Sub(s?) for 5.1 with all five P362's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-01-2009, 03:39 AM - Thread Starter
BuckFitz's Avatar
I am considering which sub to get for a new setup in my 20x13 living room, about 3000 cubic feet. I plan to use five P362's as the front, center and surrounds in a 5.1 home theater.
I've been considering the BIC Acoustech H-100 (PA-120) Subwoofer, but was wondering what you thought about using two smaller 8" subs, like the Energy ESW-8. I wanted to spend no more than $350 on the sub.
What are the pro's and con's of a smaller dual sub setup?
Has anyone tried this especially with P362's before? Or similar?
Thanks! Merry New Year!!!
I'll let you know when to stop...
BuckFitz is offline
post #2 of 8 Old 01-01-2009, 07:03 AM
blued888's Avatar
For $350, the best you can get would be the eD A2-300. 3000 cubic feet is a pretty big space to fill.
Eclectic Electronics: A blog containing technology news, information about home theater, digital photography and more.
blued888 is offline
post #3 of 8 Old 01-01-2009, 07:34 AM
mayhem13's Avatar
Quoted: 45 Post(s)
Liked: 29
Since you'll be using all towers, your mid bass will be covered down to 50hz. Look for a sub capable of playback down to 20hz or so and cross low in your AVR, try 60hz first, then work downwards to find the best blend. You do have a large space so at some point, 2 subs or more will be needed but usually small driver subs don't go that low and the ones that do are at a cost. Ported subs with larger drivers are the most cost efficient option. One of the Elemental Designs would be a cost effective start, two would be better.
mayhem13 is offline
post #4 of 8 Old 01-01-2009, 10:35 AM - Thread Starter
BuckFitz's Avatar
Slightly more accurate measurements and verified math:
2,340 cubic feet
Thanks for the frequency and crossover tips...I need to be reminded of the basics. It's so easy to get sidetracked in this process.
IT'S ABOUT THE BASS
I appreciate your help.
BuckFitz is offline
post #5 of 8 Old 01-01-2009, 10:55 AM - Thread Starter
BuckFitz's Avatar
Is there a rule of thumb to indicate the relationship between cubic footage of a room and wattage of subwoofer, or maybe driver size?
Off to get my first SPL meter...
BuckFitz is offline
post #6 of 8 Old 01-01-2009, 09:47 PM - Thread Starter
BuckFitz's Avatar
I went with the Elemental Designs A2-300.
BuckFitz is offline
post #7 of 8 Old 01-02-2009, 08:55 AM
dev_81's Avatar
So how is your Elemental Designs A2-300? Is it filling the room and giving a thumping experience?
Dev
Ashburn VA
dev_81 is offline
post #8 of 8 Old 01-02-2009, 09:13 AM - Thread Starter
BuckFitz's Avatar
I hope it will...However, Elemental Designs builds to order, and I just ordered it last night. The lead time for the Subwoofer from ED is about 30 days, so I have some time to wait still.
I got an email this morning saying the cabinet is "Awaiting Woodshop" which makes me feel like it is just before 4th period in my sophomore year again.
Anyway, I can't wait. This home theater is my first and is the culmination of 4 years of research, saving, re-researching, more saving and finally negotiations with the wife to reorganize the living room.
Good times! I am sad that it is almost over...
OR IS IT?
BuckFitz is offline
