Premier Acoustic PA-120 - Page 34 - AVS Forum | Home Theater Discussions And Reviews
post #991 of 2113 Old 04-03-2009, 05:40 PM
kwaidonjin's Avatar
Originally Posted by batpig View Post
read the Audyssey setup guide. it should be left at 120.
If you want more explanation, check out the Audyssey section of my FAQ (the explanation of LPF for LFE is towards the end): http://batpigworld.com/fadq.html#section_02
While my site is about Denons, the Audyssey stuff still applies to your Onkyo.
Here is my explanation:
O.K. Thanks for the info.
kwaidonjin is offline
post #992 of 2113 Old 04-03-2009, 05:43 PM
Iusteve's Avatar
Originally Posted by kwaidonjin View Post
Mine came with little rubber pads to put at the four corners, on the bottom.
I was hoping for something more substantial than those little things. I wonder what the effects of building a small riser just for the sub would be?
XBOX Live: Zz NiNj4 D4D zZ
Iusteve is online now
post #993 of 2113 Old 04-03-2009, 05:44 PM
kwaidonjin's Avatar
Audyssey keeps setting my 4 surrounds and center as full band and turns on double bass. I know i should set all to 80hz. the surround back it sets at 100hz. I have 4 Polk r50' and Polk CSi3 center. the back surrounds are 2 JVC that came with my old HTIB.
post #994 of 2113 Old 04-03-2009, 05:45 PM
kwaidonjin's Avatar
to bad the rubber packinf foam is so ugly, it would be perfect.
post #995 of 2113 Old 04-03-2009, 05:46 PM
samuelk's Avatar
I got online at Parts Express and ordered some feet, there are several to pick from.
Good luck and enjoy your new sub..............
samuelk is offline
post #996 of 2113 Old 04-03-2009, 05:49 PM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
read the setup guide
Audyssey doesn't choose small vs. large, your receiver does:
http://www.audyssey.com/faq/index.html#largesmall
Audyssey always recommends changing the speakers to "small" after running auto setup. 80Hz is a good default crossover if the speakers were set to full band. For something set higher (i.e. if your surrounds are set to 100) don't lower the crossover from where Audyssey measured it.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #997 of 2113 Old 04-03-2009, 05:50 PM
batpig's Avatar
Liked: 3420
or just get a subdude
Setup Guide and FAQ
batpig is offline
post #998 of 2113 Old 04-03-2009, 05:51 PM
kwaidonjin's Avatar
Thanks again, I am trying to read through it but I promised the wife and kids Bolt by 8pm.
post #999 of 2113 Old 04-03-2009, 05:54 PM
batpig's Avatar
Liked: 3420
don't disappoint the wife/kids!
Setup Guide and FAQ
batpig is offline
post #1000 of 2113 Old 04-03-2009, 08:33 PM
Iusteve's Avatar
Will the subdude fit this beast? It measures 15"x15" and the pa-120 is roughly 14 1/2" x 17"
post #1001 of 2113 Old 04-03-2009, 10:13 PM
kwaidonjin's Avatar
Well we watched Bolt on bluray, the opening was awesome,the sub definitely showed me what i have been missing.I haven't rally had a chance to get all the settings where I want them. it is hard to work on room placement with something that weighs 60#.I hat that the cord is only about 4 ft long. very short. I had to move my surge protector just to be able to plug it in.
post #1002 of 2113 Old 04-03-2009, 10:39 PM
hung8489's Avatar
I think the Auralex Gramma would fit it.
Denon 1910
RC-70's L/R Rosenut
RC-LCR Rosenut Finally!
C-50 Surrounds
hung8489 is offline
post #1003 of 2113 Old 04-04-2009, 07:40 AM
eric-t's Avatar
Supposedly the PA-120 is made on the same line as the Bic's. If so does it use a Bash amp? Looks alot like the Bic-F12.
eric-t is offline
post #1004 of 2113 Old 04-04-2009, 09:18 AM
Pinstripe's Avatar
No Bash.
