM
hoopsrgreat's Avatar
Quoted: 47 Post(s)
Liked: 63
I bought the first A7S-450 (customized) and I did the exact same thing.
MJG100,
I know you did, I actually PMd prior to placing my order as I had a few questions for you.
ED did a great job. Mow I just need my brother-in-law to make a minor fix to my door. The hinge is on the inside, and the door will no longer fit with the sub in there. I need to make the door where it will pop on now. I do not want to use the screen that came with the sub. My door looks much better and matches the other side of the ET center.
I must say, I am liking the way things are shaping up. I can only see myself replacing mains at this point, and then I am done with sound.
Then a projector, and then........
You all know how it works
hoopsrgreat is offline
post #544 of 2739 Old 04-12-2009, 08:03 AM
simplemath's Avatar
Something that you can try real quick is. Turn the 2 subs as they are a wee bit to the right, so that they are parallel to the side wall and the couch. I have found the frequency sweeps with sub turned into the room vs parallel gives a fairly lumpy output with certain frequencys. The other spot might be 90 degrees making it fire behind the couch across the back, perpendicular to the side wall.
simplemath is offline
post #545 of 2739 Old 05-06-2009, 11:11 AM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 36
so who is the winrar?
ssabripo is offline
post #546 of 2739 Old 05-06-2009, 11:32 AM
Hksvr4's Avatar
Quoted: 29 Post(s)
Liked: 37
Thanks for digging this up!!
Hksvr4 is offline
post #547 of 2739 Old 05-06-2009, 11:35 AM
Safeezy's Avatar
The Dragon looks nasty!! Congrats on the new family member.
Safeezy is offline
post #548 of 2739 Old 05-06-2009, 11:47 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5445 Post(s)
Liked: 4375
I sure like that Dragon sub driver. Almost as if the Maelstrom-X and a TC driver had a baby. A big baby.
Scott Simonian is offline
post #549 of 2739 Old 05-06-2009, 12:03 PM
HyperM3's Avatar
Finally got my Submersive in place:
HyperM3 is offline
post #550 of 2739 Old 05-06-2009, 12:08 PM
mikeloxlong's Avatar
Liked: 146
^^^heard that at the Chicago AVS meetup with Mark Seaton him self (he was demoing his new sat-sub combo and it sounded wonderful! that is one powerful air pusher!
I also like the front/back design. Pretty slick (forgive my ignorance if that design was used somewhere else before, I'm new to all of this higher end stuff)
I Geez Zeus Me
My life is richer for not knowing what goes on on reality television
mikeloxlong is offline
post #551 of 2739 Old 05-06-2009, 12:11 PM
Hksvr4's Avatar
Quoted: 29 Post(s)
Liked: 37
Thanks. It doesn't seem crazy with the grill on because of the small cabinet. When you remove the grill and see the driver, it's a beast. Showed my friends and not much to see until I take the grill off. It's "wow" every time. Tight, deep, effortless, and clean bass just to sum it up.
Scott Simonian: I've seen those drivers before and can relate.
Hksvr4 is offline
post #552 of 2739 Old 05-06-2009, 05:41 PM
storman's Avatar
Okay, I'm sure you're all bored with seeing yet another SVS PB13 Ultra picture but, gosh, ain't she purdy ?
Bill
storman is offline
post #553 of 2739 Old 05-06-2009, 05:44 PM
storman's Avatar
Sorry, somehow the attachment didn't take.
Try, try again. Oh, forgot to click on upload !
Bill
storman is offline
post #554 of 2739 Old 05-06-2009, 06:07 PM
mangosalsa's Avatar
man I love this thread!
mangosalsa is offline
post #555 of 2739 Old 05-06-2009, 06:23 PM
sivadselim's Avatar
Quoted: 193 Post(s)
Liked: 162
What speaker is that next to her?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #556 of 2739 Old 05-06-2009, 06:39 PM
Snowmanick's Avatar
Quoted: 268 Post(s)
Liked: 384
Looks like a Vandersteen 2 Ce or 3A.
~Nick
"Every loaf of bread is a tragic tale of grains that could've become beer.......but didn't...."
"If it works the first time, it's not high end." ~ Harry Pearson
Snowmanick is offline
post #557 of 2739 Old 05-06-2009, 06:39 PM
Art Sonneborn's Avatar
Quoted: 268 Post(s)
Liked: 330
Four Seaton Submersives behind my 14' wide Stewart AT screen.
