12 inch woofer vs. 13 inch woofer vs. 15 inch woofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-17-2008, 05:27 PM - Thread Starter
Toksin's Avatar
I've read many comparisons pitting SVS vs. HSU vs. Epik vs. etc...
However, I haven't read, nor have been able to find any reviews showing any benefits of one size woofer over another.
What benefits are there going with say a 12 inch woofer vs. a 15 inch woofer or a mythical 13 inch woofer? - never heard of such a thing before. Better extension? Lower bass with higher SPL? Or are there any benefits? Why would one manufacturer choose one size woofer over another? (Probably just a guess here unless someone works for a Sub manufacturer)
I'm currently looking at the SVS Ultra, SVS PB12-Plus, HSU VTF-3 MK3, HSU ULS-15, AV123 MFW-15, Epik Castle, Epic Tower, and Epic Conquest.
I had it narrowed down to 2 until I started reading back here at the forums! Thanks AVS Forum for letting me know about all these wonderful choices. By the way, if anyone has any opinions on the 8 I have it "narrowed down to" please let me know.
Toksin is offline
post #2 of 5 Old 11-17-2008, 05:34 PM
ribbit's Avatar
dont concentrate on the driver size ...
it's all about which can move the most air (in a linear way) BUT
driver size is but one factor ...
there's driver excursion
enclosure design
etc.
basically, you need to look at the overall performance and not a specific part of the subwoofer (unless all other factors are the same)
Mike C
MKC International
SVSound Philippine Dealer
ribbit is offline
post #3 of 5 Old 11-17-2008, 05:45 PM - Thread Starter
Toksin's Avatar
enclosure design
etc.
Thanks for the reply.
I know some people here have done SPL and Hz graphs for most (if not all) of the subs I listed above. Has anyone done any measurements of air movement by any of the listed subs? Or is that related to SPL? Aka High SPL = High air movement?
How does air movement work with sealed subs, such as the HSU ULS-15? Wouldn't a ported sub move significantly more air than a sealed sub?
Toksin is offline
post #4 of 5 Old 11-17-2008, 05:56 PM
ribbit's Avatar
in a sealed sub, the driver basically produces ALL the frequencies
in a ported sub, the port helps produce a set of frequencies depending on the port area, length and enclosure volume
again, we cannot generalize that a ported sub can move more air than a sealed sub
there are ground plane tests done by AVTALK and Home Theater Shack you can use to compare to each other (ground plane to ground plane)
Mike C
MKC International
ribbit is offline
post #5 of 5 Old 11-17-2008, 06:00 PM - Thread Starter
Toksin's Avatar
Got it. Thanks. I'll check out AVTALK and Home Theater Shack.
Toksin is offline
