RCA cable pin broke off in subwoofer Help!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 01-01-2009, 09:21 AM - Thread Starter
Helter's Avatar
The RCA cable pin broke off in the female that's part of my subwoofer. I tried prying it out with a pin but only pushed it further in. Does anyone know what to do in these situations? I'm out of ideas Thanks
Helter is offline
post #2 of 21 Old 01-01-2009, 09:28 AM
Pure-Evil's Avatar
Liked: 150
you might be able to push it out from inside, take the amp out. if not, try a small small screw and screw it into the pin to pull it out. if that doesn't work...i dunno. maybe superglue on the end of something small enough to get into the rca female and then pull it out?
Pure-Evil is offline
post #3 of 21 Old 01-01-2009, 09:48 AM
harmann's Avatar
Sigh I'm in the same boat mate. What coincidence! Gonna get some glue now.
harmann is offline
post #4 of 21 Old 01-01-2009, 10:45 AM
Tulpa's Avatar
Liked: 61
Are the pins ferrous metal? Might try a magnetic screwdriver.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #5 of 21 Old 01-01-2009, 10:47 AM
SteveMo's Avatar
Use a straw.
SteveMo is offline
post #6 of 21 Old 01-01-2009, 11:01 AM - Thread Starter
Helter's Avatar
I'm trying to take the back off but their are "a lot" of screws. A few require a special wrench which I don't have but going to go over my brothers later he's got all the tools there. I even tried a wine cork screw but couldn't get a grip. Coming in from the rear might be my only hope.
This really sucks. Not a good way to start New years
Helter is offline
post #7 of 21 Old 01-01-2009, 11:04 AM - Thread Starter
Helter's Avatar
There's black/gray stuff in the middle surrounded by metal. I've been trying to scrap/pull from outward inward to maybe break it free but no luck so far.
Helter is offline
post #8 of 21 Old 01-01-2009, 11:11 AM
bulabula's Avatar
Never had this happen to me. Don't flame me - I know its not a wheel stud or broken engine head bolt, but is it possible to carefully drill it out, or use an easy-out?
Chris
Feelings of inferiority and superiority are the same - they both come from fear
bulabula is offline
post #9 of 21 Old 01-01-2009, 12:09 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Take a tooth pick (or something similar), put super glue on the end, carefully put the glue end into the center of the pin. Let the glue set, then pull it out.
BTW, if you are connecting to the left or right line level inputs, just get a new cable and connect to the other side.
Randy
ransac is offline
post #10 of 21 Old 01-01-2009, 12:31 PM
JBLsound4645's Avatar
I could think of a few ways, some of which have been already listed. It’s only small thing piece of metal to retract.
Solder a small piece of wire onto the end and solder another piece of wire to the outer side of the RCA connector, now you van still enjoy sub bass.
No seriously solder a wire to the inner pin with a piece of wire then tug gentle on it until it comes out. Now if this doesn’t work remove the RCA connector and replace with new RCA connector easy.
Originally Posted by SteveMo View Post
Use a straw.
Use a, strew indeed.
How about using a vacuum cleaner, sub now goes from blow to suck mode.
JBLsound4645 is offline
post #11 of 21 Old 01-01-2009, 01:27 PM
Pure-Evil's Avatar
Liked: 150
Use a straw.
are you crazy? are you suggesting he try to suck it out? want the guy to choke to death on new years day? do NOT do that!!!
post #12 of 21 Old 01-01-2009, 01:40 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
Is that little piece hollow? If so, I bet you could use a very small pointed screw. If it's got small threads on the tip, and you push it in, it might grip enough to pull the broken piece out.
If it's just laying freely inside, I assume you tried turning the thing up on it's end at just let it fall out with a few shakes? Certainly can't be that easy though.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #13 of 21 Old 01-01-2009, 02:08 PM - Thread Starter
Helter's Avatar
I'm not sure about carefully, but this worked. I basically mutilated the inside of the female RCA connector with a drill. I got a lot of dust and shreds of black matter and kept drilling until I could get the male to have a tight enough of a connection. I still think part of the pin is in there. But I was afraid of doing damage so I stopped.
