Paradigm Sub 12 & Sub 15 - Page 28 - AVS Forum
post #811 of 831 Old 03-17-2013, 08:23 AM
crendny's Avatar
hello do you still have sub12?
crendny is offline
post #812 of 831 Old 03-17-2013, 06:04 PM
RandyDee's Avatar
I do, of course.
RandyDee is offline
post #813 of 831 Old 03-17-2013, 06:38 PM
kzhtoo's Avatar
I do, of course.
kzhtoo is offline
post #814 of 831 Old 03-19-2013, 12:29 PM
coresare's Avatar
Here's my Paradigm Sub 12 ARC result.
coresare is offline
post #815 of 831 Old 03-20-2013, 01:17 AM
AVfile's Avatar
Quoted: 65 Post(s)
Liked: 65
Originally Posted by Bill Fitzmaurice View Post
Telling a loudspeaker designer how drivers function is as logical as telling a bird how to fly. rolleyes.gif
Loudspeaker designers never consider 'speed', as all drivers react at the same speed. They also do not consider pitch definition. Those are words that laymen sometimes incorrectly apply to some of the concerns that loudspeaker designers do consider but the layman does not know how to describe in engineering terms.
Cone size in and of itself only affects one result, the angle of dispersion. Every other result is determined by the two dozen odd T/S specs and other driver details.
Some of us are able to follow what Boyce was getting at in layman terms, and some designers do voice their speakers based on subjective listening tests and not rely completely on engineering terms and measurements. Speed and pitch definition is often referred to when describing bass quality, I am sure you have been around long enough to recognize this, no need to be pedantic. As you said there are many other factors that could explain the phenomenon (possibly indirectly related to size) so we shouldn't kill the discussion so fast.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #816 of 831 Old 03-20-2013, 01:39 AM
AVfile's Avatar
Quoted: 65 Post(s)
Liked: 65
Originally Posted by boyce89976 View Post
Hmmm... their specs don't list frequency response or output? While Ann 18" driver would be fine for movies, I'm certain the Sub12 and even the Sub15 would have better pitch definition and speed for music.
What I found more interesting was the lack of company info. I could not find anything introducing who they are and where their facilities are, if any... Just a phone number (Vancouver BC area code which could be just an importer).
- AVStefan
AVfile is offline
post #817 of 831 Old 04-06-2013, 02:36 PM
scowly78's Avatar
hi guys
just installed my brand new sub 12 studio.
i tried to pbk it as i had the kit included in the price
no problem to install it on the laptop, software works, and both sub and mic are correctly detected both by laptop and paradigm pbk software
when i go to Tools and quick measure then the sub play his tone, and the software does the measure.
but when i want to run the 5 point calibration then it fails.
it detects the sub, it detects the mic and serial of mic, then it launches the tone of the sub, and then it says error 0000x04, impossible to successfully measure the response of the sub.
in the same message it advice to move up the level of the sub, and try again, but even pushing it at full speed, it just doesn't work
anyone had the same issue? any idea?
cheers
scowly78 is offline
post #818 of 831 Old 04-06-2013, 07:47 PM
coresare's Avatar
Grats on the Sub 12. Sorry no info on the problem. I use ARC with my receiver and that works fine.
coresare is offline
post #819 of 831 Old 04-15-2013, 04:31 AM
clintsound's Avatar
Just wondering with the pbk do I run this first then Yamaha ypao? Or run ypao with no sub the run pbk by itself. ?
Your help is most appreciated.
clintsound is offline
post #820 of 831 Old 04-15-2013, 04:35 AM
scowly78's Avatar
hi
first you must run pbk on the sub
when this is done then you launch your av amplifier calibration
cheers
clintsound likes this.
scowly78 is offline
post #821 of 831 Old 04-15-2013, 06:17 PM
clintsound's Avatar
Originally Posted by scowly78 View Post
hi
cheers
Thanks for that what should the volume and frequency be set at?
post #822 of 831 Old 04-16-2013, 12:58 AM
anthonywoy's Avatar
Funkywaves is now called Funk Audio. It is located in the Sunshine Coast, Half Moon Bay. Not an importer, they make their own subs. Just visited them today smile.gif
You can check out their website.
Hope you guys are enjoying your Sub12. The industrial design on these subs is first rate! Love how they look.
anthonywoy is offline
post #823 of 831 Old 04-16-2013, 10:17 AM
AVfile's Avatar
Quoted: 65 Post(s)
Liked: 65
Why isn't this info on their website?
- AVStefan
AVfile is offline
post #824 of 831 Old 04-16-2013, 12:29 PM
anthonywoy's Avatar
Not sure why AVfile, would have to ask them. It is a small family run business, with his father and brother-in-law helping out.
Has a machine shop, as they make some of the parts for the subs right on the premises.
For their top end subs, they make their own drivers and amps.
post #825 of 831 Old 04-20-2013, 01:06 PM
Dartvidar's Avatar
Im also looking at the paradigm subs. I will use them for both music and cinema, should I buy two Sub 12 or one Sub 1? I can save some bucks with buying two sub 12 compared to one sub 1, but how is two sub 12 sounds compare to the sub 1?
Dartvidar is offline
post #826 of 831 Old 08-11-2013, 09:43 PM
icemanjs's Avatar
Just got my sub 12 and ran my pbk
icemanjs is offline
post #827 of 831 Old 12-07-2013, 08:44 PM
dsteak's Avatar
It's been a while, but what was your decision? I'm also facing the same decision, 2 Sub 12's or 1 Sub 1. I'm going with S8/C5/ADP3 5.0. 50% music, 50% movies.
dsteak is offline
post #828 of 831 Old 03-27-2014, 07:11 PM
Bboy_jonno's Avatar
Hi, I just purchased a sub15 and pbk. I am having trouble getting the mic to work. Im using windows 7 home. All drivers and firmware is up to date. In pbk it detects the mic but saying can not find valid mic when i start to run the test. In device manager it says class 10 error. I have tried reinstalling multiple times and it keeps getting this error. Please help me!
Bboy_jonno is offline
post #829 of 831 Old 03-27-2014, 10:09 PM
UTHT's Avatar
It may sound silly but have you tried a different USB port. I had a similar problem on my win 7 laptop and swapping ports worked.
UTHT is offline
post #830 of 831 Old 03-28-2014, 05:27 PM
briank12's Avatar
I also had trouble with Windows 7 Home finding the Mic. An online upgrade to Windows 7 Professional solved the problem.
briank12 is offline
post #831 of 831 Old 07-11-2014, 09:51 AM
Lord Godking's Avatar
Just ordered a pair of Cherry SUB12's replacing a pair of PBK'd UltraCube10's.
I've been in the business 30yrs. Review to follow
Current setup
Integra DHC80.3
Bryston 3B's x3
Bryston 4B x 1
Monitor Audio Silver pkg
Silver 5's
Silver 3's
Silver 10
Paradigm UltraCube10 x2 PBK'd
Lord Godking is offline