My HT
Art Sonneborn is offline
post #558 of 2739 Old 05-06-2009, 06:51 PM
adidino's Avatar
Quoted: 345 Post(s)
Liked: 273
Nice pic. How tall is that foam wedge bass trap? I'm looking for something 12 inches.
adidino is offline
post #559 of 2739 Old 05-06-2009, 07:58 PM
TheFactor's Avatar
Liked: 106
My pride and joy Will update with metal grill this weekend
TheFactor is offline
post #560 of 2739 Old 05-06-2009, 08:14 PM
Hksvr4's Avatar
Quoted: 29 Post(s)
Liked: 37
Nice finish on the Ultra factor!
Hksvr4 is offline
post #561 of 2739 Old 05-06-2009, 08:18 PM
storman's Avatar
Bingo ! My venerable 2 Ce's. Had them for 15 years. They throw an amazing soundstage. The neat part about the black fabric wrap is that they also visually disappear when the light's go out in my HT room - no light reflections off the cloth, and the wall behind them is painted flat black. When we watch movies, you just don't see them.
Bill
storman is offline
post #562 of 2739 Old 05-06-2009, 08:24 PM
storman's Avatar
Geez Art, that's just baaaad. 4 submersives ! 14' wide screen !
You had Mark set them up, didn't you ? Are those LCRs made by him too ?
I've seen other pictures of your room - you must have one of the best HT's among the members.
Is it hard to leave home and go to work with a room like that ?
Bill
storman is offline
post #563 of 2739 Old 05-06-2009, 08:28 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Current system: 4-2x15" dual opposed sealed subs, 1-2x12" dual opposed sealed sub and 1-20x6.5" push/pull sealed MBM all driven by 13,000 watts and flat in-room to 3Hz.
Newest sub, bamboo finish 2x15":
Rear Panel:
2X12" in oak:
The Raven 2x15":
The Executive 2X15":
Box 2X15":
20x6.5" push/pull MBM:
Bosso
bossobass is offline
post #564 of 2739 Old 05-06-2009, 08:51 PM
WormInfested's Avatar
Quoted: 70 Post(s)
Liked: 50
Holy Crap on those cylinders of doom above me. Must have cost a bit but how do they sound? first time seeing something like that. and that odd last pic.
Pioneer Elite SC-05
JBL Studio S312II fronts, JBL Studio S10IIs mid and S8IIs rear.
Single JBL S38 center channel
Power Sound Audio V1800, 2 MFW-15's, DIY ported UM18-22, Prosub 800
Oppo BDP-103
BenQ W7500 & Silverticket 110" matte white 16:9
WormInfested is offline
post #565 of 2739 Old 05-06-2009, 08:55 PM
TheFactor's Avatar
Liked: 106
Thanks bro now if I had a 18 inch woofer like yours i'd really be cooking
post #566 of 2739 Old 05-06-2009, 08:57 PM
TheFactor's Avatar
Liked: 106
WOW That is a monster , very nice I can feel the bass just looking at it
post #567 of 2739 Old 05-07-2009, 07:40 AM
HyperM3's Avatar
I got them in a kit, there were 6 wedges. Id say they are about 10" high. The kit is the Auralex studio kit and I picked it up from Guitar Center. That being said, they had separate bass wedges that were larger and might be more what you're looking for.
HyperM3 is offline
post #568 of 2739 Old 05-07-2009, 07:54 AM
Fanaticalism's Avatar
Your designs are truly breath taking Bosso!
Fanaticalism is offline
post #569 of 2739 Old 05-07-2009, 09:14 AM
otk
otk's Avatar
Originally Posted by fanaticalism View Post
your designs are truly breath taking bosso!
+1
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
post #570 of 2739 Old 05-07-2009, 09:34 AM
thirdeye11's Avatar
Are those subs Bosso had pictured his own designs? If so those are just sick. Some of the nicest looking subs I've ever seen. Very clever. I also wonder how that 20x6.5" mid bass module sounds. Looks super awesome!!
thirdeye11 is offline
Hsu Vtf 15h Subwoofer , Jl Audio Fathom F112 12 Inch Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Klipsch Sw 115 Front Firing Subwoofer , Rythmik Audio F15 Subwoofer , Tc Sounds Lms Ultra 5400 , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Seaton Sound Submersive H P , Klipsch Synergy Ksw12 12 Inch 105 Watt Powered Subwoofer , Jl Audio Fathom F113 Gloss 13 5 Inch Powered Subwoofer , Jbl Pb10 10 Inch 150 Watt Down Firing Powered Subwoofer , Klipsch Kw 120 Thx Subwoofer