Thank you to everyone for your suggestions. Not how I wanted to spend New Years day but what can you do.
Helter is offline
post #14 of 21 Old 01-01-2009, 03:06 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
I believe he meant to use the straw as a sleeve. I don't know if a straw is the correct OD to slip right into an RCA socket, but if it is, the straw would slide in around the pin, then pull out the straw and the pin would come with it. If it works it is an ingenious suggestion. Now, if Steve suggested the OP drink a Moosehead, then he would risk choking to death on New Years Day.
Randy
ransac is offline
post #15 of 21 Old 01-01-2009, 03:20 PM
Honey what’s wrong?
I, I?
Yes I, I?
I, I, I?
Oh, you what to watch I, Robot do you.
I, I, I, [coughing] I, can’t breath.
Sorry honey we don’t have that film on DVD.
The average strew in the home is probably to narrow so a quick trip to Burger King will solve that problem. Also you’ll need a strawberry milkshake to wash down the small RCA phone pin afterwards.
post #16 of 21 Old 01-02-2013, 03:00 PM
Cooper Hendrick's Avatar
i feel like a high powerd vacume hose might be able to pull it out cant hurt two try
Cooper Hendrick is offline
post #17 of 21 Old 01-02-2013, 03:04 PM
DonH50's Avatar
Quoted: 1791 Post(s)
Liked: 1325
Why not just remove the amp module?
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #18 of 21 Old 01-21-2014, 08:43 PM
tim1111's Avatar
Same happened to me on my macbook pro about a month in from ownership not covered under warranty of course. 950.00 for a new motherboard to have it fixed.
I know this post is old but I'm' pretty sure there are lots of people still in the same boat and i hope you come across this on your travels.
-I tried taking my mac apart to no avail so don't even try.
-the crazy glue thing i didn't even try.
-i had been using the griffin imic for about a year hooked up to my home
stereo, which works great in overriding the 3.5 jack but the problem there
is that they are super expensive and both of them just stopped working after a few months. JUNK.
-today i picked up a veho speaker with tongle which works and is portable.  don't expect
great sound but its decent, but they are also expensive and cheaply made.  But i have
sound again!!  the veho tongle hooks directly into the usb port. No hassle work by bluetooth. time will tell
how this little thing stands the test of time but we will see.
i hope this helps some other poor souls out there in cyberspace?!
Tim
tim1111 is offline
post #19 of 21 Old 01-22-2014, 12:16 PM
sdowney717's Avatar
Rca plug? pretty good sized diameter so.
Take a pin.
put a tiny glob of epoxy on the end
Use a magnifying glass to aid your sight.
The glob should be real small, if too big it will glue to the plug socket.
Maybe use the sharp end of pin
put end onto end of broken pin.
Let set for several hours. Tiny amount of epoxy will take a little longer to set.
then pull it out.
sdowney717 is offline
post #20 of 21 Old 01-23-2014, 06:03 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I had something similar happen to me with HDMI. Since I had a bunch of unused HDMI ports, I just left it in and used another one.
I've had many connectors of different types break on me. All from monoprice. I know their cables work fine, but their connectors are generally really poor quality. That's how they can sell for a lot less than brand names. I have some old monster cables that are good as new. They cost 10x as much, but they are better.
KidHorn is online now
post #21 of 21 Old 02-03-2014, 04:39 AM
RH55's Avatar
This happened to me in December. Once I got over the panic, I used a set of very small tweezers and a micro flat head screwdriver to work it out of the socket. Got it out with no damage. Good luck!
My gear: Epson 6030 with a Carada screen, Oppo 103D, Marantz 8802A, JTR Triple 12 LCR, JBL 8340 sides and surrounds and Totem Mask6.5s overhead for Atmos. Dual sealed SI HT18D2 subs driven by a Peavey IPR7500 and some aura shakers underneath. Experimenting with Roomie Remote to make it all work.
RH55 is offline
