Cadence CSX-15 Powered Subwoofer 10% off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-17-2008, 11:01 AM - Thread Starter
dhayes01's Avatar
10% off $399 plus free shipping with checkout code TENOFF
www.cadencestore.com
CABINET SPECIFICATIONS
Hand Polished Gloss Black Piano Finish Front Baffle.
3/4" High Density MDF Fiber Construction.
Bonded and braced at all critical joints, engineered to dampen and eliminate all vibration for transparent and accurate bass reproduction.
Front firing subwoofer with "computer tuned bass-reflex slot port system".
Black wood grain cabinet finish with spiked footings and floor protection casters.
SUBWOOFER SPECIFICATIONS
High Power 15" Subwoofer.
2.5" Four-Layer Dupont Kapton Voice Coil Former.
100oz. Heavy Duty Magnet Motor Structure.
Extended Pole Piece Technology.
Vented and Extended Magnet Back Plate.
Double Laminated Surround and Dual Spider Suspension System.
Frequency Response: 20-500Hz
AMPLIFIER SPECIFICATIONS
Built-in Linear Class A 500 Watt Dynamic Power Amplifier.
RMS Amplifier Power: 225 Watts @ <1% THD.
High Current Output stage utilizing 6 Ring Emitter Technology Sanken Studio Grade Japanese Transistors.
Lowest Mains Buzz of any subwoofer on the market, guaranteed!
High Damping Factor >400 @ 80Hz for Superior Subwoofer Control.
33KOhm Input Impedance which prevents input signal loss and insures distortion free signal transfer.
High Grade, Minimal Loss, Tiffany Style Low Level RCA Input Jacks.
Auto Start Turn-On/Turn-Off with Audio Signal 1mV sensitivity.
Fully Adjustable Phase Control 0-180 Degrees.
Fully Adjustable Low Pass Subwoofer Crossover Frequency Control 40Hz-120Hz @ 12dB per octave.
Fully Adjustable Bass Boost Equalizer +12dB @ 45Hz.
Independent Sub Bass Volume Control.
Crossover Bypass Switch for Full Range Unit Operation Option.
Slew Rate 80 volts per uS in Full Range.
Frequency Response: 10-120Hz +/-3dB LP (10Hz-500Hz Bypass).
Signal/Noise Ratio >110dB+.
LED Power On Indicator.
110/220 Voltage Selector.
Cabinet Size: 18.5"(w) x 17.75"(d) x 21"(h).
2 Year Warranty
dhayes01 is offline
post #2 of 9 Old 10-17-2008, 11:42 AM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
Buy it thru Live.com on Ebay and get 30% off.
Sepen is offline
post #3 of 9 Old 10-18-2008, 12:45 AM
matthewmon's Avatar
anybody have any pics of the cadence subs? i've seen a pic of the csx15 but not a good view of the top of it. i haven't seen any pics of the csx12. the pics on their website aren't good. Are there any subs in this range that have a gloss black all the way around instead of just on the front? thanks!
matthewmon is offline
post #4 of 9 Old 10-18-2008, 09:29 AM
bagakay's Avatar
2 Year Warranty
Why are there 2 frequency response in the specs (blue and red). What do they stand for ?
bagakay is offline
post #5 of 9 Old 10-18-2008, 09:58 AM
Rucker's Avatar
If you look at the headings, you'll see the first is for the sub and the second is for the amp. Not sure why they list it that way.
Rucker is offline
post #6 of 9 Old 10-18-2008, 10:50 AM
kwaidonjin's Avatar
How do you get the 30% off? I see how to get 10% off but not 30%.........
kwaidonjin is offline
post #7 of 9 Old 10-18-2008, 12:30 PM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
At least, on the CSX 15 model I played with, the front baffle has the gloss finish. The top and sides are black vinyl. Same with the CSX 12 (gloss black front baffle behind the screen).
On the specs in blue and red...red = the sub's frequency response...blue = the amps frequency response.
I don't know why Cadence published the red spec up to 500hz. It maybe the overall FR of the driver. Very few run their subs above 120 -150hz and I'm sure rolloff starts happening around there.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #8 of 9 Old 10-19-2008, 07:54 AM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
Read this thread.. http://forums.slickdeals.net/showthr...highlight=live
Have to have a Live account, pay with Paypal on a buy it now, and then the "rebate" is in your live account in 60 days. Then you can transfer it to your Paypal account.
Sepen is offline
post #9 of 9 Old 10-19-2008, 05:47 PM
kwaidonjin's Avatar
Thank you.