Pinstripe is offline
post #1005 of 2113 Old 04-04-2009, 10:58 AM
plusk's Avatar
I finally received my pa120 yesterday.I agree with everyones comments on how it looks and it is heavy.I have a onkyo 706,so I ran the audyssy set up with the volume set at 6.Hardly any noise came out of the sub and audyssy set the sub at 24.5 feet,I ran it again with the volume on the sub at max and audyssy set it at the correct distance and at -15.5.I watched Quantom of Solice and did not really feel any thing from the sub but my infinity p362's sounded amazing.This morning I turned on some salsa music and I have to really crank up the music to get a vibration feel on the sub but nothing really substancial comes out of the sub.I am still hoping that the sub is just not broken in but I am scared that I wasted my money on a White Van Speaker
plusk is offline
post #1006 of 2113 Old 04-04-2009, 11:49 AM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
You didn't waste your money, something is wrong in your setup. Check the link below for setup questions and your particular avr.
http://www.avsforum.com/avs-vb/showt...ight=onkyo+706
Go Phillies! Go Eagles! Go Sixers! Go Flyers!
tingham is offline
post #1007 of 2113 Old 04-04-2009, 05:00 PM
billhev's Avatar
Does anyone know if UPS will require a signature for the sub delivery? I have to go out of town and will have to get a neighbor to roll it into the garage for me.
billhev is offline
post #1008 of 2113 Old 04-04-2009, 05:32 PM
subiefast's Avatar
I'm pretty sure signature is required. You may want to contact ups to have them hold it for you.
subiefast is offline
post #1009 of 2113 Old 04-04-2009, 05:52 PM
windomearle's Avatar
Yeah, UPS didn't leave mine because a signature was required. What kind of box does it come in? I can just sign the UPS slip and they should leave it by the door on the next delivery attempt. I did the same thing for my Polk Monitor 30s. It's probably too heavy for anyone to steal anyway. If it comes in a pretty plain brown box that would probably be better than a box with pictures of the subwoofer on it.
windomearle is online now
post #1010 of 2113 Old 04-04-2009, 06:04 PM
kwaidonjin's Avatar
Nope it comes in a walmart type box, it tells what is inside and all the specs. I had to sign for mine.
I set my volume at 6 and the x-over all the way up, audyssey set mine at the correct 10 ft. and the sub was awesome during the opening scene of Bolt. after that I didn't notice much difference in the rest of the movie. But there really wasn't alot going on after the first opening scene. I tried the Jericho missile test in Iron Man and the Skidoosh test in Kung Fu Panda and both sounded great. And I had just did them the night before on my old setup.Audyssey set my sub for -10db and the bass for -3db. I changed it to +3 for the Bass.
post #1011 of 2113 Old 04-04-2009, 08:59 PM
Iusteve's Avatar
Mine came in a box with all the pics and premier acoustic logos and a full description on it. Full advertising for any thief!!! DONT LEAVE IT AT YOUR DOOR!! UPS did require a signature. Any thief would throw their back out carrying it but it isnt heavy enough for someone to throw in their car and be gone with it.
post #1012 of 2113 Old 04-05-2009, 08:40 AM
plusk's Avatar
I did not have to sign for mine.
I am convinced this sub needs a pretty good break in to start sounding good,mine just keeps getting better and better the more it is played.I suggest for anyone just getting the sub let it play for 12 hours before calibrating.
plusk is offline
post #1013 of 2113 Old 04-05-2009, 10:38 AM
plusk's Avatar
Anybody know if this sub is shielded.I can't find any where that says it is shielded,I have mine close to my tv
plusk is offline
post #1014 of 2113 Old 04-05-2009, 11:06 AM
kwaidonjin's Avatar
Mine is 3 ft away from my LCD, no problems.
post #1015 of 2113 Old 04-05-2009, 12:25 PM
jaejw1's Avatar
dont know if anyone has seen this.. but here is a simple review on the sub.. http://www.hometheaterfocus.com/spea...coustics7.aspx
jaejw1 is offline
post #1016 of 2113 Old 04-05-2009, 12:44 PM
eric-t's Avatar
If you have a Plasma or LCD you have nothing to worry about as it doesn't effect these.
eric-t is offline
post #1017 of 2113 Old 04-05-2009, 02:24 PM
plusk's Avatar
Eric,
Thanks, did not occur to me,no picture tube.I have a samsung 52' 850
plusk is offline
post #1018 of 2113 Old 04-05-2009, 02:52 PM
eric-t's Avatar
Anybody else receive their sub that hasn't giving a review yet?
eric-t is offline
post #1019 of 2113 Old 04-05-2009, 09:40 PM
kwaidonjin's Avatar
That says it is a PA-6W subwoofer,Not the PA-120
post #1020 of 2113 Old 04-05-2009, 10:22 PM
jaejw1's Avatar
yes your right.. oops
jaejw1 is offline
